View Full Version : Engineering/ Technical
  1. Rolling back the odo
  2. Re-Programming a Multi Displacement Hemi
  3. Shift fork broke?
  4. Dynos near Cincinnatti Ohio?
  5. car not running.. need help!!..
  6. What about motor oil?
  7. Muscle Car Console
  8. Muscle Car Dash
  9. Muscle Car Dash
  10. Muscle Car Dash
  11. Muscle Car hood scoop/bulge
  12. Muscle car roof line
  13. Muscle Car Exhaust Tips
  14. Muscle Car tailghts
  15. Muscle Car concealed headlight system
  16. Muscle Car Color
  17. Muscle Car Intake system
  18. Muscle Car Wheels
  19. Muscle Car Stripes
  20. trans trouble help please
  21. VIN searches?
  22. 67 camaro rack&pinion
  23. Ram air Vs short air Vs cold air
  24. makeing sense of intake pressure?
  25. What does this light mean?
  26. Theory: Using brakes to assist traction with an open differential
  27. Engine readings, notice anything odd?
  28. need help.. just starting on cars..
  29. Frame Damage
  30. 1991 rs
  31. Emission regs
  32. Diesel
  33. Changing Intake manifold gasket 1997 chevy 350 5.7...
  34. How bad is a stripped bolt?
  35. bmw..?/
  36. Alright, BOV question for you all...
  37. Flex Fuel?
  38. Physics Student Very Curious
  39. panic button
  40. LS/VTEC turbo or B18C1 turbo
  41. Question! PLEASE help
  42. Engine Running On Hydroxy Gas From Water
  43. Radiator Fluid leak? Can't find source.
  44. oil?
  45. Overheating, out of ideas...
  46. Hesitation on 2001 Ford Escape 6cyl.........
  47. fog light ignition
  48. Autozone Question
  49. Transmission Problem?
  50. chevy problem
  51. Ignorant Question Concerning Coolant
  52. Tire preasure display- How does it work?
  53. Speed Pro Cam Specs
  54. blowing white smoke
  55. ARE INVERTERS SAFE? 12V to 120V
  56. Misfire issue
  57. Support Our Troops Cruise Night 2007
  58. Lower radiator hose heater
  59. 82 Monte Carlo Restoration
  60. can i get your opinion??
  61. Synthetic oil testing.
  62. does it matter?
  63. wrong topic but got a question
  64. Quick Vibe Question
  65. Detroit Diesel 2 Strokes
  66. Cam choice finer points
  67. SCARY Saturn problem!
  68. Tisonic Immobiliser diagram
  69. Oldsmobile problem
  70. What tools do I need?
  71. Automotive Repair
  72. gmc electrical schematic
  73. Automatic Door Locks
  74. Car noise... Strut?
  75. Carb Info??
  76. 2001 Ford Escape. Strange symptom........
  77. stuffing a 71-75 olds or buick 455 into a 84 Lesabre 2dr
  78. High Output Alternators
  79. car runs badly with no throttle response
  80. Rather perplexing...
  81. Redesign indicator for car explosion prevention system
  82. Torque Specs
  83. how do you remove the wheel?
  84. Whats the value of this LeMans??? Is it worth 10,000?
  85. How to change powersteering piping
  86. 67 firebird engine
  87. 1970 LeMans coupe Value
  88. problem with car - won't start
  89. oil & antifreeze
  90. VS series 3 stopping
  91. muscle forum dont like to respond
  92. good question
  93. Matched set of Holly 660 center squiter carbs
  94. Problem with wiper motor
  95. Disengaging from wheels to something else?
  96. Synthetic Oil....
  97. Need help with bm shifter
  98. For Sale 63 Pontiac Grand Prix
  99. Exactally how good at math do you have to be to be a mechanic?
  100. supercharger modification needed?
  101. Cleaning carbon varnish.
  102. flat engine oil questions
  103. wheel vs. tire weight ratio
  104. 240sx dohc swap
  105. what should i get
  106. GM Muscle Performance List from 1973-1985
  107. Do rim sizes effect wheel hp?
  108. car trunk help
  109. Carb again..
  110. 1991 eagle talon questions
  111. gearshift selector button hard to push in only in park
  112. Please help.
  113. Injection Altitude Compensation (Carb)
  114. Truck body armor
  115. Re: clutch noise
  116. Valves Discussion..
  117. Passed emissions but noticed why my steering wheel wobbles!
  118. How to derestrict a golf buggy?
  119. dumb question but need help
  120. Mx5 Straight six
  121. Can't reverse, only drive in 2nd gear
  122. Help 96'blazer Heater Core
  123. FS: 1967 Mustang - 289 auto - $6500
  124. Engine Rebuild
  125. 1989 ford probe idle issue
  126. emissions
  127. emissions
  128. valve guides
  129. Urgen- Ford Mondeo Water Problem
  130. Wiring Diagram
  131. Flowmaster rust through
  132. F/S 1973 ranchero 500 with cobra jet
  133. Structural Rigidity enhancement...
  134. studded snow tires fall out?
