View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14
  1. Tranny Or Fuel?!?!?!?
  2. rear license plate light
  3. 2001 sc1 W/ auto to 96 sl2 W/ manual
  4. Buy Me! 94 Sc2 $1800
  5. 2nd time transmission broke
  6. 99 SL1 RPM and coolant needles
  7. 97 saturn wierd problem, please help!!
  8. r34 bodykit
  9. Any good ideas?
  10. Le5,lsj,lnf,l61,l66
  11. parking brake chime won't stop
  12. jump start smoke
  13. sl2 oil plug
  14. Fuel leak from canister in '98 SL1
  15. Gone in 60 Seconds!!
  16. brake caliper mounting bolts
  17. 94 Sl1 Sohc
  18. speed sensor
  19. map sensor
  20. 99 SL1 drivebelt replacement
  21. custom work worth it?
  22. 96 SL2 Oil in Cylinders
  23. Average Costs?
  24. alternater plug
  25. bad milage
  26. 95 sl sohc with oil problem
  27. Free 1992 SC2. No Engine. Good for Parts.
  28. check engine light on but no codes
  29. my Poor Staurn
  30. Starting Issues!!!
  31. window tinting
  32. squealing
  33. trouble codes, 0341, 0507
  34. 1995 Sl Sohc
  35. Security System Issue
  36. Body Kit For A 91-95 SL1/ SL2 For sale
  37. Another 99 SL2 OBD II code
  38. po741
  39. 97 sc2 not starting
  40. Engine Codes...
  41. 95 SL2 Leaking Oil
  42. loss of power
  43. Timing Belts on a 95
  44. Prices?
  45. Where is the crankshaft position sensor
  46. 01 Satrun sc idle speed problem and bucking
  47. 1.9L motor trouble
  48. Parts, parts, and more parts. Whats really wrong with it???
  49. key switch for SC2 year 2000
  50. location of VIN number on my car.
  51. Splines
  52. Splines
  53. Rear speakers
  54. 2000 Saturn SC1 cylinder mis-fire
  55. I would like to know more about Saturns please!
  56. Freaky event...electrical???
  57. Alloy wheels....strip & clean.
  58. 97 Saturn SW schematic
  59. 98 SC2 Computer problem? Help!
  60. I think i might have a problem
  61. 2001 sc2 air intake question
  62. Squeak from Steering Wheel
  63. Sirius Satellite Radio
  64. 94 Sl2 has a rattle noise when A/C is on
  65. 92 + boost = no no ?
  66. 97 sc2 body kit
  67. 01' Starting and stalling
  68. Transmission temperture sensor
  69. 1998 SC1 - Manual Tranny Problem??
  70. Transmission problems help!!!
  71. rough idle
  72. which alternator
  73. 91 Sc2 Rally??
  74. My 99 SL1 has a jerk when applying gas pedal
  75. Replacing Belt Tensioner Pulley
  76. looking to trade or sell my 90'celica for a saturn sc2/sl2
  77. question about 99 sl2
  78. High Idle
  79. blown 95 SL1 motor
  80. radio harness color code?
  81. 95 SW2 intake / exhaust questions
  82. Blown Engine?
  83. Coolant system issues
  84. heet
  85. 96 SL1 rod kncking
  86. 1994 Sc2 For Sale
  87. O2 sensor for a '98 SL1 DOHC
  88. 98 Saturn SC2 Idles Rough then runs fine
  89. 1994 sl2 llo seized engine...
  90. running like crap, need help pleaseee
  91. 92 Saturn SL2 won't start
  92. removing door panel on 96 SL1
  93. 1995 SL2 barely starts..help!!!
  94. 97 sc2 amp wiring HELP!!!
  95. Possibly tranny problems, maybe the cold weather?
  96. 2001 SL2 cold starting problem
  97. Looking into a Saturn as a daily driver...
  98. exaust manifolds
  99. SL2 motor swap
  100. 2000 SC2 service engine light?
  101. camshaft position sensor
  102. 1995 SL1 idles rough and stalls
  103. speed sensor?
  104. electric seat belt
  105. Another SC2 crank but no start problem.
  106. headliner fix?
  107. single to dual?
  108. whats tbi mean?
