View Full Version : Engineering/ Technical
  1. Battery, alternator or other?
  2. A Contraversial Issue!
  3. Need some advice
  4. twin turbo bseries
  5. hey all
  6. '71 Mustang 302 Coupe: $600
  7. Buick Riviera 1997 Radio
  8. help finding alternator
  9. Oil Gauge Light
  10. Thermal effiency
  11. Turbo for 96 Voyager
  12. Car servicing intervals
  13. Engine Hoists
  14. Could Direct prot fuel injection cure knocking?
  15. new to MOPARS/ have a few questions
  16. Motor swapping help
  17. 1969 amx engine for sale
  18. Cougar Restoration
  19. Buick/Oldsmobile Engines
  20. Theft
  21. 92 BMW Computer chip
  22. improving 0-30mph
  23. Minivan Safety
  24. JDM Valve colors??
  25. Closing the Seatbelt Loophole
  26. Motorized and Non-Motorized Off-Roaders: Respecting the Land and Each Other
  27. Where to buy engines?
  28. 69 or 70
  29. My Assignment
  30. starting problem???
  31. on a budget so wondering if...
  32. fuel injector problems?
  33. F&F
  34. heater
  35. How much
  36. Installing new headunit and 6x9s
  37. Need help wiring pwr wndws to work in both directions.
  38. Please help, car won't start and wife is mad at me!
  39. pontiac stereo
  40. serious problem
  41. I think I found a cheaper alternative to my dream engine...
  42. 1996 Tahoe 5.7 not starting
  43. Car wont start.
  44. check engine - p0141 Bank1 sensor2
  45. Weber 32/36 DGEV tuning for 1.5 ltr
  46. Cheap Speed?
  47. Bucket Seats
  48. I want louder exhaust
  49. Nissan Pickup Wheels
  50. Obd2 Car W/ Obd1 Engine
  51. Question about FI versus Carbs?
  52. Misbehaving Horn
  53. Having problems starting car after swap
  54. need help on my mini-stock engine please
  55. How Do I incorporate gen3 rx7 motor in my truck
  56. I need help with purchasing new rims.
  57. engine runon
  58. your recommendations on first muscle
  59. What mods do i get?
  60. Tranny Problem
  61. Customizing my interior...
  62. New to the Boards!!
  63. Tachometer light
  64. Window went down and I can't get it back up
  65. tuning/reseting ECU after mods?
  66. Valve adjustment & Timing Belt
  67. swapping questions
  68. where to have dyno done?
  69. 1997 venture keyless entry
  70. Arospeed, any good?
  71. anybody know where to get engine mount hex bolts for a 289!?
  72. Beat by an Iroc-z cant let that happen need help!!!
  73. Auto to Standard Trans switch?
  74. sites for buying engines?
  75. swapping questions
  76. The Gift of A Hummer
  77. Caught!
  78. swapping problems
  79. Just Ordered the Edelbrock Performer RPM package from Jegs!
  80. Lowering a S10 Blazer??
  81. What determines the limit of cylinder pressure?
  82. GMC Truck fuel pump burnout
  83. Code Check Connector
  84. Easy upgrades or posiible swaps.
  85. Gauge install. NEED HELP!!!
  86. air conditioning
  87. Need Help With Swap Fast.....!!!!!
  88. Blown Second Gear?!
  89. Engine rebuild kit???
  90. :: Problem, Any Help Appriciated ::
  91. :: Problem, Any help Appriciated ::
  92. Flex Plate
  93. double wishbone vs. struts
  94. Dyno
  95. Tune-up
  96. Pushrod vs. SOHC vs. DOHC
  97. Blew motor, starting mini me!!!
  98. head unit+receiver
  99. Caravan Door locks
  100. Restoring a 1967 AMC Rambler.......
  101. Anyone here an actual Honda tech? 1.5 carb problem I need help with
  102. wtf: from antenna to radio
  103. Astro Idle Problem / Slower acceleration
  104. Engine will not start
  105. When to use high octane gas
  106. Few questions before swapping engines!?
  107. NX kit
  108. 18,000 mile oil change
  109. Need Heater Help
  110. v6 vs. v8
  111. Which Helms manual?
  112. oil on spark plugs
  113. Rear Wheel Drive Conversion
  114. The Thoroughly Modern Minivan
  115. The Marines Go Off-Road and High-Tech With Increased Fuel Economy
  116. SUV Market Becoming More Diverse
  117. Maintance Required light blinking to much
  118. How Screwed Am I?
  119. Charger SRT-10
  120. Your theories
  121. ECU swapping for Performance
  122. Engine Fire
  123. need help
  124. speedo works when it wants???????? plz help!!!
  125. :dunno: Is my clutch going?
