View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14
  1. 96 SL service light
  2. Odd, Odd Dash/Electrical Problem
  3. Looking to Trade 96 maxima for 95-98 sc1 or sc2
  4. 97 SC1 DRLs
  5. Fuel pump and filter location?
  6. Reverse Problems
  7. 98 Saturn SL Won't Start- New Battery
  8. Upgrading 96 SC1 with SC2 front end
  9. Exhaust Questions
  10. 1998 SL1 Engine Info
  11. 2000 Saturn SL1 Bulldog remote starter
  12. 96 saturn sl2
  13. wheel bearing
  14. plug missing electrode, going thru coolant
  15. custom headlights
  16. 96 SL-remove speakers
  17. Lost a gear
  18. 2000 Saturn Sl1 Remote Programing
  19. About how much for an ECT from dealership?
  20. changed the CTS and cleaning the IAT tomorrow...
  21. I think it may be possessed........
  22. Stuck and dont know what to do......HELP...
  23. security light,car won't start
  24. best place to mount a radar detector
  25. loud squeeling noise - not belt
  26. Wierd Horn Problem
  27. Need a new ECTS? Check this out...
  28. 2001 SL2 idler pulley prob
  29. Please help!! 1995 SW2
  30. automatic trans shifting
  31. 01 SL Cylinder 1 misfire after plug change?
  32. starter on 98 sl2
  33. 1997 sw:.. aif? afi? ifa? help please
  34. '98 SL2 stalls/hesitates @ 4000 rpm
  35. 91 SC running rich
  36. 1992 SC DOHC Cluth Problems
  37. gear configuration.. 97 sohc auto
  38. Ects
  39. Service Warning Light
  40. spoiler removal
  41. brakes drag...
  42. dropping a manual into my car
  43. New to the saturn family!!!!!!!
  44. wanna make my exhaust louder.. please help
  45. blinkers stopped working
  46. 2002 SC2. Car Starts and Stalls...
  47. 97 sl2 intermittant won't start
  48. 93 SL2 stalling
  49. Reset Service Engine Soon light
  50. tire question
  51. fast idle in drive,park
  52. Daytime Lights
  53. CD Deck Problem
  54. 1995 Saturn SL1 Heater trouble please help!
  55. 97 SL2 starting problem
  56. 1994 Saturn SL2 TC
  57. how much power?
  58. Wiring question?
  59. injen intake on saturn sl 2
  60. Check Engine Light Code 0404
  61. What size rims?
  62. 92 sc2 has a weird problem
  63. Newbie here, looking for help with SW
  64. 2000 SL2 ignition switch replacement
  65. Big Thanks to Y'all
  66. 98 saturn sl2 hard to start and get running from acelleration to first gear
  67. Electrical problem
  68. need help!! 1997 SL1
  69. tie rods
  70. uhhh ooooo
  71. 97 Sl2 starting prlbem
  72. does 93-95 SL2 Cen Rear LENS fit SL?
  73. Power?
  74. Mechanical Problems!!!
  75. 95/96 headliner/roof panel sl2
  76. '98 SL2, P0341 -"CMP sensor signal out of range"...after a tune-up job
  77. Blower Motor Only Works On High
  78. more power baby
  79. '99 SL2 radio display backlight out
  80. uses 2 qts oil in 2 week -SL2 97
  81. OEM parts
  82. 94 sl1 mechanic probs
  83. Sl1 94 sound system question
  84. Starting problem 95 SC1
  85. Differences between SC, SL, and SW ?
  86. timming chain
  87. 94 sc2 lifter
  88. 02 SL1 engine "ticking"
  89. 1995 saturn sl2 wont start
  90. Starting and running problems linked?
  91. P0133 02 Sensor and P1406 Emissions Controller Codes
  92. struts
  93. Strange startup problem
  94. Rear Defroster Problem
  95. valve
  96. 94sl2 needs help
  97. a huge problem..??
  98. Check Engine Light
  99. need parts for 95 sc1
  100. Service Engile Ligth is on after changing AIR Filter
  101. won't start/fuel gauge zero
  102. Removing A/C System
  103. Hp Sl2
  104. SL2 performance????
  105. how 2 get shifter knob off
  106. gauge pod
  107. 1997 SL2 Timing maps?
  108. '97 SC2 temp sensor
  109. Replacement Gauges for SL2
  110. How to install a cold air intake
  111. 95 SC2 Head Gasket
  112. Car won't start, just makes clicking noise
  113. '99 SL2 security system problems
  114. Electrical problem or what
  115. SL1 cold start problem
  116. goofy thing that happened over the weekend
  117. Speed mods for my 93 SC2
  118. My Wheel Fell Off!
  119. Thinking about a 01 sc2
  120. 02 SL1 OBD problem
  121. dead battery...dead keyless remote???
  122. 2002 sl1 1.9 soch (gurgeling noise from engine/trans
  123. Hestitates on acceleration
  124. looking for SL part
  125. can I save my radiator?
