View Full Version : Engineering/ Technical
  1. Hondata and Turbos
  2. HP Without Dyno
  3. Specs
  4. b16a or NOT????
  5. comp cam???
  6. battery seems dead?? help
  7. Very odd engine problem..need help
  8. 95 CX HAtch Swap
  9. DIY Exhaust?
  10. bad coil?
  11. Horsepower Question
  12. Tranny Question?
  13. B18c into my EF civic HELP????
  14. AEM V2 intake installation
  15. AEM CAI for Accord 1997
  16. Shame on Mugen!
  17. timing belt help
  18. What b16 Cable tranny has the shortest gear ratios? Where can I find one?
  19. W-30 ?
  20. motor swap
  21. Type R
  22. f22a1 swap
  23. f22a1 swap
  24. swaping in to my civic
  25. first car
  26. Big brake/rotor kit install help
  27. General shifting question...
  28. spark plugs
  29. Squeeking noise when I shift in low gears?
  30. engine care
  31. accord engine type
  32. New here just saying hello
  33. wastegates and BOV's
  34. B18c1
  35. custom return line or not??????
  36. Altenator for home power!
  37. My Type-R
  38. High performance crate motors?
  39. Best Car Movie
  40. Best Muscle Car Song
  41. Type-R ITR tranny....
  42. speedo problem
  43. TSB's
  44. head gasket....?
  45. Differences are between chevelle ss and a nova ss?
  46. Difference between a Chevelle and Nova?
  47. about getting Sponsored
  48. Ricochet! B16B Q
  49. drifting in a acura and d1!!!!it was asowme
  50. b16a2 and V-AFC
  51. b16 swap into 6g
  52. '66 barracuda
  53. teach me about the B series motors...
  54. how to install new xenon bulbs
  55. 99 Civic EX Swap
  56. What is milling your head?
  57. What is the difference between boring and stroking a motor?
  58. Best Tranny for Ls-Vtec???
  59. I want a faster Civic for daily driving!
  60. V12 @ 8500 Rpm ???
  61. Electronics on the brink!
  62. Oil Filter!
  63. #--- Help I Need Air ---#
  64. can I do anything with this?
  65. HELP! Clutch Pedal won't come back up.
  66. shop swap rates
  67. powerful engine
  68. jdm d15b sohc vtec
  69. Jdm Motors And Accesories For Sale
  70. i am wanting to do an engine swap onmy 92 civic please help me out
  71. d16z6 swap info needed!
  72. reading ecu codes
  73. Whats wrong with my car?!
  74. auto to manual
  75. b16a valvve job
  76. ZC timing belt question
  77. Speedometer Fuse????
  78. Starter bad?
  79. 1991 Acura Integra RS - Starting Problem
  80. engine reinforcement
  81. Exhaust
  82. 94 Blazer 5.7 Missing and Hesitates when Excellerating
  83. is it possible to put a turbo and supercharger under one hood
  84. is it possible to put a turbo and supercharger under one hood
  85. More Power???
  86. Vtec Controller???
  87. 92-95 2door civic H22A conversion / need experienced comments
  88. Engine Mods
  89. how to adjust shifting cable
  90. Is it possible to convert from carb to fuel injection?
  91. ls 1/4 mile help?
  92. Cheap muscle cars
  93. Turbo Stock LS or B16a2 LS/Vtec
  94. Engine Weights...Effecting handling?
  95. timing belt
  96. Change Manual Tranny Fluid on B Series
  97. dc header question please HELP!!!
  98. Hardwireing a Passport 8500.....
  99. Knocking (Rod knock?)
  100. acura distributor
  101. Raising Redline
  102. B18C1 in crx
  103. how to install cold air intake 98 civic ex
  104. ODB2 conversion to ODB1
  105. b16b
  106. Civic Speaker Rewiring
  107. corner lights!
  108. OBD II or OBD I
  109. synthetic oil
  110. I Feel Power Loss!!!!
  111. prelude digital climate control
  112. zc question
  113. timing belt
  114. help me with a tranny swap
  115. JDM B16A or USDM B18C1
  116. engine all loud when cold
  117. O2 simulator Question?????
  118. battery question
  119. exhaust question
  120. Whats the best classic 2 restore?
  121. head gasket
  122. VTEC problem!!
  123. LS/Vtec Really that good?
  124. I-Vtec vs Vtec, compare and contrast
  125. anyone with b16a jdm help!!!!!!!!!
  126. Honda 2000 EX
  127. o.k. its a dumb question, but help
  128. Refurbish
  129. ringing noise???
