View Full Version : Engineering/ Technical
  1. starter motors...
  2. 69 cuda for sale
  3. Getting a misfire error code
  4. butterfly valved street scoops?
  5. Transmission failure '97 Chevy venture
  6. Electrical question.
  7. help with ID on old Cutlass
  8. GM 3800 v6 RWD tranny compatability
  9. Testing shocks
  10. Help!! Car overheated!!
  11. intake valves hitting piston on stroker motor need help
  12. If excess CO2 from cars is such a problem....
  13. Diagnosis Needed - Oldsmobile Fouling Out
  14. Mustang left in the cold for three years
  15. I've got a serious draining problem!
  16. front and back quarter panels
  17. Coolant Blockoff?
  18. Rocket 350 vs. regular 350 - Whats the difference?
  19. 1988 monte carlo luxury sport
  20. 70 chevelle ss transmission lines
  21. Old Crower Mileage Kit
  22. 302 performance
  23. numbers question
  24. numbers question
  25. Help w/gauges in 66 mustang
  26. motor balancing
  27. charger info
  28. $50000, 3,000hp, 32 cylinders.
  29. Structural damage
  30. this is unbeliveable
  31. want to learn how to do a leakdown test
  32. Live Racing From Las Vegas!!!!!!!!
  33. New Firebird hood!
  34. 1969 #5 Head Rebuild
  35. Choosing a project title
  36. Problem With Fuel Pump?
  37. Rebuilding the Heads.
  38. 1995 grandprix gt 3.4/1992 lumina 3.4
  39. My battery won't charge?
  40. 1977 Formula
  41. RB26DETT Swap
  42. 86 honda
  43. 1972 Chevy NOVA with SS Goodies
  44. 1972 Pontiac LeMans 70K Original Miles Very Clean
  45. New Motor New Problems
  46. What would you do?
  47. 90 chevy pu broken belt
  48. 92 DeVille, wheres the fuel filter located
  49. Heads and Headers.
  50. 3rd Brake Light Wiring
  51. 63 Nova Rear end
  52. Running the fan off the battery...
  53. my 68 Dodge Coronet 440
  54. transverse engine changeover?
  55. AC Compressor output
  56. Computer Car Management
  57. To warm up the car, or not to warm up the car?
  58. Can someone help with car id please?
  59. Would you buy diesel fuel from this man?
  60. Cracked Head On Vehicle For Sale
  61. Head Gasket Hell!
  62. Carburetor 'Pops' at Low Idle, upon Starting
  63. help!!! my security sucks
  64. big block chevy 409 tri power intake w/carbs
  65. 97 b2300 fuse problems
  66. Brazilian Muscle
  67. 2002 Isuzu Rodeo Steroe error
  68. 1936 hudson rat rod ???
  69. Rear end specifications???
  70. Header Help!
  71. Oldsmobile Power Blocks 400 & 455
  72. My brake lights, turn signals, and turn signal indicator lights aren't working.
  73. SEMB Muscle Car Club - Video
  74. info on air filter cross reference
  75. Gas Mileage myths or facts?
  76. mmm mmm mmm (pic)
  77. TCC lockup
  78. Oil light flickering - fresh rebuild
  79. Olds 442 or Cutlass dashpad
  80. Long overhangs vs. Short Overhangs
  81. OBD2 fault code Reader...which 1 to buy
  82. **Videos US Street Nationals Bradenton Fl***
  83. recirculating ball steering
  84. A few questions about exhaust
  85. help -- 1967 buick wildcat --- help
  86. dumb question :X
  87. Performance Chip....reprogram Ecu...
  88. The first actual question
  89. clutch adapter plate
  90. Looking for opinion on welding exh manifold ON-CAR
  91. use of flushing oils
  92. timing chain advice
  93. can some1 explain to me the different type of exhausts
  94. First Thread
  95. Lucas Transmission Additive
  96. reboring my 305 V-8 engine
  97. Radiators and Intercoolers
  98. *WANTED* Interior for 79 Trans Am
  99. Speedometer, Tach doesn't work
  100. '65 Impala wheel offset?
  101. engine swap question
  102. Window help
  103. 350 small block
  104. Need Front Clip For 69 Ford F-100
  105. obd I or II conector for laptop?
  106. Radio/dome.
  107. Louder! cont...
  108. Louder!
  109. Early Vortec 4.3L identification
  110. I need any help you can offer...
  111. Help with engine swap
  112. Please Help
  113. Compression at which gasoline will ignite
  114. 305-Any easy mods?
  115. reverse went out
  116. Automatic Trannie Makes Manual 'Clutch Chatter' Noise
  117. removing spare(2002 trailblazer)
  118. How do you know when to change tranny fluid
  119. edelbrock heads
  120. 06 GMC Sierra lift help?
  121. alternators..rebuild? rewire?