  135. 95' Taurus not starting... what could it be?
  136. Structural Changes between a models trim
  137. Spotlights
  138. where is the bank 2 Oxygen sensor located?
  139. suggestions,tips, tricks, or info please
  140. Minivan advice required
  141. Car Pedal System
  142. Abs
  143. Oil plug stripped threads (2001 Escape)........
  144. What ship you own?
  145. did i throw a rod?
  146. reverb
  147. Tune Up
  148. Bore/Stroke Ratio..
  149. Check the head and block for warping...
  150. olds missing
  151. car RPMs drop as you drive
  152. TBI Engine swap, won't start
  153. ignition coil wiring
  154. Battery Light On and Off, Help
  155. exhaust tip
  156. im f-ing retarded
  157. Best way to build a 351 cleveland??
  158. Tightening the Accelerator cable
  159. Please Help Identify these Parts
  160. roller parts
  161. 82 olds won't start
  162. honda transmission problem
  163. FS: 1972 GMC Sprint (A Body)
  164. Changed trans fluid in 98 Grand Caravan & added Trans X fluid to help leak,is this ok
  165. head gasket
  166. 93 Caddy not starting, but strange..
  167. Got trans fixed now power steering problem.
  168. hot brakes
  169. certification exams ?
  170. Need help with twin turboing a 327ci in '57 Chevy
  171. SO whaddya guys know about medium duty trucks?
  172. Engine shakes at low RPM
  173. Carberator Idle System..
  174. Cut-Off, Hit Curb
  175. Stereo Options on a 2nd Gen
  176. Headers - Long vs. Short
  177. 1999 Tahoe Fuel Pump / Won't start cold
  178. power steering problem on chrysler sebring
  179. Dyno testing
  180. Chevy Astro Fuel pump
  181. chevrolet venture
  182. 96 ford taurus
  183. transmission help, stuck in third
  184. antifreeze leak
  185. 93' Cavilier engine
  186. High Reving No Movement
  187. Do vehicles with distributors have crankshaft positioning sensors?
  188. MSD blaster 3 coil blew up
  189. is there an A/C compressor that will work?
  190. ae82
  191. 1970 Super Bee elctrical questions
  192. 1990 thunderbird sc rpm drop and car stall some times .
  193. transmission for 1989 chevy suburban
  194. Help with weird starting issues...
  195. Source for diagnostic trouble codes?
  196. Turn signal flasher on 87 Oldsmobile Cutlass Crusier
  197. Careers Abroad
  198. Rough idling or something of the sort?
  199. Flowmaster Muffler.
  200. 1967 firebird after market head unit
  201. 2000 Gmc Van
  202. 4L60E transmissions
  203. AOD wiring
  204. anyone familiar with seats and safety?
  205. Brake job
  206. Wiper fuse keeps blowing?
  207. Voltage drop ok?
  208. Looking for advice on a new project car...
  209. Spongy Brake Pads - (Calipers?)
  210. topaz
  211. Firebird
  212. SAE flywheel housing
  213. Oil switch sensor
  214. Red Cluster Needles
  215. Windstar misfire
  216. Little Red Straw has entered throttle body!!
  217. strokers
  218. Chevy Maxx Steering Wheel Freeze
  219. 01 SS monte Carlo
  220. More diesel engines
  221. Shifter Forks
  222. differentials??
  223. 1995 s10 4 wheel only front brakes work
  224. e85/flex fuel conversion
  225. need help increasing h.p. to 2006 dodge charger rt.
  226. a prob with my 69 nova
  227. help with a engine swap
  228. please help
  229. Remanufactured Engine
  230. Trouble Starting my car
  231. What Happened
  232. Diesel engines
  233. Is this a Lamborghini engine?
  234. 2004 Dodge
  235. High NOx 1997 vw
  236. holley 9510 carb ?'s
  237. edlebrock ford bigblock manifold and holly 9510
  238. 1989 chevorlet suburban
  239. i need help fast!!
  240. Insurance on muscle cars?
  241. 1995 oldsmobile Delta 88/ won't run
  242. can anyone help
  243. airflow question
  244. Engine Overheating
  245. cheap easy horse
  246. cold air intake - how to create one
  247. CLimate fan not working?
  248. A stupid question...
  249. Alternator test and battery drain test?
  250. Whats wrong with my car!!!
