View Full Version : Engineering/ Technical
  1. 66-67 LeMans VS 68-70 Roadrunners
  2. 77 T/A 403 Perfomance upgrades
  3. dash light
  4. headlight wiring help
  5. Need help with a seat swap
  6. Need help with a Nova to Camaro Seat swap
  7. Bb
  8. LT1 vs LS1
  9. Help Making Scoop functional
  10. 3.8L Olds backfireing
  11. Difficulties with Valve Adjustment
  12. Battery died?
  13. selling 68' mustang
  14. Looking for 50's truck
  15. 1969 Chevy Caprice Parts needed ...
  16. Greetings all!
  17. 1974 Challenger??
  18. how to build an awesome LT1??
  19. Just aquired a '66 C10 Chevy truck.....
  20. Maintenence on Mustang
  21. tail-lights out, brake lights work
  22. engine removal
  23. VOLT Gauge Lowers in Reverse..?
  24. towing and your odometer
  25. Heater Works But No Defrost
  26. Lookin' for a Muscle Car Show in LA
  27. custom intake manifold
  28. how to clean up edelbrock manifold
  29. 2005 Charger????
  30. diamond plate tool box 4 sale
  31. FS: 1993 Supercharged Camaro Z28 - Indy Pace Car edition
  32. Whats the fastest
  33. 3.23 ratio rear axle assy for sale
  34. 1996 Firebird Formula Conv. $7500.00
  35. car shakes back and forth please help
  36. Help! Spark plugs fouling
  37. Lights don't work
  38. TIG Welding 4130 (Chrome-Moly)
  39. Built an Oil Pan what should I Coat/Paint it with?
  40. 700R4 Assembly Help
  41. Nissan V6 engine runs fine until 2800 RPMs
  42. 66-67 LeMans??
  43. '89 Suburban door panel
  44. hot wiring to start van
  45. car problem
  46. corvette killer??
  47. engineering
  48. '90 Chevy 2500. No reverse lights. Where is Backup light switch?
  49. performance gaskets?
  50. 1992 dodge caravan braking question
  51. Think I used the wrong kind of RTV
  52. ticking
  53. something draining the battery
  54. looking for a cheap amx 74 javelin
  55. What to do with a vin tag and title
  56. 1969 dodge charger 440 rt
  57. 1974 amx javelin, I need parts or will sell
  58. Which One Is Better?
  59. Looking for a Dream-HELP?
  60. do u know
  61. aint this sumthin
  62. how to clean deck surface for head install...
  63. 77 T/A Olds 403 heads swap smaller 350 heads
  64. 77 T/A Olds 403 heads 305 heads
  65. 77 T/A 403 Heads
  66. Olds Cutlass Supreme 1969
  67. Will This Cause Problems..
  68. Quick fix? Or am I an idiot?
  69. No start (no spark)
  70. Car just stalls at stop lights; turns RIGHT back on
  71. How much can I?
  72. 93 Grand Am
  73. Engine worries.
  74. windstar transmission- RPM sensor
  75. Replacing Standard Breaks with ABS Brakes?
  76. 66 Ford Mustang Convertible 64k orig. miles $14995
  77. 180 crankshaft
  78. Wipers frozen, motor broken?
  79. For Sale or Trade???? 1970 Pontiac T-37 Lemans Looks like the GTO Judge
  80. GM aluminum intake manifold
  81. 1974 Chevy Truck
  82. Picks of your trucks!
  83. how to install a tach and misc??
  84. Steering Column
  85. 72 chevelle
  86. re-painting
  87. leafspring problems
  88. bedliner
  89. Spun Head off Bolt, need HELP!!!
  90. 1971 Mustang "C" or "J" Code Rolling Chassis wanted
  91. Fast Yenko??
  92. ABS Problems..
  93. What exactly happened
  94. Radiator Fan Smoking...OH NO..!!
  95. check this out ! ! !
  96. 2001 Ford Windstar Oil In Throttle Body
  97. 2003 Silverado Leans To The Left
  98. camshaft qwestion
  99. pin out for checking error codes?
  100. 1997 Dodge Ram 1500 won't start
  101. Mr2 turbo comparsion
  102. How Much HP Are These Mods Good For..?
  103. Help moving a dead car
  104. '93 s10 help please!!!!
  105. need to rent a hummer for one night
  106. 1979 HO Assembly Manual... Help
  107. chevy Lug pattern
  108. How does a auto lift works?
  109. Starting Problems 94 S10 Blazer 4x4
  110. 1994 SHO Ford Taurus
  111. HELP!!!Battery Install Mistake
  112. 1990 Dodge Daytona For Sale
  113. carb question
  114. rear end
  115. The car dies when I put in gear??
  116. Air Brushing: Complete Kit for Newbie?
  117. 4T60E model & type identification
  118. auto artist Danny Whitfield paints a ......
