View Full Version : Engineering/ Technical
  1. wanted: early 70's 351c/429
  2. 351 Cleveland and Gas
  3. Intake manifold/vacuum system cleaning tip question
  4. Camshaft Selection
  5. Fathers Day Muscle Car Show
  6. smog
  7. WANTED: 76-79 starfire in CA.
  8. driving lights don't turn off
  9. Needs a fuel filter? no exhaust??
  10. original engine?
  11. 88 monte ss for sale!!! on oahu
  12. stuck oil filter
  13. charging problem. help please
  14. Inconsistent interior lighting, alternator dying sign?
  15. I have 78 Malibu Wagon, Will Sedan Rear Door Fit Properly?
  16. diamagnetic screws
  17. I want Power Windows/Locks for my 78' Malibu. Any help?
  18. 78 d-100 gas tanks
  19. Repressing struts?
  20. FS: 69 Mustang Convertible
  21. anyone have a supercharger for a sbc??????
  22. Tuning?
  23. carb tuning for a jet ski HELP PLEASE
  24. Firebird vs. Thunderbird
  25. 1968 Firebird Question
  26. Pontiacs In The Park at VMP
  27. Pontiacs In The Park!!
  28. Best recommended upgrades for (350 Motor)? *read inside*
  29. Video Ram racing N/A Shootout
  30. New Member.
  31. Air Conditioning question
  32. Welders, tips needed; how to fix a radiator.
  33. Radiator Plumbing, Sorry for starting another thread
  34. is my maro muscle car worthy?
  35. New here, have some dumb questions...
  36. First mod to make to an engine for performance
  37. Tacony Car Show Pictures
  38. engine treatments
  39. Any benefit in leaving automatic car in neutral on the stop lights
  40. Brake pulsation and replacing fluid
  41. To rebuild or to buy already rebuilt...
  42. 351c to 429 swap
  43. Wow there's a lot of CB's at my high school
  44. 19?? Dodge Coronet
  45. want enkei rf-1 17x7 5 lug patern
  46. Drive to reverse when moving
  47. not a car, but still an engine problem
  48. fuel injected flamethrowers
  49. 1966 Ford mustang dash help
  50. oldsmobile 442
  51. Not Synchros, Right?
  52. Cobra For Sale
  53. best minitruck for a bagged project?
  54. chevy bertta
  55. How do you hook up the antenna on this thing?
  56. Electric fan // question...
  57. 69 mustang steering
  58. 73 gran torino
  59. Chevy/GM door/body panel question
  60. Keep your engine running forever?
  61. new seats, maybe something wrong?
  62. Which areas develop the highest air pressure on a car's body?
  63. Drip Trim Opinions?
  64. what carb is reliable streetable and decient
  65. holley carb problem
  66. Anti-rust compound for vehicle's body.
  67. Wheel bearing and hub assembly going... how long will it last?
  68. Engine freeze on start up
  69. did anyone else see...
  70. I guess I'm not the only one!
  71. only a few muscle cars
  72. gap tools and point tools
  73. Mods to increase gas mileage
  74. 4 Bolt Main
  75. Please, somebody tell me the name of this particular part on my accessory belt...
  76. 70 71 72 Cudas
  77. Are Bosch Platinums the Worst?
  78. body damage
  79. remote lock programming 1995 Olds Aurora?
  80. Strut vs. SLA
  81. Can your wheel really fall off because of a bad bearing?
  82. Timing belt vs timing chain
  83. 72' Nova mpg?
  84. '95 Grand Am -- Turn Key and Nothing
  85. Converting the Power Windows
  86. Question about welding
  87. EnGinE SwaP
  88. alternative fuels ideas and questions
  89. a/c line question
  90. WHat is the short squeaking sound when I start by 96 buick up?
  91. Does Restore really work
  92. Dyno Articles
  93. Gallardo Assembly Line Pics
  94. No Clutch!!!
  95. Can I use both terminals on battery ?
  96. Compression Ratio = Gear Ratio??
  97. broken connector
  98. Oil leaking out of speedometer sensor
  99. How long can I drive w/o power steering?
  100. Brake problems
  101. Olds 403 engine troubles
  102. erratic idling on '93 Mercury - cheap soution?
  103. confused voltage readings
  104. Block Identification Number Help
  105. turbo amc twin garretts t3.t4
  106. 351c knock
  107. trans fluid
  108. Is it better to drive at constant of variable rpm?
  109. AN to Inch conversion... anyone have one?
  110. How many miles can you expect out of an american V6?
  111. 351 2v heads on a 400 m
  112. Help Please.. Intermittent Trans Shift Problem..
  113. Which cam and pistons to choose???
  114. Please help, Chevy Celebrity 88 won't start
  115. Suspension design
  116. In general, what things need to be repaired on a car?
  117. Civic won't start 4 days after car washing
  118. Slow vs Fast break in
  119. Plugged EGR Causes Problems
  120. cummins T/D in a 70' charger?
  121. help with dipstick tube
  122. Lift Kit For Lexus Rx300
  123. reading codes without a code reader
  124. th-350 vs. th-400
  125. check out this 2000+ lb-ft dyno run
  126. gtech 1/4 mile, 1/8mile, g's, etc computer?
