View Full Version : Engineering/ Technical
  1. hypoid ???
  2. Automotive Jumper Cable Amperage Claims
  3. My Ford Mondeo quality - what do You think about this
  4. What can I do with a 2000 VW Passat?
  5. Need help with battery Ah and starter calculation
  6. Motor oil polymers in engine Toyota Yaris - cleaning??
  7. Survey for School
  8. Brake failure
  9. Possible Damage After Incorrectly Seated Torque Converter
  10. Turbo car running badly/bogging down, blowing black smoke
  11. DIY: Porting & Polishing a Throttle Body (Video Tutorial)
  12. flushing the cooling system
  13. 94 Ford Thunderbird 4.6...air system/electrical issue
  14. Hand Tigten only?
  15. 92 metro dies on acceleration. please help!
  16. Who Loves To Read !?
  17. First post (Multiple questions)
  18. 2008 TrailBlazer LS HighBeams
  19. Reducing fuel consumption
  20. ECU Remaping
  21. Need help in finding a scan tool
  22. Need help in project involving microcontroller
  23. Is there any relay which can be programmed to work under certain voltage, current or load range?
  24. Open-source Automotive Project
  25. Windshield-Roof Leak 1991 Honda Accord LX
  26. CVTs
  27. "service engine soon" codes
  28. Block Sanding By Jeff Lilly Restorations
  29. 2001 GM 3800 Unidentified Wire
  30. Your diagnostic guess, please? Car ran over rocks, emits smoke
  31. Roll Cage by Jeff Lilly Restorations
  32. easy access to changing voltage regulator components
  33. Frames
  34. Older the engine, poorer the mpg.
  35. starting problems with hot engine
  36. 1991 Honda Accord Unidentified Part
  37. My 78 Ford LTD won't start
  38. Chevy help with a used car with problems.
  39. Timing chain guide rebuilder
  40. Rover Batteries
  41. Old Car That Hasn't Been Started In A While
  42. Need Help! Something has fallen off (pics attached)
  43. How to repair beginning rust on the hood
  44. feeling the fuel pump
  45. Vehicle Electrical System related Questions
  46. New cars, no headlights on.
  47. ford fiesta 1.25 zetec
  48. i need help with my 66 impala
  49. AC wont switch
  50. Exhaust wall thickness
  51. Idiotic girl needs help! Gears!
  52. sr20de...old radiator (i guess) popped like a balloon, new one hisses. Not (specifically) the thermostat. Wut do?
  53. back again, no start
  54. Autel AULDS708 Automotive Diagnostic and Analysis System
  55. Engine Rebuild Basics
  56. Name that Part!
  57. Change the battery without losing data
  58. OBD mobile scan tool - univeristy projecto
  59. SBC starter issues
  60. the cool guy
  61. 6-stroke engine thermodynamic analysis
  62. Carburetor scoop questions
  63. Green technology
  64. Turbo's
  65. Compression ratio
  66. Engine won't Start, Turns over and SPARKS
  67. Taking tires off one set of rims and put them on another car
  68. What's the difference between cast iron and chromoly steel flywheels?
  69. Gear CVT
  70. Automotive in the future
  71. Looking to learn more about auto repair
  72. Formula one car body panels
  73. Any suggestions?
  74. create DTC (failure) for obd II tool
  75. Alternating current (1 - 1.5 A) in alternator output
  76. where to buy launch x431 master?
  77. Electric Power Steering Redux: SCARY Article!
  78. ASE or shop manual leak down test for court
  79. Teach me the Basics of exhaust
  80. .►► Real THERMAL IMAGING Night Vision Custom Install
  81. Is this Battery Leaking? Pic Inside
  82. How to get into engineering?
  83. using a/c compressor as supercharge
  84. Emission: HC's same as Gasoline?
  85. Charging Systems in New cars. curious!
  86. Need starter gear tooth geometry
  87. Fraction of Fuel burnt
  88. D light malfunctioning on a honda civic
  89. Distributor - Breaker Points
  90. Combustion equation
  91. Don't be soldering your automotive electrical connections
  92. Custom high angle cv drive shafts?
  93. Dana 44 cross pin diameter?
  94. Hello from the UK
  95. Double Wishbone Suspension
  96. Help: See accident damage in service history?
  97. Holley carburator, need help and information
  98. Used Car Pre-purchase question
  99. Central locking used to break into a car?
  100. New Bosch wipers don't smear.
  101. 2003 Chevrolet Cavalier auto won't shift to park and reverse its stuck on neutral and drive
