View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14
  1. is grinding related to motor mount?
  2. 1992 SL1 144K Acceleration Problem
  3. Idle to fast after highway driving
  4. 95 SL2 with occasional drivability trouble
  5. 92 SL2 Automatic - Multiple Problems
  6. sc clunks and growls upon in first upon rapid acceleration
  7. Where is mass flow sensor 98 sl saturn?
  8. '94 SC2 used, contains after-market alarm
  9. Door is stuck shut!!!!HELP!!!!!!!!!
  10. Clutch Pressure plate
  11. Rough shifting
  12. 95Saturn SL2, Won't start unless gas pedal is to the Floor
  13. idle due to bad o2?
  14. SL 2001 not starting while engine is still warm
  15. 1999 SL2 Automatic, Which engines will fit?
  16. Hide away headlight noise on SC2
  17. Headlight moisture 2002 sc1?
  18. 99 Starting mystery
  19. 1.9l boost question
  20. electrical issues
  21. Sl1 electronics problem
  22. from a dead stop at a light my car is a pain to get in gear
  23. shake when in gear at a light
  24. Manual Transmission Woes
  25. Where Should Jack Stands Be Placed
  26. Light.. Won't.. Stop.. Blinking..
  27. 94 SL2 Odometer failure
  28. 99 SL is hard to steer
  29. remote door locks
  30. 95 SL cat converter trouble
  31. 2001 SC-2 please help
  32. change in idle speed
  33. Smoke from under SW and no start
  34. '95 Saturn Cruise Control
  35. fuel comsumption
  36. when to use a hotter plug
  37. 1999 Saturn SC2 hood
  38. front license plate on '01 SL1
  39. 98 sl rebuild
  40. sl-2 question
  41. 92 an 96 engine differences?
  42. shifter problems... maybe worse?
  43. 99 sl2 lifter noise
  44. DRL's won't go off...
  45. Replacing Fuel filter
  46. FS: 94' SC2, cheap, needs work
  47. Cruise Control - 1995
  48. engine swap for 96 SL2
  49. Mystery light
  50. signal/hazard lights
  51. blown fuse?
  52. how do the engine come out of sl2
  53. fuel filter
  54. sierrap615
  55. 94 SL1 seatbelt light.
  56. '95 Saturn SL 4 Door
  57. 95 SC2 getting hot on gauge
  58. Loud Brakes
  59. 91 sl2 automatic trans
  60. 2001 Saturn SL Idle problems
  61. I have 2 questions
  62. Saturn----Low Oil Light
  63. Transmission Part Help
  64. '95 Saturn SL Repairs
  65. aftermarket steering wheel hub???help!!
  66. Fuel Filter
  67. 96 SL SES and Flashing Lights
  68. 1997 SC2 Vibration
  69. front brakes lock up
  70. Possible trans probs? (not related to the below post :) )
  71. 01 Sc2?
  72. new radio problem
  73. 2002 SL1 won't stay running computer problems
  74. more engine swap questions
  75. Dead Shifter in a 97 SL
  76. transmission problems... gulp, expert diagnosis needed
  77. error code
  78. What's 6 inches long, with 2 ball joints?
  79. RPM's surging
  80. AHHH!!! too many parts so little money...
  81. Revenge in a stock Saturn....
  82. 99 SL1 Rear Brake Diagram
  83. radio harness
  84. gas pedal
  85. 2000 SL1 Noise and Rough Idle
  86. do it yourselfers?
  87. how to remove alternator??
  88. Electrical Problems 1998 SC1 single cam
  89. body damage on front underside of '97 SL: to fix or not to fix
  90. what the %^&* please help me
  91. coolant temperature
  92. 94 Saturn SL2 wont start
  93. 99 SL1 Install Cruise Control??
  94. 92 SL Manual Transmission Problems
  95. 2000 sc2 DOHC intake crack??
  96. what repairs have you done
  97. ATF change
  98. how strong is the rear deck.
  99. Black oil
  100. Replacement of Starter on 99 SL2
  101. new engine
  102. sl2 engines
  103. Ac output temperature
  104. mass air flow senser
  105. starter bad or bad battery?
  106. spark plug wires
  107. 96 SL1 tranny?
  108. idiots lights?
  109. When at speed, changing lanes or quickly moving side to side is very sloppy, why
  110. EGR valve
  111. Emissions "not Ready"
  112. rotors
  113. '99 SL2 will not start
  114. Airbags Warning Light Stays On
  115. ignition tumbler????
  116. Cai
  117. can't see!!
  118. code 32
  119. electrical diagram for the tranny
  120. scam or will it actully work.