  122. 68 amx head gasket
  123. CAI vs. WAI
  124. 96 Probe GT: Heater problem
  125. stuff wanted for projects
  126. Engine will only run when choked, and other problems...
  127. just starting to learn about internal combustion engines....
  128. right signal problem.
  129. Problem When Low On Gas
  130. Clutch problems Need help
  131. DANA 60 3rd members
  132. Oil grade
  133. Anyone With a 300C Service Manual...Help!
  134. help with paint code
  135. 94 1500 chevy six power steering pump
  136. dome light and speedomator,not working
  137. warped I. Manifold or wrong one? chevy 350
  138. AN fittings . Wheel Adapters . Wheel Spacers
  139. ASE Electrical Test T6 (Practice Questions)
  140. carb issues
  141. Clutch Question
  142. egr removal
  143. ford and chevy power train questions
  144. Problem starting when cold
  145. Throttle Position Sensor Importance
  146. The 10bolt Weld
  147. Heavy Pontiac
  148. what is the best muscle chevy?
  149. what is the best muscle chevy?
  150. what is the best muscle chevy?
  151. Restoration of my 73 cougar
  152. Camaro> to buy or not to buy
  153. 95 Plymouth Voyager Oil Dipstick Problem
  154. 1977 Dodge Van SQUEALS at High RPM
  155. Removing the Crankshaft Pulley
  156. Need advice fast!
  157. how do i change starter 95 s10 blazer 4x4
  158. WANTED: Jeep CJ Fenders, Laredo Seats, and Dash
  159. WANTED: Jeep CJ Fenders, Laredo Seats, and Dash
  160. Quick Question
  161. blazer idling a little rough
  162. First Timer Restoration
  163. OBD I and II
  164. Oil types
  165. Blower Motor
  166. Dyno Advice
  167. 98 Cutlass Trans cont...
  168. storing a car.
  169. Chip Upgrade
  170. Bad Alternator?
  171. severe service condtions oil change
  172. Fuses?
  173. A good diesel
  174. TITAN mistake, or was it?
  175. Random Pontiac Engine
  176. Headlights Problem
  177. 1964 Plymouth Fury
  178. My 1972 AMC Hornet 4-door
  179. rough idle when cold
  180. CA smog questions...lots of em
  181. Keys and Ignition Switches
  182. 94 Chevy 1500 4X4 w/t electrical problem -- 9 volt drop
  183. Auto VS Stick
  184. Flare to banjo, to drill or not to drill?
  185. Over Drive For Pontiacs
  186. Junk Engines?
  187. Junk Engines
  188. Pontiac Engine Myths
  189. New Montly Cruise Night
  190. Pontiac Engine Myths
  191. Installing Mass Air Flow Sensor
  192. Pontiac Engine Myths
  193. Just a curious question about head swapping.
  194. Steering and Transmission Problems
  195. How do I disable remote start?
  196. main bearrings
  197. The "rubix cube of motors"
  198. Leakage questions
  199. rare earth magnet/fuel atomization...blah blah
  200. What do you think of E85? I won't run anything else.
  201. 1966 Mustang HELP!
  202. timing marks
  203. Remote Start w/stick shift
  204. Sbc Frost Plugs
  205. Auto trans question
  206. tranny flush
  207. Cigarette adapter
  208. High-Performance Mufflers
  209. sudden rapid overheating HELP
  210. tach problems
  211. New horn circuit?
  212. Where can I find torque specs?
  213. Im Gonna Kill Someone!!
  214. Im Gonna Kill Someone!!
  215. 962C Transmission Oil Cooler Location
  216. How to sell these tires?
  217. Need Help Asap with Escort
  218. Exactly what happens
  219. How much larger can I (safely) go than 16" wheels?
  220. 10W-whatever
  221. My project truck...
  222. SOHC vs DOHC
  223. rubbing sound? sqwealing?
  224. A question about gearbox
  225. 1993 Chrysler Lebaron shakes when in idle
  226. Suggestions for Custom OBDII Software
  227. AWD v. MR
  228. Interior sound deadening / Ziebart Underbody Coating
  229. 83 Bronco Engine Swap 4.0
  230. Lift Kit Cant Find One
  231. Low heat out put
  232. motors
  233. New guy
  234. Best Muffler for 99 silverado?
  235. Disable my alarm
  236. In general how many miles can a car take...
  237. For sale( 1968 AMC Javelin
  238. For sale( 1968 AMC Javelin
  239. Unofficial Muscle/Pony/Sports Car thread
  240. Not the fuse
  241. 69 impala trunk
  242. 12V power source
  243. Bottom End Knock? HELP :)
  244. what does this BUMPER JACK fit ? # U69 . chevy ford mopar ?
  245. Engine Coolant
  246. forced induction
  247. 94 Silverado running hot
  248. Chevelle Fiberglass
  249. Need Help
  250. 96 Silverado won 't start, but with a twist