  130. ATTS indicator light (on your gauges)
  131. I think I have been dupped ?
  132. Grim Tranny Reaper (repair)
  133. 1994 S-10 pickup running rough
  134. best of the basics help
  135. tailgate locking mechanism problems
  136. engineering software
  137. Anyone ever seen this? Oil filter??
  138. gsr parts bolt to b20crv?
  139. crvtec or ls/vtec
  140. f22 exhaust
  141. white smoke???
  142. VTEC or not??
  143. Idle Fluctuation
  144. OZ Wheels - Cast or Forged?
  145. Please help! Whats crankshaft Horsepower?
  146. Missing Vacuum Hose
  147. Oil Tac gone crazy
  148. 2000 Civic EX Swap!?
  149. "Technical" learning websites?
  150. idle revving problem, mpfi swap ...
  151. why the swap?
  152. engine/tranny conversion
  153. How to fix an Evaporative Emission Control System Malfunction - OBD II Code P0440??
  154. Is this swap really as good as it sounds?
  155. Swapping a RB26DETT into a 92-96 Prelude
  156. r12 to 134a conversion
  157. 90 Si wireharness/ radiowires
  158. grrrrrrrrrrrrrrrrrr
  159. muscle car top speed
  160. how much did your swap cost?
  161. please help! ignition issues. (reposted w/edits)
  162. how to get maximum HP from a stock d16 engine (decided not to swap)
  163. Engine Build-up
  164. what is next?
  165. 1991 Ford Escort Fuel Cutoff Help!
  166. Electrical issues, bad ground? loose connection?
  167. how do you like to shift?
  168. question on pulleys
  169. Best susp. set up for front wheel drive cars?
  170. TA sensor?
  171. 99 civic swap question!!!!!!!HELP PLEASE
  172. JET VFORCE PCM do they work?
  173. b-series technical articles
  174. alternator question
  175. My Micra wont start.. any ideas??
  176. Best head for an LS/VTEC?
  177. Lister Storm
  178. Possible Warped Disc?
  179. Accord engine swap
  180. Cold as ice?
  181. B16A2 engine swap into 94civic
  182. Gas in Oil
  183. Honda Civic Exhuast
  184. Car wouldn't run fast enough to pass emissions test...HELP
  185. Coupe V6 exhaust...how restrictive?
  186. Engine swap for a 97 civic hb.
  187. need an h23
  188. Tranny Question....
  189. JDMeet in San Diego (Balboa Park) Sept 14th @ 2pm
  190. usdm b18c1 vs jdm b16a2
  191. I need help starting car
  192. Got problem with radiator fan integra 1988
  193. i have a few newbie questions
  194. idle problem help~~~!!!!
  195. brake lights out
  196. 4d4g civic engine swap in dc/md area
  197. This is a JDM forum!
  198. dropped nut in oil pan
  199. hurting dx
  200. Big vs. small V8s
  201. 89 Honda Civic Trunk won't close...suggestions on fixing it?
  202. can i get some help?!
  203. fiberglass
  204. Any Referees for motor swaps out there???
  205. Sanding/Primering Your Car?
  206. will this throttle body work?
  207. caddy probs and some ?s
  208. Trans am engine swap
  209. b16 Sir1 codes?
  210. Cold Air Induction and MPG
  211. Valiants
  212. 94 civic, which swap would be best for me?
  213. jspec b16a legal pass smog?
  214. Manual transmission/shifting question
  215. Car has dead cylinder, but still has fuel, spark and great compression????
  216. JDM EF8 Legal?
  217. 1999 Honda Civic EX
  218. jdm sir 1 gen info
  219. E-Manage from Greddy....
  220. How Do I Test My Brake Light Switch?
  221. 84 carb to 87 fuel injection swap
  222. 5 lug conversion???
  223. Have You Seen This 1970 Impala?
  224. Engine weights
  225. NZ Civic Trans Swap
  226. Oldsmobile 3.5L twin OHC
  227. what could be the problem?
  228. Oiling Problems
  229. ECU Question
  230. Which model of spark plug is the best for integra GS (B18B1)?
  231. Which model of spark plug is the best for integra GS (B18B1)?
  232. Looking for a JDM ITR front end!
  233. bomz header
  234. D16Y8 issues
  235. Synthetic in a never synthetic car
  236. H22 in a 92 Accord
  237. P08
  238. best turbo kit for d16z6
  239. JDM B16 Osakajdmmotors.com
  240. How much is this car worth?? Look@@
  241. converting from auto to standard
  242. changing from auto to standard
  243. Strong like bull
  244. The Letter Cars
  245. integra gsr or prelude si
  246. parting out a 79 firebird
  247. Oil dipstick tube question
  248. 2000 Sunfire --> engine keeps cutting out
  249. 2003 Accord Coupe - Dual Exhuast on the I4?
  250. torque
