View Full Version : Engineering/ Technical
  1. 96 nissan 200sx Sr20de OBD II Cutting out at 2500RPM feels like rev limiter
  2. sunroof help
  3. cuda bumper brackets
  4. engine
  5. Radiator Drain and Refill.. Good Enough..?
  6. I hope someone can help!
  7. Steering Problems..Rpms drop..Hard to Turn..?
  8. looking for a 1970 Chevelle 454 SS
  9. Programming Instructions for programming instructions EZSDEI474V
  10. 68 Camaro SS vin check to see if real?
  11. new new new nitrous system
  12. Hydrogen engines
  13. Light Problem
  14. Seeking Fairlane production Info
  15. What the %^#@ with these gas prices
  16. Maintenance Question
  17. Air shocks?
  18. Do I need a new clutch?
  19. 87 maxima-stalling issues
  20. Some helpful FAQs, newcomers PLEASE READ!
  21. What is this car?!
  22. need help
  23. How's it Done..Radiator Flush..?
  24. Need some help with interior of '82 Camino
  25. looking for help
  26. Dead Radio -- Need Help
  27. Dukes of Hazzard Sound Effects for the General Lee
  28. Engine I'm looking at buying
  29. piston suggestions
  30. Lowrider Hydraulics
  31. Need to replace a cigarette lighter
  32. Compressing/Decompressing Shocks?
  33. Good to know that an American Muscle Car is the fastest production car ever
  34. 1969 Chevy Caprice Parts needed
  35. Non Technical but congrats Curtis73
  36. just a wild idea, i wanna know if a turbo would be possible on a 351c
  37. Rebuilt Engines
  38. 1998 Buick Regal GS will not start sometimes
  39. 1967 Mustang door Panels
  40. transmmsion, ford
  41. 1972 351 windsor engine for sale
  42. 1967 ranchero for sale
  43. CV joint or transmission
  44. Battery Discharge problem
  45. Problems with starting 89 Dodge Dakota
  46. 350 swap 92 s10 digital dash
  47. so lost 350 or 383?? seached..but now lost
  48. ~*2005 Midwest Performance Street Racing DVD FOR SALE*~
  49. 1988 Honda Prelude electrical control problems
  50. 1948 Inline 6
  51. 68-70 dodge charger
  52. JB weld?
  53. Size of rear wheels ?
  54. Compression Check
  55. What is my buick worth???
  56. 86 Buick GN
  57. pass aircare
  58. 97 cheyanne tranny
  59. 91 Accord...
  60. Cooling Fan Problem
  61. Storing Car
  62. do replacement brake lines exist?
  63. suspension
  64. fuel pump intermittent?
  65. smart car
  66. no back up lights on my S-10
  67. Carb Help
  68. What can you do to make an engine sound weird?
  69. Need EFI info
  70. What happens to car that idles for an extended time?
  71. 66 coronet 500
  72. Please Help!!! I keep cracking CV joints.
  73. dodge neon troubles HELP!
  74. my car acts dead all the time HELP!!!!
  75. Why?
  76. Any Tips on Getting Dirt Out of Plug Holes..?
  77. Tachometers
  78. $5M 70 Cuda to $250M
  79. hood locks?
  80. performance clutch in a 5.7 350...
  81. LT1 head flow
  82. super/turbo combination
  83. muffler
  84. diy wheel alignment?
  85. Turbo kits for 3.4s
  86. 1973 Corvette 454 Big Block 77k miles.
  87. 04 crown vic sport exhaust
  88. 68 Firebird Question
  89. 71 cutlass want to BUY bucket seats
  90. should I clone it or keep it original
  91. Building a 383
  92. chatter?
  93. 2000 nissan frontier xe differential
  94. Oil Light on at Low Idle
  95. boost
  96. I'm building a 442
  97. Proper way to flush
  98. sb 350 mounting?
  99. Car wont start or charge- HELP...
  100. forged or cast iron
  101. Support Our Troops Cruise Night T-Shirts
  102. 1940 ford
  103. I've done everything still won't start
  104. Vehicle Speed Limit Controller
  105. QPower
  106. 71 chevelle a/c to non a/c
  107. hundred spoke rims?
  108. Want to know alot about building up the redline of a 60degree v6
  109. clicking sounds ?
  110. Starting problem related to idiot lights not working?
  111. Just some newb questions
  112. 1973 roadrunner
  113. Vacuum Leak..Or PCV Functioning Correctly..?
  114. Benefits of New Spark Plugs..?
  115. Camry Question
  116. 40 below
  117. Quick startup question Olds 88
  118. 1966 Impala SS
  119. Carb Help
  120. 1968 galaxie 500 convertible for sale
  121. 65 Mustang
  122. tbucket help
  123. Exhaust sound
  124. Radiator
  125. Newbie...Beginner Questions
  126. head gasket on a /95 chev 1/2 ton
  127. 1965 Ford Falcon has to Sale
  128. 40 below
  129. Poly bushings for sale
  130. 95 4.o 5 speed locked in a grear
  131. Mint condition 86 grand national
  132. 70 chevelle SS/ 93 LT1 fuel injected motor
  133. compression ratio..
