View Full Version : Engineering/ Technical
  1. Body-on-Frame vs. Unibody Structures
  2. GMC Fuel Pressure drops
  3. High gas prices
  4. mystery carburetion fault
  5. Alarm Help
  6. diagnostic software
  7. 87 rx turbo mystery
  8. Help!!
  9. Help! with a brake Job...
  10. Gas tank bubbling?
  11. No High Fan Ac/heater
  12. How to change voltage from 12V to 3.5V without power loss?
  13. How to make the disc brake spreader?
  14. need tire advice
  15. No pressure in brakes
  16. Need 68 Mustang 302 ignition advise
  17. Rings only....or more?
  18. No power to Fuel Pump after crank
  19. engine stalling after removing load
  20. EGR and performance
  21. 454 Vs. 350
  22. Engine cylinder numbering for Lincoln LS
  23. ecm fuse blows
  24. brake replacement
  25. Eaton Limited Slip Making New Noise
  26. tranny flush gone wrong
  27. brake problems
  28. Fluctuating Oil Pressure
  29. Would it be possible to take the nose off a 68 lemans and put it on my 71?
  30. Horn Amperage/Relay Question(s)
  31. 1988 300zx n/a won't rev past 3k
  32. help with tahoe problems
  33. Replacing Oil Filter on Buick Enclave?
  34. Mechanical advance doesn't work - '79 TA
  35. R&D thinking
  36. Looking for rear diff gurus
  37. 2 months later - the 20 second idle!
  38. Toyota Camry 1996 coolant overflow
  39. I need help
  40. vibration
  41. Problems with 2004 ranger
  42. Problems with 2004 ranger
  43. Gas Fill-up Causes Car to Flood?
  44. Horn problem/Fuse Box question
  45. Drilling Hole In Thermostat
  46. dodge 1500 4.7
  47. Air Conditioner lubricant.
  48. Small (ish) diesel
  49. Plug Fouling with TPIS Mini-ram
  50. Clutch not returning properly.....
  51. Help me please.. buick riviera wont start
  52. Turbo bike Carbs
  53. What's a good starter car to learn on?
  54. 69 Camaro Project in Portugal, Europe
  55. Mystery fuel pump whine...
  56. 383 Stroker question
  57. 93 honda civic valves & lifters
  58. 94 k1500 z71 tranny slipping
  59. 87 mustang gt- no spark
  60. Power Generator using DC Motor and Alternator
  61. Gotta brag a bit... GTO-related!
  62. Can better Exhaust System give better MPG?
  63. Too much coolant?
  64. Slipping AC, A/C clutch
  65. Question about Career in Automotive
  66. Starting problems
  67. making a supercharger
  68. mobility scooter lift-2003 baja
  69. still wont shift gears.. any clues ? ?
  70. GM Fuel Gauge/Sender Question
  71. ***HELP!*** Strange Light Problem
  72. 97 intrepid timing belt
  73. Any clues to my problem?
  74. Window Motor or switch?
  75. Would This work?
  76. 1989 F150
  77. trailer hitch AC power converter
  78. "Universal Remote"
  79. 61 Corvette Auction Tickets Start At $10
  80. What's wrong with the handbrake????
  81. Building a New Buggy
  82. How to remove the ignition on a 71 lemans?
  83. Ethanol
  84. renault
  85. A new paint job for my 65 MGB
  86. Changing disc brakes - how can you tell if you need new rotors?
  87. xsara picasso hdi tyres
  88. Honda Electrical Drain
  89. Penn Foster Career School Auto Repair Technician
  90. rod bearings check
  91. What to do with oil after you’ve changed it…?
  92. Air Conditioner Compressor
  93. informtion on muscle cars
  94. Missing on 2 cylinders...need help
  95. Battery Disconnect Switch
  96. Price exceeding estimate
  97. Diagnosing a brake problem
  98. New Weber Carb flooding
  99. Keeping it legal/smog friendly
  100. 1970 Duster Help
  101. 1970 Duster Headers
  102. 1970 Duster 340 Blower Question
  103. 1970 340 Duster
  104. 1973 Dodge Challenger Rallye 340
  105. 1990 Pontiac Sunbird-Did i put too much motor oil?
  106. Engaging starter while engine is running
  107. 78' malibu new weather stripping
  108. What parts make a car loud?
  109. need help for head swap
  110. 1994 ford taurus worth keeping?
  111. How does an alternator work?
  112. Turbocharge Small Block Chevy Questions
  113. Vanagon 2nd gear piston cover
  114. pontiac grand prix a/c problems
  115. 2 Stroke hard starts
  116. 1999 marquis headlight removal.
  117. Nissan R-12 AC fittings
  118. body kit problems help me..???
  119. need some help please
  120. Anyone Know much about Patriot Heads
  121. fuel problem
  122. TIming issue?
  123. chain shoe
  124. Solution detection position autonomous car
  125. I have a small issue with my wind shield wiper
  126. 97 toyota camry 2.4 5SFE how to R & R cams
  127. Decontaminating Brake Pads
  128. need help
  129. fuel filter location
  130. How to pass the exhaust inspection
  131. Can you ID this Alternator ?
  132. Converstion Kit
  133. Big Block Chevy Parts (Merlin heads, Edlebrock, holley, mallory)
  134. The myth about air/heat and gas!!!
  135. Difference between an intake manifold and plenum?
  136. all of the sudden no reverse!
