View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14
  1. 5 Minute Shut Down
  2. I need help identifying....
  3. Ground wire kits
  4. 94 sc2 throttle position sensor switch
  5. Trouble Code 15 -- '95 SC1--Need help with resistance
  6. 97 sl2 questions
  7. window jerk
  8. my saturn was on fire-electrical wiring help
  9. Hub or Strut????
  10. 1998 saturn after-market a/c system
  11. EGR Valve T/S
  12. CPS location
  13. 98 engine swap
  14. Cooling Fan Fuse Blowing Constantly
  15. Coolant Leak
  16. overheats in warm weather only
  17. 94 SL Engine Light Question
  18. 92 Saturn SC2 Stalling.
  19. performance question
  20. Pink Coolant?
  21. Ignition Switch Problem.....Help...
  22. Wouldn't have believed it if I hadn't seen it!
  23. Idle, rpm, gas problems with a 93 SL-1 Automatic
  24. re -build
  25. 98 Saturn SL1
  26. Tire Rubs Brake Line When Turned To Right SC1
  27. 95 SL-1 Engine/Tranny Problem???
  28. body work
  29. Soaping Your Belts?
  30. muffler help
  31. Saturn still running rich and dying
  32. 1994 sl1 tempature light on any help?
  33. low spark condition while cranking
  34. need transmission for 94' sl1
  35. coolant
  36. this is a bs ? but i got to ask
  37. 92 saturn sc2 trouble codes needed
  38. I need a fuel door!
  39. speedometer off
  40. glow gauges problem
  41. High Idle in Neutral
  42. HELP I Broke 3 Transmissions!!!
  43. best way to change the clutch
  44. 96 SL2 oil pump cover
  45. overheating
  46. '02 sl2 any major problems?
  47. overheating?
  48. Removing the idler pulley
  49. Wiper halfway up
  50. 97 sc 2 ring job $$ =
  51. oil consumption,97 sc2 =
  52. Reverse problems
  53. Shifting Problems
  54. Front left wheel noise
  55. Speedometer doen't work when it cold out. 97' SC2
  56. SOHC to DOHC swap???
  57. 94 Saturn SC2 parts car, anyone need parts?
  58. Trouble Code 11
  59. Saturn SL1 running rough
  60. saturn sc2 1992 won't start
  61. running rich, dying, aaargh!!!
  62. aftermarket pcv and oil burning?
  63. 98 Saturn SL1 won't stay running
  64. saturn SL1,1999 fuel filter replacement
  65. Another Car wont start-wierd spark timing...
  66. 94 sc2 intermittent rough or fast idle
  67. WHAT DAMAGE CAN BE CAUSED BY NOT CHANGEING YOUR Oil REGULARY?
  68. Intake 2000 SL1
  69. compression test-loss of power
  70. I need help
  71. Car will not start
  72. coilovers
  73. 95 SL2 Auto Hangs Up In Gear
  74. 96 SOHC into a 95
  75. 98 SL2 oil light
  76. Rear tire problem
  77. 2001 SC1 a/c problem
  78. Absolute electrical failure in '97 SL4
  79. Left brake light not working
  80. motor vibration in drive and thumping in front when slowing down.
  81. saturn sl1 transmission problems
  82. HELP i need to remove door
  83. 93 SC2 Dash Harness Relay
  84. intake question for SL1
  85. is there any thing out there
  86. 96 SL1 Can't get into First Gear
  87. intake module
  88. Saturn SL2
  89. 96 SL2 cranks but won't start
  90. Oil weight, Valve cover change...
  91. 97 saturn sc2 engine cradle or k-frame
  92. which Hologen lights to use (H.I.B)
  93. Locked Ignition Cylinder 94 SL2
  94. Saturn Cooling Fans
  95. Car audio
  96. '95 SL1 Third Brake light works tail brake lights dont'
  97. Aquired a 94 Saturn...3000 rpm idle??
  98. semi-stall?
  99. Pulley
  100. has this been done yet im sure it has
  101. 95 SL2 wont start
  102. Sputtering.
  103. 94 SC2 Bad thumping in right tire
  104. oil pressure gauge
  105. bogging at idle
  106. gauges
  107. 96 SL2 Clutch
  108. hmmm build up or trash heap
  109. When does an engine need rebuilt?
  110. transmission?
  111. have $$ - need a hood from a '92 to '96 SC2 - LA area
  112. Engine cranks, but no fire
  113. Interior Panels for my 99 Saturn SL
  114. My car accelerates on its own....
  115. just a quick question
  116. 95 SL1 oil dripping out tailpipe
  117. headlights and dash lights
  118. loose shifter
  119. SL-1 2000 Automatic Transmission Problems...
  120. transmission removal
  121. 99 Saturn SL1,Radiator Cap location
  122. motor swap
  123. For
  124. SL1 won't start; low fuel pressure
  125. Prospective purchase of '95 SC1
  126. sc2 engine rebuild...just read it
  127. Help won't start
  128. question about 2000 SL1
  129. moisture in headlamps
  130. 1996 si1 how many miles will it go
  131. SL1 Engine Getting Louder
  132. 2 questions. Interior Lights & Sterio.