  134. Hi everyone & this is my first Question in this forum
  135. Can you run an engine backwards.
  136. Outlook for Alternative Fuels
  137. Tools
  138. Ford Aspire Question ?
  139. Silverado broken frame
  140. altitude adjusting
  141. new nitrous sytem
  142. new nitrous oxide
  143. New Engine Smokin !!!!!!!
  144. ***Wanted*** C3 vette w/ 4spd
  145. Tranny trouble
  146. 68-70 charger in or around alabama
  147. 70-81 trans am hurst shifter
  148. overdrive
  149. Mercury Montego
  150. whats the estimated value of pro streeted road runner
  151. Handheld 1/4 & 0-60 times???
  152. non-biased opinions on Amsoil
  153. Overdrive off on matrix, going faster ?
  154. Engine Disassembly
  155. Water in crankcase
  156. Door Glass weatherstripping?
  157. feedback carburater
  158. What exactly is a Clone Car
  159. Internal Size..PCV Hose..? How Big..?
  160. how much abuse can rims handle before getting bent?
  161. Burnout video, sorry if its a repost...
  162. power windows keep opening
  163. 88 Trans An GTA rear brakes
  164. Gran Turismo 4
  165. sleeper engine definition
  166. Disconnecting the fuel lines
  167. distilled or tap water for mixing dex-cool?
  168. Chicago
  169. Alaska roads vs. 2wd Ford van.
  170. FS: Chevy straight 6 in CT
  171. Desktop Dyno
  172. Ignition Timing
  173. V8 swap question
  174. custom lambo door kit?
  175. Engine Tuner's Calculator (using Absolute Pressure and Relative Humidity)
  176. 70 Firebird w/455?
  177. GMC VS. Chevrolet
  178. Electical problems 2
  179. need a direction
  180. The 4A Engine by phat-i (included MODIFYING THE 4AG / 4AGZE)+info
  181. Serious Club
  182. castings #'s
  183. 1974 Dodge Challenger Electrical Problems
  184. 6" Suspension 3" Body Lift
  185. Newbie Question
  186. Octane for street rod
  187. torque converter
  188. 95 Suburban abs question?
  189. synthetic oil
  190. building 1st engine
  191. Car radiator pictures
  192. Looking for something aesthetically similar..
  193. Where can I get info on my transmission?
  194. no head light on my 1991 s10
  195. 360 How Much Power Is Possible
  196. stumped
  197. 1984 firebird for sale
  198. timing question
  199. 95 Chevrolet Z71 heater blower problem
  200. Whats the prices in US?
  201. towncar in need of some horses
  202. i need a supercharger for my 5.0 towncar
  203. Damaged Bolt
  204. question for the experts!!!!!!
  205. Turbo charged sbc
  206. 6.5L diesel chevy fuel pump
  207. 302 Vibration
  208. 4cyl/8cyl..Same Car..Same Power..
  209. New Engine
  210. 318 in a Dart?
  211. toruqe versus acceleration
  212. Nismo new tech to reduce TuRbO lag?
  213. Variable Valve timing by Dave Coleman...
  214. Offroading in Iowa
  215. Please help me Identify 1970 Rallye 350
  216. i need cheap mods!
  217. Vacuum operated exhaust?
  218. Small block chevy install/removal
  219. looking at 4 bolt 350.
  220. Need some help!
  221. Classic car dilemma
  222. having trouble
  223. 2001 Ford Espace spark plug replacement
  224. best transmisson?
  225. Measurements
  226. Oil filter question?
  227. Transmission Identification
  228. Ford Keyless Entry Keypad
  229. WTH Do Oil Filters Come Loose..?
  230. soap mixed with antifreeze: still ok?
  231. 97 Suburban Drive Shaft problem?
  232. 326 Engine/Mr. PBody
  233. simple way to Power up a Natural Aspiration engine.(non V-tec)
  234. car locks
  235. Recommend Performance Shop
  236. throtole body
  237. Replacing a matching distributor
  238. Oil Leakage
  239. 64' Impala
  240. '81 firebird tranny help
  241. How much draw is acceptable? Battery going dead
  242. Timing Belt
  243. General Lee Car Found
  244. towing
  245. I dont know a thing.. I wanna learn
  246. Pi Research/data acquisition
  247. Can someone help me here?
  248. Why use nos?
  249. cv axle
  250. Cylinder Head