  109. specs on a 94 SL1
  110. 99 saturn SL1 revs high on cold start
  111. Need Amp Help
  112. what month was changeover
  113. 97 sl1-Cold starting issues
  114. Looking for parts for 96 SC2: Green Body, Tan Interior
  115. dohc 2 sohc swap
  116. willing to trade whole 92 sl2
  117. oil level
  118. tune-up
  119. 92 SC2 DOHC Header on 96 SC2 DOHC
  120. what year motors can i use in my 96 sl2
  121. Low or no Oil pressure on cold morning starts
  122. 92sl bottom end in 96 sl
  123. 97 sc2 oil in spark plugs
  124. Tranny went out on our SL, for the 2nd time
  125. help 97 sl won't start
  126. SC2 Wont start :)
  127. Which manual is better?
  128. swap motors
  129. Engine noise sl1
  130. No Service Engine Soon Light - Fan out
  131. 92 Sl1 wipers not working
  132. Signal Replacement.
  133. 97sl1 into 95sl2
  134. 2000 SL2 misfire
  135. I just bought AC Delco Plugs
  136. Engine runs RICH ( Wish I was)
  137. motor swaps
  138. 93 SL2 DOHC engine swap
  139. RIP engine- Where's a good place to buy online?
  140. Just bought a 92 SL2 for $300
  141. 95 Saturn SL fan problem
  142. Question on 95 Saturn SL heater core
  143. Belt Tensioner Replace
  144. 1999 SL2 slight transmission leak
  145. Adding power to a SL2
  146. water in floor...97 SC2
  147. 92 Saturn few questions about
  148. Need opinions
  149. Engine Compatability (96)
  150. Football?
  151. Changing oil in Manual Transmission
  152. How do i get the spoiler off a 2002 sc2
  153. FS. Header from '92 SC2.
  154. cruising speed cut out
  155. Saturn SL Seats
  156. powertrain damper kit
  157. 95' SC1 not starting
  158. 95' SC1 not starting
  159. no take off
  160. 97 SLI Ignition problem
  161. For Sale: Nearly New Ignition Control and Coils with Warranty
  162. FS: Parting Out 92 SC2. Blue Green Body. Blue Grey Interior
  163. how do i disable my air bag on the driver side
  164. SC, SL bumper question
  165. need parts
  166. starting problem
  167. Roof Rack for 95 SL
  168. Looking to buy a SW
  169. how to program a key fob for a 2000 SL2
  170. Battery power...lights dimming.
  171. Saturn compatiblitly questions
  172. sylvania silverstar lights
  173. tornado fuel saver.
  174. 2000 Saturn Sc1 windshield wiper problems
  175. 1997 Saturn Won't Start & Coolant Sensor light won't turn off.
  176. Saturn SL2 shifter.. HELP!?!?!?
  177. SC2 Jerking AGAIN !!
  178. Left Fender Almost On Tire
  179. SC Steering Column Cover
  180. power steering flush - how do I do it?
  181. Temp Sensor
  182. very unusual cooling fan issue 92 sl1
  183. 1995 Saturn SL1 Tachometer wire
  184. Replacing Speakers and Radio in an SL
  185. Rear Speaker Wires
  186. tire question
  187. code p0711
  188. She Is Driving Me Bonkers
  189. sc2 running at times on 3 cylinders
  190. Rough Idle on 99 SL2
  191. Jet chip
  192. Project disappointment lol
  193. Battery size
  194. remote starter
  195. 1997 Saturn 2 Door needs replacement driver's side door.
  196. 1998 SL1 cold start problems
  197. Noise in dash
  198. Power Steering Hose Removal.
  199. easy engine removal?
  200. 93 Saturn SC clutch problems
  201. Engine swaps
  202. Trunk light for SL1 1998
  203. rpm's
  204. headlight swap
  205. 1994 SL2 How to: Get to and Replace Speakers?
  206. 2000 SL and Service Engine Soon light
  207. 2001 SL2 Electrical Problem
  208. Window Problems (1998) Saturn 2 door
  209. Saturn SC2 Jerking Problem
  210. Changing Brakes
  211. temp gauge and high idle
  212. Excessive vibration at idle
  213. 2000 SL2 Startup Problem
  214. 1998 SL1 trans problem
  215. 1994 SL2 Console lights not working...
  216. Engine Misfire and smoke out of tailpipe @4000 RPMs
  217. Rear Defogger
  218. engie swap question
  219. very low temp in cold weather
  220. 1998 SL2 Engine Swap
  221. Rpm On Fritz
  222. Changing Wires
  223. Surging and temp problems
  224. aftrmarket amp into factory deck
  225. oily sparkplug
  226. 2000 SC 1.9 losing rocker arms !!!
  227. crazy wiper motor
  228. Modifications to cylinder head
  229. misfire?
  230. blower inop in cold
  231. Parting Out 92 Saturn SC2 Coupe. Several New Components.
  232. cooling problem
  233. i realy need help
  234. Hi/lows at same time
  235. Serious Starting problems
  236. new sunroof?
  237. engine misfire at cruising speed
  238. cracked paint...
  239. Oil dripping underneath near front
  240. car won't start
  241. Carbon on Head and Intake
  242. Cock-eyed Shift Knob
  243. krytox lubricant
  244. Fuel Gauge out of Wack??????
  245. Shuddering in 1st gear
  246. EGR valve problem on a 1997 SL2
  247. led bulbs
  248. 1992 Sl1 Windshield Washer
  249. Air blowing out of oil cap filler hole while eng. running
  250. 97 Sc 2 burning to much gas !!
