View Full Version : Engineering/ Technical
  1. what engine should i put in my nova
  2. Minivans with collapsable seats
  3. Yukon randomly doesn't start, just clicks
  4. 1997 ram, bogging and accelerating problem
  5. Looking for tips for a first time restoration
  6. Neon engine problems
  7. Fiero wiring Question
  8. '98 Saturn And '89 Blazer Questions
  9. Question about the electric car and its engine.
  10. So is there a difference between a plymouth roadrunner and a...?
  11. more power
  12. sway bars
  13. How to: Testing for malfunctioning parts
  14. creative or crazy
  15. Is a 1973 plymouth sattelite sebring plus considered a muscle car?
  16. What is better front wheel drive or rear wheel drive?
  17. Car runs till out of gas.
  18. 80 cutty 5 spd
  19. Motor Mounts. Pontiac vs. Olds
  20. convert all wheel drive to a 2 wheel dive
  21. ? radiator fit 1973 javelin
  22. Low oil pressure when stopped.
  23. Need some assistance.
  24. Suspension Composites
  25. Pontiac Engine Smokes...after shifting gears
  26. ECM Tuning
  27. Left Turn Signal Doesn't Work Intermittently
  28. Replaced engine broken spedometer/odometer
  29. question on chevelle frames
  30. Car shakes and dies...when stopped
  31. lightest muscle car and the most powerful stock engine
  32. Alternator ratings...
  33. Automatic to Manual...How Much???
  34. Brake Maintenance Questions
  35. how to calculate efficiency of an air/air intercooler?
  36. Calipers stuck closed...
  37. 73 Ventura 455 Swap
  38. ABS pump will not stop running
  39. looking for a 4 speed for my nova
  40. wanting a good 4 speed saganaw or muncie
  41. 66 mustang for sell
  42. 350 010 casting # for sell
  43. 66 mustang for sell
  44. 350 010 casting # for sell
  45. AEM EMS Standalone, experts needed.
  46. Daihatsu Charade specs
  47. Jet Performance Chips.
  48. Battery not charging at times.
  49. Help with a Seat Cordoba
  50. Mustang is a Muscle car
  51. 98 exp elec.motor or bad bearing sound
  52. Engine Additives That Work??
  53. wanted
  54. Electrical System Disaster
  55. rb25det in fc rx7
  56. what tranny for blown chevy 454
  57. Synthetic Oil vs Natural Oil (Read Post before voting please!)
  58. Pictures, Support Our Troops Cruise Phila. 4/21/07
  59. Taurus towing capacity
  60. Battery Help
  61. Emmissions laws
  62. need help with digital odometer adjust mileage
  63. all original 1969 hemi super bee
  64. Rd. Const. For Support Our Troops Cruise Phila. 4/21
  65. Speed Limiter
  66. Some Pleasant Driving
  67. quickest and cheapest way to make HP in a 350
  68. looking for parts on my 71 yenko clone
  69. 350 with 327 heads please help
  70. taurus stumble?
  71. Octane Booster?
  72. head gaskets
  73. Ram Air Pontiac 400 questions
  74. 98 caravan. 3.0L, flashing indicator
  75. Issues with Lumina
  76. what would be
  77. Straight pipe instead of new CAT
  78. Car Suspension Question: need answers quick
  79. Mercedes 307D
  80. Symptoms of bad O2 Sensor
  81. modified intakes (Air Filters)
  82. aero turbine? hks? exhaust mufflers...
  83. Shmastigage???
  84. Need Help Identifying a Big Block
  85. Pennzoil a rip off?
  86. 1996 Hyundai Elantra Engine Rattling
  87. N20 Purge?
  88. 1994 Explorer 4 wheel drive problem
  89. GM 3800 supercharged V6
  90. NAPA guide for labour hours.
  91. 79 Trans Am
  92. please help, turn signal not working
  93. 1987 Buick LeSabre Refuses to Start
  94. '88 delta 88 engine identification
  95. Exhaust Manifold Materials
  96. Performance Chip
  97. I Have To Many Remote, Just Want One.
  98. tomos targa lx supercharger???
  99. 1999 gmc 1500 intermittent stalling??HELP!!
  100. old terd
  101. Hickup Truck !!!!
  102. Headlights/Dashlights just went out?!?
  103. Shaking
  104. chevelle
  105. life of tpms sensor?
  106. tomos targa lx supercharger???
  107. engine condition
  108. NSCA Columbus April 28th-29th
  109. Is it possible...
  110. Bearing Issues/Engine Rebuild
  111. One More Question...
  112. (People that) dont know anything
  113. How many amps is too much?
  114. Chevelle 67 SS 427 keeps cutting out
  115. 1968 Ford Torino: Over heating too fast?
  116. Carburetor Nozzle For Robot
  117. project laurel
  118. New Musclehead
  119. Wrong engine block?
  120. Banks Kit (Diesel)
  121. Ram 3500 repaired water in oil-but now overheating
  122. 350 chev timing problem
  123. engine swap: 4.3l v-6 into a Chevette
  124. V8 conversion
  125. 97 Pontiac Grand Prix Engine Failure after dealer replaced intake manifold gasket.
