View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14
  1. 95 sl transmission problems...need help ASAP!!
  2. speedometer
  3. speaker screws
  4. Pops out of 2nd gear
  5. Seatbelt doesn't work!
  6. 92 sc ignition problems (coil goes in and out)
  7. Headliner and Modifications...?
  8. Left front wheel
  9. Scratch Remover
  10. How much oil for a 94 SC2?
  11. SL2 Head Gasket
  12. Electrical WIERD Starting/Running/AC Shuts my car off Problem
  13. Can I replace my own muffler? ('94 SL1)
  14. car hesitates
  15. 94 SL2 many small problems.
  16. 92 saturn shuts off after 20 seconds
  17. Anti-Lock Brake Issue
  18. Coolant temp sensor
  19. trouble code 26
  20. I need some help here...
  21. Phsyco cooling fan from hell.
  22. Wheels
  23. I found headers!!
  24. Reliable engine for 91 SC2
  25. Left wheel ticking, service engine soon?
  26. Color Change
  27. High Idle, then 30mins b4 u can start up the car
  28. ignition system...
  29. i am looking for some specs
  30. cooling system problem
  31. Popping the hood without a hood cable?
  32. Plugs
  33. Cold Air Intake
  34. swapping sl2 parts
  35. service engine light mystery
  36. Service light = lose power
  37. '98 SL Clutch or Transmission problem
  38. gas tank
  39. odometer.
  40. Saturn SL # 4 Cylinder Miss
  41. wont stay running
  42. timing chain replacement please help
  43. failed emissions
  44. Uh Oh Trouble
  45. Any Problems?
  46. Tensioner question
  47. holes
  48. transmission fluid
  49. 1995 SL1 Won't Start - Please Take A Look :)
  50. o2 sensor?
  51. Looking for a parts suplier
  52. S Series paint problem
  53. 93 SL1 Code 26 and 32
  54. sl moter mount question
  55. SL2 Wheel stud replacement
  56. Aftermarket power locks
  57. 1996 Saturn SL Cylinder Miss....
  58. Where is the therman fan switch
  59. HELP! PO706 transmission trouble code
  60. header?/euros?
  61. tick tick
  62. whinning noise
  63. plugs/wires?
  64. dag nabit not this
  65. idling speed
  66. Tune up?
  67. where to find cheapest saturn parts (body)
  68. chick car?
  69. S.e.r.g.
  70. unladen weight..
  71. removing rear speaker grills in 93 saturn SC2
  72. oil on spark plugs
  73. 1996 SC2 Service Light!
  74. my 91 sl2 is dumping fuel into cly. 1 ????
  75. Programing a Keyless Entry for 1999 Saturn
  76. 96 Radiator Leak
  77. Wheel size on 93 SC2
  78. 1992 Saturn RPMs acting weird
  79. sporatic idle, can't start with out murdering accellerator
  80. Speakers
  81. '92 DOHC Engine Swap
  82. A/C Clutch
  83. How do you remove rear door handle 96 SL2?
  84. d.i.y. c.a.i.
  85. 2002 Sc2
  86. gauges
  87. Hard to start when hot!!
  88. fan
  89. 1994 SL1 parts for sale
  90. 94 sl2 wierd shifting HELP!!!
  91. odometer problems
  92. cooling fan
  93. SL2 engine overheat/ AC cuts out/ uses oil
  94. intake ?
  95. turbo
  96. New project
  97. used parts
  98. how much would a manual conversion be?
  99. Powertrain Control Module
  100. Problems shifting into 2nd
  101. Power Lock Problem
  102. 1996 Sc1 Head Gasket Change - Hlp Plz
  103. temperature sending unit won't come off
  104. Antifreeze leaking out of reserve
  105. firestone tires
  106. P0133, P1133, and P0341 in Saturn SC1
  107. '98 Saturn SL-1 doesn't start
  108. where's my horn?
  109. smoking abit
  110. door wires
  111. door panel
  112. Check engine light problem?
  113. what does everyone think?
  114. '96 saturn sc1 wont start. PLZ HELP...
  115. 2001 Saturn sc performance upgrade
  116. fuel tank Sending unit
  117. Drag racing?
  118. pcm
  119. saturn sl1 have radio want to install cd player--power acoustik cd player-- how to do
  120. rebuiler licence
  121. Converting A/C to R-134a?
  122. 1997 sc1 parting out
  123. keeping fluids cool
  124. '95 SL1 Computer code 26
  125. EGR lost it's magic smoke?
  126. Find OE number
  127. 1994 Saturn SC1 Headliner
  128. owners manual
  129. cat back exhaust
  130. Euro tail lights
  131. Question bout engine computers
  132. coolant/antifreeze refill
  133. cold air intake
  134. 95 sl2 transmission to 95 sl1
  135. 2002 Engine in a 95 SC1????