  137. Survey (for my graduation thesis, please help!)
  138. Car modelling tools
  139. Oil Catch Tank Advice
  140. firing problem on 97 maxima
  141. a/c problems
  142. Help Needed to Replace Burned Rod Bearing
  143. Engine fails to start on my truck.
  144. 2 fuels filters on my truck?
  145. 1989 caprice help
  146. Elevated oil temperatures and bearing failure
  147. 1972 charger engine build-up
  148. Wiring Diagrams
  149. Important! Help! Tires!
  150. STOLEN in Ontario 1972 Copper colour Nova
  151. Monster in the exhaust manifold
  152. transmssion cooler theory question
  153. Floating or Press Fit pins?
  154. Tail Light problem
  155. Is this head useable?
  156. what type of head is on a 98 trans port
  157. I need a cam timing lession
  158. Muscle Car rumble for a driver?
  159. Help me pick an engine to use!
  160. Who made the BEST looking/best running muscle cars
  161. gx160 Honda Engine low on power
  162. Removing sludge from a pulled motor?
  163. boss 429 info
  164. 08 honda civic si
  165. styrofoam in my gas tank!
  166. Custom exhaust for 1973 mustang mach 1?
  167. HELP:Car stuck in limp mode
  168. '76 Chevy C10 - Having Problems At Startup
  169. new product Autocern
  170. How to make a good muscle better
  171. Need Help for first car (muscle)
  172. Teaching Aids with Cutaway.
  173. 1969 Chevy Camaro RS
  174. Need help programming Hypertech on a 02 S10 4.3
  175. 1957 Ford Fairlane 500.... With a 351 winsor cobra engine
  176. ford probe motor swap
  177. 98 blazer electrical problems
  178. 93 Blazer spraying fuel
  179. 86 Comaro 8-cylinder
  180. Parking Brake Adjustment
  181. 1994 Bronco 4x4 Full size NO BRAKES
  182. VW IAT sensor location
  183. 1968 Pontiac Tempest
  184. '93 Chevy Silverado 2WD ABS bleed procedure
  185. tragedy
  186. Analog instrument clusters? HELP!!!!
  187. Wet Torque vs Dry Torque
  188. looking for acid dip metal stippers in north east
  189. choosing major (automotive school) help
  190. how do i reprogram a keyless entry keypad?
  191. 87 Buick Regal: Re and RE Headliner?????
  192. 71 Cyclone GT Modification Advice
  193. 99' Mercury Grand Marquis noisy valves
  194. HELP Please! Diagnose breakdown!
  195. Which vehicles are the easiest to maintain?
  196. Timing belt trouble Ford Zx2 1998
  197. 1966 Nash Rambler speedo cable problem?
  198. 1966 Nash Rambler speedo cable problem?
  199. Building a tank
  200. Out with the Tapered roller!
  201. Summit Racing Gift Card
  202. 1966 Nash Rambler speedo cable problem?
  203. RWD Cars
  204. 430 hp 383 small chevy for sale
  205. Hitching my Trans Am "Truck"
  206. Turbo Integra wastegate location
  207. DOHC better than SOHC?
  208. Towing 4X4 Nissan Xterra
  209. Big Block Chevy Cam Recommendation Anyone?
  210. Tank tracks?
  211. 2007 toyota avlon
  212. PICC and hydro assist fuel cell
  213. Please Recommend an Oscilloscope for Diagnostics
  214. how to
  215. '89 CRX 1.5 Litre ?????????
  216. Anyone Attend the Fabulous Fords At Knotts?
  217. Broken sunroof, what's the problem?
  218. plymoth voyger 95 A670 transmission will not shifft
  219. 86 Ford Escort runs rough at mid range rpms
  220. 92 beretta?
  221. APPEEC 2009 Call for Papers px
  222. steering toward the right answer
  223. Mustange rear end
  224. "Hell Camino" Paint Video
  225. Carbon fiber custom roadster need an engine!
  226. Oil Change problem !!! dipstick maybe faulty...
  227. Hey newbie here
  228. Ase materials
  229. accelaration drops after speed 50 mph
  230. Filters
  231. Looking for a 12v vacuum pump to open and
  232. haldex clutch
  233. brake problem
  234. 1998 Silverado PU, 4x4 Shifting problem
  235. On car damper tester ELKON L 100 - documentaion
  236. changing from 205/70/15 to 225/70/15
  237. 92 ramcharger no fire-bumpy road
  238. Spindles, bearings
  239. My new project - reviving car unused for nearly 13 years
  240. Anyone have some engine building books they recommend?
  241. passlock, disable, turn off, by pass
  242. Need help with a misfire
  243. From Scratch
  244. Reverse diff concept
  245. coolant question
  246. Recliner Broke! Help Plz!
  247. Exhaust fan size
  248. TH325-4L Upgrades?
  249. 2002 Elantra No electrical working
  250. Car sabotage?