  121. Long Overdue A/T Maintenance
  122. Clear Corners
  123. obd connector
  124. Slipping Automatic Transmission??
  125. Adding a battery vs buying a new alternator...
  126. service book
  127. 92 Saturn SC Headlight Flicker
  128. interior trim
  129. serpertain belt
  130. Help!!!!
  131. is this normal?
  132. doping
  133. tire pressure
  134. AC probs
  135. aftermarket tail lights.
  136. outside mirror glass replacement
  137. I NEED A WINDSHEILD--Which will fit??
  138. k&n 57-3012
  139. 96 SL fuel relay
  140. 2002 sc2 problems
  141. Radiator rant....
  142. MAP sensor prob. . . still
  143. dome light
  144. turning brakes
  145. 99 Saturn SL1 Engine oil consumption
  146. Engine swap?
  147. Need help with car problem! Noisy metal noise...NOT BRAKES!
  148. Any suggestions would be much appreciated
  149. timing chain
  150. 93 SC2 Loosing Power
  151. Pics of my new amp...
  152. '98 sc2 in bad shape
  153. Tranny Question
  154. 96 SL2 Oil in the Spark Plugs
  155. problem with s.e.s!
  156. Emissions
  157. oh my god
  158. Oh boy, a new problem! 92 SL2 Clutch System
  159. Stalling in gear
  160. Blown Alternator/ problem with Amp
  161. about mods
  162. coolant gaugeis weird
  163. some ?s
  164. about traction control
  165. hey just brought a 1997 saturn sl2 w/manual trans
  166. Engine Swap
  167. servive engine soon!
  168. This is a post on Saturnfans.com that I made and thought.
  169. Saturn Sunroof
  170. Tranny swap question..
  171. Deal Breaker?
  172. fuse blowing problem
  173. Head Swap
  174. crapy resale value.
  175. energy suspension
  176. Electric problem
  177. Milage increase?
  178. HELP! 94 SC2 with SERIOUS problems
  179. 97 SC2 Shifting problem
  180. 2000 saturn ignition questions
  181. overheating car
  182. third brake light question
  183. automatic shifter
  184. Power Window Motor/Door skin
  185. Possible parts off a 95 SL2
  186. 96 sc1
  187. Just bought an 2002 SL2
  188. Nos
  189. 97 SC2 purchase
  190. idle speeds
  191. 97 SC2 Bad transmission
  192. random thought.
  193. hard time starting
  194. '01 SL2 won't start
  195. to change or not to change
  196. sensor replacement.
  197. How many gears does a 98 sc1 coupe auto have?
  198. 94 SL1 SOHC manual transmission bad!
  199. SL2: Rebuilt from Salvage
  200. Very Old Saturn Paint Job I Designed
  201. Another 98 SL2 with odd problems
  202. 1995 SL A/C Problem
  203. gas mileage going bad????
  204. Sl3?
  205. 98 SL2 weird Electrical....wont start HELP?!!
  206. power seat?
  207. service light on?
  208. cooling fan always on.
  209. oil burn or leak?
  210. 1994 Saturn SL2: Odometer failure?
  211. engine light
  212. rumbling or rubbing noises
  213. how much is it worth?
  214. '99 SL2 squeal after start
  215. Stupid question about the EGR System
  216. I lost my keys....
  217. starting up
  218. directed to saturn speed_ 12
  219. Location of Fuel Filter in 02 SL2
  220. another saturn gone
  221. 8 mph in 1st gear
  222. Quill Bearing
  223. SOHC-DOHC more info...
  224. Sohc-dohc...
  225. '93 SL1, engine sounds like it has a woodpecker in it. Thanks Meineke!
  226. mixing oil.
  227. Wiper Delay Problem
  228. Wiper Delay Problem
  229. Wiper Delay Problem
  230. a few issues (speedometer, door panel)
  231. 94 sl1 motor mount
  232. Tranny still messed up.... '98 SL2 Auto
  233. whats the diff?
  234. 2000 Sl2 Ignition Woes
  235. uhh.....i'm stumped
  236. sounds like a beetle
  237. 2000 sl2 o2 sensor
  238. 95 SC2 Slight Knock
  239. Saturn 99 SL1 ECT check and replacement
  240. cd player
  241. Oil in Spark Plug Well
  242. rear quarter panel replacement question
  243. Anyone know the stock power to weight ratio numbers?
  244. Trunk Problem
  245. Where is the knock sensor?
  246. gas milage
  247. 95 Sc2 Uses Oil
  248. Loose Side Mirror(Glass)
  249. It's that time...
  250. new trunk lid
