What can I use on the Si ?
sparq
01-08-2002, 06:45 PM
So heres the low down...
I will have access to free, or at least CHEAP Si parts from someone that is buying a swap off me. He has a 93 Si and asked if I wanted any of it. Heres what I was looking at getting
Intake Manifold
Head
Header
ECU + VTEC solenoid
Will that be everything I need to drop the head and what not onto my block? Or will I also need the Si wiring harness (I thought I heard some place that the wires are already there for VTEC you just gotta have the ECU and solenoid to make it work... or will I need the wire harness? Just looking for a fun little project ~ sounds fund if yah ask me :) *grins* what does anyone know about this?
Intake Manifold
Head
Header
ECU + VTEC solenoid
praxis
01-08-2002, 09:40 PM
The wiring is NOT wired from the fender to the ECU. I don't believe that the harness (from the D15) has the vtec wire, either. If you get the head... it should include the solenoid and everything that you need (except for wiring). SOMEONE HELP ME OUT HERE: I think that you need to tap into the block or something to move oil to the spool valve? I think that you will also want the ECU.
What year Si head? I would recommend the same generation.
sparq
01-08-2002, 10:13 PM
Hahaha, well it would be sorta hard to drop a B series head onto a D series block. Its the same generation, both vehicles are 1993... :)
pvang31019
01-09-2002, 01:28 AM
since he's swapping, just take the whole motor+tranny. The head won't be worth it without the tranny(trust me)....as for the vtec wiring, only 1992 came with the vtec already wired up...
sparq
01-09-2002, 03:25 PM
Ahhhh fugg it, I think im just going to use the little cash I do have and go down to the bank and use the car as collateral and get a loan for my swap... but that means im probably going to be down here for another 2 months, Beth wouldnt like that :( ahhh, oh well maybe I will just work on all the other little goodies on the inside and what not... oh poo! Well the thought was nice I guess :rolleyes:
Rice-Rocketeer
01-09-2002, 03:44 PM
I summed it up in my email bro. DON'T STRAY TO THE DARK SIDE YOUNG ONE!!!