  126. 1998 ford winstar
  127. running lean
  128. 2.0 Jetta Timing Belt?? Cam Position Sensor code.. And car wont start!! Help!!
  129. 96 Jetta 2.0L GL WONT STARt. Has Spark Has Fuel Pressure. Just died while idling.
  130. '83 Olds Toronado brake problems
  131. what mods do you have to your rb20det motor
  132. 01 blazer service light came on
  133. Stingray vette Big Block swap HELP !!!!!!!!
  134. Steering gear HELP
  135. Having an issue with my passenger door
  136. Rodent chewed injector leads: misfire after repair
  137. carb. problem
  138. Coolant in oil. What are the odds...
  139. Motor/Engine Sim
  140. Oxygen sensors.. Can you use any O2 sensor for any vehicle?
  141. 12v PLC.
  142. Computer integration ?
  143. car won't start and makes clicking noise
  144. Smog Problems! (Someone Plz Help me!)
  145. The Bourke/VBL(modern modified Bourke stlye) engine
  146. grand caravan 2000 window problem
  147. software
  148. need help
  149. Swapping 3.8 Impala Engine for ?????
  150. Di-Electric vs Electric Grease
  151. 93 Dynasty running rich!!! Help!
  152. Corroded Wire To Computer...Price?
  153. trade custom chopper for muscle car
  154. Check out this Ford police car.
  155. transmission?
  156. MSD spark problem
  157. Where are outdoor temp sensors mounted?
  158. Where can I find a bolt-on four-link with coilovers
  159. electrical
  160. JDM/EDM hybrid project
  161. 97 tahoe aftermarket lights not working
  162. Power required by standard alternator fan?
  163. destroking a 350....
  164. what is this part call?
  165. Transmission fluid issue
  166. Anyone heard of a company called ITM?
  167. Blue 350 engine block in 70 camaro. where's it from?
  168. 92 Eagle Summit wheel wobble videos [YouTube]
  169. Transmission Fluid.... Is it true???
  170. 97 Taurus overheating
  171. Tuning help
  172. battery vapors???
  173. Is This Product A Con... Mpg Cap
  174. can't decide...
  175. 99’ Tahoe with non-stock tires needs a fix for rear break wear and other problems!!!
  176. 99’ Tahoe with non-stock tires needs a fix for rear break wear and other problems!!!
  177. Lift support cross reference
  178. Shaking and Stutterting Problem
  179. do they work or not? electricchargers
  180. 1992 brake light trouble
  181. 4cyl diesel leaking oil help!
  182. Cigarette Lighter Help
  183. Cr6hs
  184. Emergency brake emergency
  185. squire universal turbo kits
  186. OBD2 / canbus
  187. Charging systems
  188. 92 Eagle Summit Steering link questions [pics]
  189. relay location
  190. How to check dampers?
  191. rubber cement in engine oil
  192. 1991 Chevy Corsica 2.2l
  193. What Engine Will Fit My 95 Cadillac Concourse??????
  194. Accidently dropped to 1st on hwy
  195. AntiStatic Strap
  196. Charging Laptop in car - battery life
  197. It sounds like.....coconuts.....
  198. 88 Buick LeSabre Ignition Control Module? HELP!
  199. Lumina APV fuel pump problem
  200. Program your keyless remote
  201. 2004 silverado and want to use 31x12.50 what do I do?
  202. dashlights out...
  203. Tire Changing Machines
  204. What's wrong with my car?
  205. Ac R-12 To 134a Conversion
  206. Uni-body homemade convertible?
  207. Impossible engine swap??
  208. 2-stroke turbo= Deisel or gas, cvt constant engine RP
  209. Getting Low MPG
  210. 1982 Ford Mustang Gt 302HO 4 speed value...
  211. 98 Dodge Grand Caravan almost stolen
  212. 96 Voyager with TCC solenoid Code
  213. Question About " Open Loop "
  214. Scratch built headliner
  215. Engine swap help
  216. Deutz Engine Screensaver
  217. STP Multi-Valve Cleaner ~ Help !
  218. Infrared system?
  219. 03 Monte Calro SS - Traction Control/ABS
  220. How to make wiper delay switch
  221. How the engine can be heated in winter
  222. Oil leakage and car not starting
  223. fuel system problem
  224. I got a CB now i need to hook it up
  225. distributor wiring
  226. what do you do if you put jp8 in a car?
  227. How to know what wheels to buy to widen stance?
  228. lt5
  229. thnx mr p
  230. difference in 427 truck motor and car motor
  231. Please help: 327 bored .060 over
  232. Supercharging
  233. Help needed please.
  234. Ignition problem
  235. Pay for entry-level tire technicians....
  236. What is Race Engineering?
  237. Engineers and Engineering Technologists?
  238. T56 for Muncie question, help
  239. Painting a car in the cold
  240. Windshield wipers not working, blowing fuses
  241. v6 engine ?
  242. rust holes
  243. 12/97 pontiac relearn difficulty
  244. Oiling Head Bolts
  245. Getting Bad MPG
  246. cougar lower front arms
  247. Pre-oilrs/chargers etc.
  248. Car sounds! what is wrong with my engine?
  249. What would I need to Fuel inject and twin turbocharge a Chevy 350 (1970)
  250. locking lug nuts