  133. 2000 sc1 jerks when slowing down
  134. I need a part name
  135. saturn engine swap 1992 sohc-1999 soch
  136. Looking for BodyKit Saturn SC2
  137. parts for 2000 SL1
  138. Sl1
  139. 2000 Sl1
  140. fan not working
  141. sterio in sc2
  142. intermittant instrument cluster
  143. SL2 Alarm problem
  144. 2001 Saturn SL1 throttle position sensor question
  145. Rattling in driver door
  146. Maybe i can help
  147. 94 sl1 stalls
  148. Suggestions for 95 Saturn sc2
  149. auto tranny to manual
  150. Need Some Help 92 SL twin Cam Clutch Problems
  151. FS 93 Saturn SC2 Orlando, FL
  152. High O2 reading, but PCM still sending rich command!
  153. High Coolant Temp and Low Coolant Warning Lights flashing
  154. 1997 Saturn SW1 Keyless Entry Programming?
  155. Saturn SC2 2001 clicking noises / check engine light
  156. spark plug
  157. cylinder head necessities
  158. Cutout switch for fuel pump
  159. sl1 rpm rising
  160. Ecu?
  161. race car
  162. 95 Twin Cam Trans wont shift warm
  163. not a fix
  164. Bought This From Ebay...... Urgent
  165. What is a (transaxle) shaft bearing?
  166. alignment
  167. valve cover repair
  168. Gas milage
  169. Stopping Funny
  170. Car Won't Start...Need Help!!!!
  171. 94 SL2 DOHC Engine interchange ?
  172. '94 SL-1 SOHC ----- Aftermarket Gauges???
  173. Struts with springs mounted?
  174. is it safe to remove?.....
  175. removing the dash cluster
  176. New Catalytic Converter
  177. 2001 Saturn SL-Help!
  178. Some Header Help Pleaseeee! Want some opinions on my car as well!
  179. belt tensioner?
  180. '95 SL2 for sale (engine work or parts car)
  181. what could be running my battery down
  182. what is the diff..?
  183. Oil system cleaners?
  184. WHAT ARE some good ways to get HP
  185. EGR Valve Options ???
  186. 96 Twin misses on start up
  187. 1999 SW1 Wagon opinions
  188. Key Stuck in Ignition
  189. ABS light comes on and off
  190. Vehicle Won't Start!!! Please Help!!!!
  191. Rapid clicking when accelerating/hard clutch release
  192. wheel squeaks after warm up
  193. Custom taillight help
  194. cylinder head and cam
  195. injector fuse blows
  196. 99Sc1
  197. Wierd rattle noise behind idler pulley
  198. Transmission probs?
  199. radiator hose
  200. Should I fix it or get rid of it??????
  201. 2001 SC2, locator/alarm keeps randomly going off
  202. Very rough idle in cold and after exhaust replacement
  203. 1992 motor swap sohc
  204. Non-functioning windshield washer pump...
  205. 99 SC1 check engine light
  206. 2000 SL2 MIL - EVAP system small leak
  207. what do I try now?
  208. No Dash Lights
  209. Installing new speakers, new deck, subs and an amp, would like some help please
  210. Car Stalls When Braking
  211. 150k service recommendations
  212. Rebuilt Tranny
  213. 94 sl2 hard start
  214. head gasket replacement
  215. Auto transmission mystery
  216. Shadetree mechanic without a tree....
  217. Need help, axle/hub
  218. sensor location
  219. 97 SL fuel pump problems -- again
  220. Problem shifting out of park
  221. Saturn SL Problems... :(
  222. Wipers are streaking
  223. Radio problem in 93 SL2
  224. slave cylinder help please
  225. answer and you get a cookie....
  226. One Hard Screw
  227. 02 SL turbo kit
  228. ?
  229. Need some parts bad, Please help
  230. Need Help Bad Please!!!!
  231. Slight Pause During Acceleration
  232. 99 Saturn Homecoming Edition, Tell me more about em..
  233. New Alternator, but....
  234. CV Joint dilemma
  235. SL2 Transmission swap
  236. Intermittent Start
  237. Just got a new ECT and car is still stalling...
  238. 1999 SC1 Type of Coolant?
  239. Horn problem
  240. shifter - maybe clutch?
  241. Need to find this part...
  242. Saturn Sc2 02 Radio Harness.
  243. running rich
  244. 99 SC1 Alternator Question
  245. Finding a vibration in the front
  246. Erratic RPM Indications
  247. replaced ECTS, still having same problem!
  248. Cannot shift my 1995 Saturn SL2...
  249. Those great headers need a great gasket kit
  250. 2001 sl2 down shift problem