  126. best engine build for boost
  127. Bad News....
  128. weight between Stock Engine and JDM B16A SIRII
  129. Flamethrower Kit ?'s
  130. In need of opinions!
  131. pulling out and dropping in engine???
  132. chevy front end
  133. restoration for a profit?
  134. Idle Problems on 99 GMC 4.8L V8
  135. 88 Integra Coolant temp Sensor
  136. a question for the wiring experts...
  137. american muscle vs jap cars
  138. B18c with type r head?
  139. valve seal problem
  140. Ford Tempo Problems
  141. Micro polish crank
  142. looking for salvaged honda frame and body
  143. PocketPC OBD Scanner
  144. engine pictures
  145. Need Help!!!
  146. quick question
  147. need help in understanding english!!!!!!!!!
  148. question re fluid pressures and flow rates...
  149. Would this car run 12s or high 11's?
  150. Ek H22 swap help
  151. b16a vs ls
  152. Help with a B18A component!
  153. Help with gettin power to car
  154. Which engine ??
  155. Whats going on with my shifting?
  156. Where can i find a helms?
  157. how to run a itb setup?
  158. Need some part help ASAP!!!!!
  159. manual ECU convert
  160. My civic is having issues, please help!
  161. fuel pressure adaptor
  162. I Need Help picking out a car
  163. SUV to Get 600 Miles per Tank
  164. running lower oil temps?
  165. Can anyone identify this tool?
  166. Possessed SUV Wiring?
  167. PLease..Help a girl out! Desperate!
  168. What oil should i use???
  169. 93 ranger while driving will die and come bake too life
  170. jdm d15
  171. Propane
  172. 1958 Impala
  173. B16A1 vs. B18C1
  174. Any Tips On The Zc Swap for 88-91 Civics?
  175. 95 GMC air flow from vents
  176. ECU conversion
  177. Where Can I Find.....
  178. Spark problems!
  179. autozone's free diagnostic service
  180. Holley carburetor jetting
  181. transfercase
  182. power to wieght ratio
  183. my 350 keeps dying
  184. street legal rocket
  185. Making My Motor Into Type R?
  186. turbocharged JDM b16a
  187. Broken camshaft
  188. rebuilt engine costs
  189. FS: 2003 Toyota Tundra Access Cab SR5 4x4
  190. ls tranny or Crx si tranny??
  191. Rebuilt Engine vs. Custom Engine
  192. Dazed And Confused
  193. 2.4+ liter B-series motor
  194. Skunk2 Vs. Toda Cams?
  195. V2 intake good?
  196. 68 ford falcon
  197. catastrophic intermed. shaft failure-why?
  198. 98-02 accord 4cylinder vtec question!!!
  199. flywheel ?s
  200. removing the rear seats in honda civic 97
  201. 2 barrel makeover?
  202. Battery Replacement
  203. aftermarket parts and an h22a
  204. Valves springs and retainers.
  205. jdm single cam vtec????
  206. ls/vtec vs b16b
  207. Simple mechanical question
  208. type r engine swap
  209. Oil pump replacement
  210. Engine problem! Help please!
  211. late 70s Trans AM question
  212. low 11's
  213. Still can hear the Vtec,no power lose.but not as lord as be4...
  214. b16 head on a d15 block
  215. how do i dismantl a 92-95 civic ex dashboard?
  216. About H22
  217. Help. Strange problem.
  218. chose engine oil ~?
  219. transmission problem
  220. Noob to muscle cars and i need help.
  221. where do u get high octane gas?
  222. No heat
  223. KYB AGX shock settings????
  224. New Greddy Titanium Exhuast
  225. octane boost?
  226. EGR Valve Help!
  227. TB and throttle question
  228. what's the difference between catback and dual exhaust?
  229. Going Seriously Off-Road -- Around the World For Charity
  230. More on CAFE Reform - A Potential Threat to Minivans
  231. CV boot and Axle replacement help
  232. Towing capacity advice/help for 2003 Dodge Caravan 3.3lt
  233. DOHC Zc Internals..Help!!
  234. distributor cap direction
  235. need part number ?
  236. What exactly is horsepower?
  237. 88 Accord Wont Start Cold
  238. Tuned Up - Now Problems - HELP!!!
  239. d15b/vtec and dx
  240. volkswagen gti motor swap
  241. didn't know where else to post this
  242. problem
  243. a couple inquiries
  244. 2002 Tahoe Fuel Pump Problem
  245. chevy motor
  246. Igniton timing mystery
  247. selling my 1969 Dodge monaco on ebay
  248. B18b1/vtec Vs B20/vtec
  249. Big problem please HELP asap!!!
  250. 92 civic si w/B18B1 motor swap help