  126. 1994 Saturn SL1 acceleration Problems
  127. Anyone else have a leak into their 2002 SC?
  128. sl1
  129. Kick Panel Removal
  130. Seat Brackets for Racing Seat
  131. alarm install help
  132. I have a strange probem
  133. Coolant light
  134. Parting out a 95 sl2
  135. was i ripped off?
  136. 96sc2 wontstart bad mpg plugcarbonfouled
  137. 95 Saturn SL1 Headlight Questions **Please**
  138. 1995 SL2 Automatic Revving/Stalling etc...
  139. "new" 2001 SL2 tips?
  140. Musty Odor
  141. Start up problems
  142. 95 sc1 tranny or clutch problem
  143. Valve Train Noise
  144. Engine replacement '96 SL2
  145. shaving the head
  146. Air intake system
  147. 2002 Saturn SL1 cruise control???
  148. 95 SL parts Wanted
  149. parts interchange between sl-sw-sc
  150. 1997 Saturn SL1
  151. Advice: selling Saturn SC
  152. High idle when cold temps outside/moving but ok when stopped
  153. 2002 SL2 C/F Hood Fitting 97 SL2?
  154. 96 SC2 crank sensor
  155. Not another oil burning thread !
  156. Intake System Help
  157. HELP.. car cuts off when put in reverse
  158. 97 SC1 Service Engine Soon light
  159. sc2 window cleaning
  160. grinding noise?
  161. sl muffler help.
  162. code P0117
  163. '96 SL Clutch slipping
  164. Nasty Noise With Tranny
  165. EGR Question.
  166. looking for diecast models
  167. Bad Fuel pump?
  168. coilovers
  169. This clicking noise...HELP...
  170. Airlifts(airbags w/e you want to call them) for a 1997 saturn sl2
  171. 99 SL2 High idle at start
  172. need help from all u experts--rough startin' 95
  173. 1994 sl1 manual trans .. got probs
  174. cv joint
  175. Windsheild Washer
  176. body q?
  177. 1997 Saturn SL1. MUST SEE!
  178. 1996 saturn SL-2 rear window off track
  179. 00-02 SL kit update
  180. 1999 Saturn SL2 Instrument Cluster Removal?
  181. 93 saturn SC2
  182. How do I change the Water Pump on a 96 SL2?
  183. hmmmm
  184. Lookin For Hp
  185. grounding kit
  186. shaking at all speeds...
  187. high idle on 99 SL1
  188. hey guys
  189. brake rotors
  190. saturn sl 97 start up
  191. Trouble Starting
  192. Decrease In Gas Mileage
  193. spolier fine scratches
  194. motor swap
  195. oil pan gasket
  196. 92 Saturn With Oil On Plugs
  197. Car Accident 94 SL2
  198. Start Up Problems
  199. Glow Face Gauges... funny spot
  200. What Does This Code Mean?
  201. my 94 SL2 vs. a 99 SC2
  202. Me Again - 1996 SC2
  203. power seatbelt motor?
  204. Duals???
  205. Overcooling
  206. Sc1/sc2
  207. i need help with looks on my 1999 sl-2
  208. Locking with keyless entry causes horn to beep constanlty
  209. 94 SL 2, Power steering pump, Broken mounting bolt
  210. need help! engine check light with rough idle!
  211. im having probles with my saturn
  212. throw out bearing problems!!!
  213. 94 Saturn power window
  214. Idle problem, please help!
  215. saturn performance
  216. Hey engine and muffler fans!!!!!!!!!!!!
  217. Occasional engine lights
  218. how do u take door panels of a 1997 saturn sl2
  219. 2000 SL2 Spark Plug Gap
  220. 94 Saturn SL Fan
  221. Diagnostic Trouble Code P0137
  222. dip in rpm's in 2nd gear
  223. Shaking on rapid acceleration
  224. 1996 SC2 Problems, Help?
  225. Egr Valve.
  226. Service Engine light is on....
  227. Saturn sc2 Spark Problem
  228. euro lamps
  229. Speedometer problem?
  230. Compression check
  231. 2001 SL2 running hot and surging while driving
  232. '00 SL1 won't start
  233. please help, need 95 SC2 1.9L DOHC engine info
  234. 1993 SL2 timing chain or belt
  235. CV joints i think
  236. Check Engine Light
  237. help rough idle
  238. caster for '97 SC1
  239. Rims on my saturn
  240. Keyless entry for 98 SL2
  241. replacing '92 engine with '93 or '94
  242. 2001 SL1 Help!
  243. New Saturn Owner yay
  244. quarter mile times
  245. saturn leaks on passenger mat!!!!!!!!!!!
  246. why buy plastic?
  247. 95 Saturn Clutch
  248. '94 SL1 Acceleration problem
  249. 1993 SC2 loses power when switching gears.
  250. Flowmaster for a 97 sl2?