  119. Trans Am?
  120. pontiac trans-am ws6 mods
  121. Links..Autoparts etc..? Help...
  122. selling 66 chevelle 454
  123. 2 wd s 10 bucks like its in 4x4 when cold
  124. MrPbody can you Identify this seat?
  125. mercury sable airbag problem
  126. 75 Gremlin going from 6 to 8
  127. Best way to hook up light?
  128. 1972 chevy nova
  129. 1972 nova
  130. Couple car questions, please help
  131. Mass Air Sensor..I need Help, Urgent..
  132. 97 Chevy S-10 4.3 X
  133. Maxlife question.. please reply.
  134. Car not starting after rain/cold
  135. How to verify airbags? P.S. BUCKLE UP!
  136. forgotten muscle
  137. rust n paint, 76 nova
  138. Intake Manifold
  139. Transmission Flush
  140. Info about 70 GS455 St1 Conv
  141. I busted something!
  142. need 350 with tranny
  143. mototube vs twin tube dampers
  144. State Investigator Unleashes 15 Violations Upon 4 Wheel Parts
  145. how can i know if i have a windsor or cleveland
  146. A question from a person with absolutly no knowledge of cars whatsoever. . .
  147. electrical help
  148. WTB: '66-'69 Pontiac Beaumont
  149. twin engine AWD car
  150. question about how shops do this....
  151. exhaust suggestions
  152. Heads needed for sbc
  153. Chopped Muffler/Illegal..?
  154. Highest Miles
  155. Philly's Best Cruise Night To Support Our Troops
  156. EZ Lube Left Plug Off My Tank After Oil Change
  157. Mark Donahue Javelin
  158. The Rocket 88 was one of the first "Muscle cars"
  159. Point me in the right direction
  160. "69" 722 trans am heads
  161. 1992 Ford Ranger
  162. New to the scene
  163. Big Block conversion for 1995 Totyota Supra
  164. need help
  165. Help. Flooding
  166. Is It Ok to Speed Up An Idle.?
  167. Help..Check engine light, how to shut..?
  168. 1997 GMC Jimmy Transmission Problem
  169. 350 w/ 6/71 blower
  170. MOUNTING 13b ROTARY ENGINE IN A 98 HYUNDAI EXCEL HATCHBACK BOOT/TRUNK??????????????
  171. Engine tags
  172. '68 firebird fenders f/s
  173. Project Time!
  174. I need some intake piping.
  175. ladder bars
  176. Rocker Arms... a good upgrade?.
  177. High miles oil? Frequency of changes?
  178. 70 Olds "No Spark"
  179. Short Ram
  180. What is a cat-back exhast?
  181. 1990 chevy EFI 1500 305 cheynne
  182. engine building, anyone?
  183. boss302
  184. 3 engine performance mods for stock 98 Hyundai Excel to get the most bang 4 my buck?
  185. High Performance help......please.
  186. temp gauge chevy s-10
  187. Liters to ci conversion
  188. 70 Chevelle Lock cylinder
  189. Fuel octane learn it.
  190. missing
  191. stalling problem
  192. Hurst Wheels
  193. 01 Dodge 2500 electrical problem
  194. Advice on changing EGR valve 01 Tahoe
  195. 75 Gran Sport
  196. whats APC's website? also what should i do to a b2200?
  197. Montero vs Trooper vs Explorer-buying used
  198. Road Runner Pic!
  199. jeep idles fine then idles way down help
  200. maverick engines
  201. 1990 grand am wont turn over
  202. How high can you rev
  203. 1974 Ford F-100 Bolt Pattern
  204. changed vacuum advance now 425 wont start
  205. Anybody ever rebuild a turbo???
  206. Synthetic and Regular..Which..? 127k miles, Recomendations??
  207. Painting
  208. Heater = Engine Cool?
  209. For people who know their sh&*
  210. 1996 for taurus
  211. American and european cars
  212. castrol GTX
  213. will these 2.4 quads interchange? look here please
  214. 1967 stingray
  215. Need More Help On Remote Starter
  216. How to find and disarm factory alarm
  217. Totally stumped with startup issue
  218. L-ROC 350 in older GM
  219. compression
  220. Winter Startup?
  221. viper alarm system
  222. Honda's H22A Engine - US vs Japan
  223. Airbag OBD Codes
  224. Old 1972 Galant
  225. replacing intermediate shaft on silverado
  226. automotive paint survey
  227. gear ratios
  228. Vacuum Lines
  229. Finding the right wire for remote start
  230. ABS wheel speed sensor
  231. Muscle Car Concepts
  232. difficulty
  233. 78 Camaro
  234. Front Wheel Drive Transmissions
  235. Safest way to thaw a battery?
  236. Tranny
  237. Info on hook up remote starter on 99 tahoe
  238. 401
  239. turbo kit
  240. tubo kit
  241. New Project Cougar
  242. Plug a Tire (damn screws) Properly..How..?
  243. Help finding some parts.
  244. WOT engine life?
  245. 2 Questions..
  246. 2001 Z24 Cavalier Hesitation
  247. Cam Sensor Issues
  248. throttle position sensor
  249. 1969 Cougar with Targa Top ???
  250. turbo kit