  127. "Check Engine" - Transmission Question
  128. Anyone who works on his/her own car, I need your help...
  129. Automotive Engineering
  130. How does water not get into an air intake?
  131. what is this?
  132. Lets take it back for a second...
  133. 68 Coronet
  134. fs: autometer Z series gauges
  135. a little history please
  136. Zhe Leaf spring suspension
  137. Borla Mufflers
  138. Brand loyalty- what's your thoughts?
  139. Jack Stands
  140. almost caught fire, electrical help!
  141. Infinity G20 - blower switch not working
  142. Spring is finally here
  143. Differentials
  144. FFW "LIVE" Broadcast Starts Thurs. 4/6
  145. '71 Chevelle Malibu?
  146. No spark. Is it crank sensor, Ignition switch, ESC module, PCM, or EGR?
  147. Minimum Turning Radius (Curb To Curb)
  148. cracked windshield
  149. Benefits for Exhaust temp measurement??
  150. Exhaust Temperature... HELP ME
  151. Automatic Engine Braking (with an auto trans)
  152. need some advice
  153. 65 Fastback help
  154. Change gearing in a FWD
  155. Gm 3.8 Liter V6 New Complete Crate Engine 90-92
  156. Buick Olds 3.3 Liter V6 1991 New Crate Engine
  157. audi and bentley comparo
  158. Gm 4l60e Automatic Transmission Free Shipping
  159. fuel injection cleaner
  160. question on picking carburetor
  161. query surface rust under the battery on LH inner guard on my car
  162. Car does not start completely after gas tank emptied completely. What could it be?
  163. Mopar Magazine Hot Ride Contest!
  164. Ford Mustang Cobra SVT DOHC 4.6L Engine Assembly
  165. Chevrolet Ls2 6.0 Liter 400hp New Crate Engine
  166. Camaro 350 SB is dying after 45 seconds - due to Edelbrock carb needing adjustment?
  167. 2 fast 2 furious begining
  168. white exhaust
  169. Support Our Troops Cruise April 30th
  170. Remote cartridge oil filters on transmission?
  171. R-134a compatability
  172. relieving fuel pressure
  173. Replacing BALL JOINT 96 Buick. Which TOOLS NEEDED?
  174. 71 nova... good deal?
  175. HELP! I put diesel in my gasoline engine
  176. Suggestions needed: HOW TO FILL AC Guide
  177. New Hampshire vendors are welcome.
  178. crankshaft balancing
  179. Great Muscle Car Story!
  180. Firebird Cadi swap
  181. Porting head gasket...
  182. help in fuel pump selection
  183. Electric Supercharger ?
  184. Audi: Showing them how it's done.
  185. 2000 Chevy k2500... no dim headlights
  186. Need some help on project car.
  187. HElp w/ 96 Ciera
  188. 72 1/2 chevelle
  189. Homemade Transmission Flush Machine
  190. What is the different betweent BHP and HP?
  191. 93 pontiac ssei supercharger
  192. W&H DuCoil Distributer
  193. Ghetto Testing for a Bad Alternator
  194. ignition coil?
  195. drum brakes
  196. storing a vehicle
  197. wire harness
  198. Another One: Engine Wont Start!
  199. light problems
  200. haven't started 95 camaro in 6 months
  201. WOT Good?
  202. 1972 Chevelle SS 402 Matching Numbers 4-Speed
  203. Engine Won't Start (HARD ONE!)
  204. OBD- II / P0744 Torque Converter Clutch Circuit Intermittent, what does this mean?
  205. remenicent of the boss
  206. could use some pointers for learning about cars
  207. What the crap?
  208. bov's
  209. mutant olds/pontiac
  210. mutant pontiac
  211. Best books to learn...
  212. do u have a 63 plymouth
  213. do u have a 63 plymouth
  214. do u have a 63 plymouth
  215. Bad fuel pump
  216. Invader Tires?
  217. Parking Sensors. Are they any good?
  218. Good to car in NETURAL while braking
  219. Slow down rust?
  220. Dirty Throttle Body equals poor acceleration?
  221. Product that i would suggest for carbs
  222. Auto-stick transmission question
  223. Interference/Noninterference Engines
  224. 1972 Chevy NOVA with SS Options: See Web Link!!!
  225. Need some help Satellite/RoadRunner 71/72
  226. WANTED - 71/72 Satilite car parts
  227. The Tornado
  228. Repair Quesiton
  229. 65 carburetor swap..
  230. 1976 sting ray for sale
  231. TH400 weak links
  232. signal/indicator fault
  233. 39 chevy help
  234. Belt Tensioner problem
  235. ford ranger
  236. New Video Show!!!!!!!!
  237. Diahatsu Fourtrak 4x4 help!
  238. Different oil treatments?
  239. gear drive
  240. Always properly diagnose the problem before...
  241. Please help me with 350 questions!
  242. 71 mustang spark plugs
  243. Removing Mufflers - Hp
  244. Old drag picture
  245. GTO restoration
  246. Engine diagnostics in 2000 GTP
  247. Aluminum Driveshafts????
  248. Coolant leak - mechanic changed out block-heater. Sound right to you?
  249. Quicker starts? Help
  250. 87 Escort idling high, running rough