  102. Possible Hydrolock and Solution?
  103. 1991 Ford: Battery drain caused by both engine and meter fuses
  104. Replacement bolts - Canada
  105. Portable battery jump starter which one to buy??
  106. quick question about an increasing source of 12v as revs go up
  107. HELP Gas Tank Issues!
  108. Urgent question about "Guaranteed to pass" for cars!
  109. Trailblazer remote start issues
  110. VW Jetta Vibration
  111. Advice for silencing a noisy hood + muffler
  112. AWD not as safe as it seems?
  113. Remote Car Locking
  114. Electrical issues
  115. Speed Limitations & Monitors
  116. Cloud of white smoke and burning plastic smell from under the hood
  117. Starter motor troubleshooting
  118. LED strip mod, Turning Signal
  119. 2 barrel dual carb vs 4barrel single carb
  120. Is a 04 base Sebring a good car to mod?
  121. It is possible to broke the car hood hinge by walking on the hood?
  122. A request for help, from an ignorant - a question on databases
  123. Hub/bearing assembly issues
  124. Need definition for crossword clue
  125. Cooloing problem, challenge for anyone who can help!
  126. 2008 Kia Optima - Manual Steering Rack Conversion
  127. Help me rewire my AC system to bypass the computer
  128. distributor question
  129. Wheels 101: what affects ride quality most?
  130. You used toothpaste - how's the windshield now?
  131. Best Way To Clean Engine Block Threads
  132. Driving while blind
  133. CV driveshaft
  134. A couple of brake questions
  135. Modified fuel pump setup, PLEASE ADVISE!
  136. help me in design calculation for hybrid car
  137. Carb Choke Plate to Provide TBFI Properties
  138. Car loses power when accelerating hard after using Seafoam
  139. sealed vs 'cap topped' batteries
  140. Hole in brake rotor
  141. Which way to face thermostat
  142. A Car Repair Wiki with How To's, Instructions, Diagrams
  143. Permanent Oil residue in the Coolant?
  144. Can overheated exhaust result in engine damage?
  145. Bonnie shudders and dies...a lot.
  146. Battery/electrical issue?
  147. Cooling system: Does it circulate the coolant in the resevoir?
  148. volvo
  149. Help my turn signals and hazards won't work
  150. What is the material build up on my rotor?
  151. Moist underlay in recently purchased car
  152. '89 chrysler electrical problem
  153. Shudder while turning right
  154. Auto Key FOB app for smart phone
  155. Can my car pull a trailer?
  156. Mitsubishi 4G93T Timing belt noise/knock from idle to 2000rpm then dissapears...
  157. massive coolant leak
  158. Coolant everywhere, car broke down but didn't overheat.
  159. Motor fuels
  160. Another Steering Rant - Mixed Bag
  161. dirt inside tire(s)
  162. Can you identify this part?
  163. What determines hydroboost compatibility?
  164. My car is in park and drive at the same time, so it will not start, what needs repaired?
  165. I am lost...Torque Converter...
  166. Determining gas remaining in the tank
  167. CarMD
  168. Nissan RB26DETT vs Toyota 2JZ
  169. BMW E38 740i M60 4.0 V8 motor,erratic fuel pump pressure HELP PLEASE
  170. Multiple sudden coolant losses
  171. question about headlights
  172. The Real Difference Between Horsepower and Torque (Bit of a read, but worth it)
  173. head gasket
  174. Technician advice needed. First time in shop
  175. Engine Question - Chevy Small Block Build
  176. What would happen if..
  177. Survey - what do you expect from hybrid-electric vehicles?
  178. Clutch diaphragm spring. How to choose it's diameter?
  179. Hey guys HELP me out here!!
  180. Audi Production Award 2012
  181. Prv v6
  182. Are USB KKL VAG-COM cables car make specific?
  183. Tire data
  184. Pontiac 400 build advice!
  185. Camshaft identification help!
  186. Looking for a blogs, newssites...
  187. no fuel?
  188. Tips to remove choke pulloff
  189. Finding help learning.
  190. Ignition misfire and Lean diagnostic codes?
  191. Camless Engine
  192. Solex carburetor
  193. transmissions, why is there a difference between Overhaul capacity and service refill capacity?
  194. Phoenix Systems RFI brake bleeder
  195. Nissan Pathfinder - Did I get Scammed!!
  196. overheating question
  197. differential half shafts slop
  198. front brakes question
  199. Japanese Monster Engines
  200. 12 bolt rear end
  201. zed-bull auto key programmer VS smart zed-bull
  202. oese anyone use BMW Multi tool V1.2 before?
  203. Flat / Boxer vs Rotary
  204. Pontiac Hemi
  205. C clamp with bolt drive instead of T handle for tightening.
  206. Common Rail Injection System
  207. Oil on spark plugs
  208. Compustar CS600S Remote Starter - Add Chirp
  209. Trying to track down a dang seat belt!
  210. "Plus-sizing" Tires But Maintaining Original Width
  211. 08 Saturn Aura XE no power, Will not start, not dead battery!
  212. **Negative** Caster
  213. stagg shocks and struts?
  214. 440T4/4T60 Drops into Neutral at Stops
  215. Any information on electronic suspension operation welcome.
  216. Car starting issues (video link incl)
  217. what happens to v6 and v8 cars if we do not use them for more than 80 km/h for long time
  218. Electric car MSRP
  219. Tie Rod
  220. car battery light
  221. Who do you view as some of the best car designers
  222. Powersteering fluid ran out, now squeeks..
  223. HELP! Weird 1985 Pontiac Fiero Electrical Problems!
  224. Smell of exhaust inside the car
  225. Diesel fuel conditioner into gas engine?
  226. Front Strut Mounts & Bearings Play
  227. Continuous Variable Gear Transmissions - which are reliable?
  228. True Constant Velocity Joints: Are they available yet for ANY car?
  229. Trying to get an engine unstuck
  230. Radiator Fan Refuses to Hush!
  231. installing a limited slip differential for snow and ice?
  232. Mechanic says battery has low voltage
  233. Need Advice: 2006 Dodge Magnum
  234. AF's new youtube newsfeed
  235. Review - Tote Air Compressor
  236. Brakeline Flaring - bad instructionals, disinformation, youtube,
  237. Car Whistling noise
  238. Voltage Stabilizer
  239. Hyundai Odometer reading
  240. Career halp!
  241. Install Fog (Aux) Lamps
  242. Help! Admin or Mod Please
  243. Physics Question: Thrust Angle
  244. need help identifying part
  245. Car Design Software
  246. Transducer/Odometer
  247. Moilten metal on 3rd O2 sensor
  248. Car leaking fluid what is it?
  249. O2 sensor
  250. Oxygen Sensor Question