  136. tail light
  137. Rear sway bar mounts
  138. 1995 SL Clutch Pedal
  139. engine swaps
  140. DOHC for SOHC
  141. 1994 SL Failed Emissions - HELP
  142. high rpm at idle
  143. freezing car parts to save gas
  144. '97 Saturn SL1 - smoke in cabin
  145. How to quieten up the cabin?
  146. 96 sl1
  147. Engine Block Drain Plug
  148. 1992 SL2 white guages?
  149. steering column swap
  150. Engine Tends to overheat while idling/stopped
  151. some progress pics of my work
  152. Stop Leak in Auto Trans.?
  153. Fuel Guage
  154. nos purging
  155. Theoretically speaker....
  156. A/c Blower Stopped
  157. 95 Saturn SL1
  158. 92 sc2 high beams
  159. '96 Sc aftermarket Springs
  160. how do you post pics
  161. codes P0117; P0125; P0711 ?
  162. Engine whirring/whining SL-1
  163. Job Offer!!! Sweeeeet!!!
  164. Code trouble SC2 1997
  165. White Face Gauges print out
  166. Radiator Fan Question
  167. how to remove my door assembly?
  168. so, i keep changing my mind about a turbo
  169. 1992 Saturn SL2 - Problems Read
  170. fender wells
  171. 92 sc2 turbo or nitro
  172. 97 SL2 Aftermarket Pistons
  173. '00 SL2 Cooling problem
  174. engine swap
  175. SC2 hide a way headlights
  176. Faster Turn Signals
  177. thinkin about cutting into airbags for mod.. opions please
  178. PSP mod! .. lol
  179. Thats Why I Bought My Saturn...
  180. Location of Air Temp Sensor and IAC?
  181. new clutch, flywheel, halfshafts, and now even bigger problems!
  182. new cam an lifters
  183. wtf does the Intake Resonator do?
  184. Does the PCM control the MPH readout?
  185. Sister's Saturn wont start! Need help!!
  186. 99 SL engine trouble
  187. Car Power Off
  188. 92 calipler problems
  189. 1992 saturn spun bearing ?
  190. Lost Threads
  191. Rebuilding A 1995 Sc2 Motor
  192. '99 SL2 idle speed
  193. clutch replacement 95 sl1
  194. Post Pics Of Your Car!!!
  195. Resetting The Service Engine Soon Light
  196. 1997 Saturn SL Transmission + Options?
  197. valve job
  198. Want to make a real difference??????????
  199. car stalls
  200. Is there no way to pull codes for yourself?
  201. windshield
  202. 1996 saturn sc
  203. Burnt Valve
  204. Air Bag Deployment,
  205. Swapping Parts
  206. 95 sl hard shift and hard start
  207. Saturn Reliability Help
  208. 96 motor swap
  209. any hi po mods
  210. Muffler For 95' SC2
  211. Sunroof
  212. New stereo system installed.
  213. trouble code 51
  214. miss or hesitation during acceleration
  215. 96 SC1 speaker question
  216. Too Many Problems!!!
  217. fan malfunction
  218. new air intake
  219. trunk mod
  220. wanting brights on same time as low beams. please help
  221. 98 questions
  222. women !!!
  223. trunk rattle from bass
  224. 93 5speed Saturn SC with the shakes!!
  225. Need parts for 98 SC2
  226. Coolant Temp Sensor or ECP sensor?
  227. Saturn Mods
  228. Keys open 2 cars...
  229. Power Window problem 97' SC2
  230. Selling My Car
  231. Painted valve cover
  232. 1994 Saturn Homecoming Edition????
  233. service light
  234. Need help getting clutch to engage the starter, within the next 24 hours...
  235. door locks
  236. 1993 Saturn with code 26 & 32
  237. airbags
  238. engine codes
  239. fuel injectors
  240. idle drops consistantly
  241. Specs & Name Of Your Saturn
  242. c02 sensor
  243. e check
  244. crankshaft bolt into a scrapyard (mountain of a molehill)
  245. 94 Sl2 To 95 Sc2 Engine Swap
  246. 1.9L dead cylinder???
  247. taillights
  248. 97 sl2 cant find the problem
  249. vrooommm possible?
  250. Flip-Flop Trunk
