View Full Version : SC/SL/SW
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. 95 SL! Loose Shifter!
  2. response to my first thread of curious
  3. curious
  4. 2002 sc2 info needed
  5. 02 Saturn SL2 won't start
  6. 95 saturn sl2 no start
  7. 95 saturn sl2 no start
  8. help with 97' SC turbo selection
  9. Codes P0301,P0507 2001 SL1 Help
  10. SC2 Steering Column Controls Loose
  11. Hole in intake manifold
  12. '01 SC1 won't start reliably
  13. Heater Core Help
  14. sc1 fogs up
  15. coolant low light
  16. window fogs
  17. 3rd gear '96 sc1 issues. the rest are fine. (wordy post)
  18. Sludge in Coolent Recovery Tank
  19. 1997 Saturn sl SOHC dies?
  20. Mileage
  21. Traction Control
  22. readiness monitors
  23. 1999 sl2
  24. DTC codes...
  25. p0711
  26. No Start on 93 SC2
  27. 1992 Sl Charging problems
  28. 00' SL2 Tempermental starting.
  29. P0410 code
  30. 94 SC2 Headlights out - Headlight switch?
  31. Crossed Jumper Cables...
  32. Running temp
  33. Air Pump
  34. 94 saturn sl1 hard hesitation
  35. Cars runs cool
  36. Brake Grinding
  37. Rear Hazard Flashers inop.
  38. 1997 SL2 Idle Cylinder Miss...
  39. 99 saturn Sl2 Front Brake Caliper
  40. service light (wrench icon)
  41. 94 Saturn heater fan
  42. P0133 Code
  43. 95 SL2 won't start
  44. 2001 Sl2 1.9 DOHC Burning Oil
  45. 1995 saturn stick wont start
  46. 2001 SL2 won't start
  47. 1996 Saturn will not start
  48. Egr
  49. 1997 SL wont start popping IGN3 fuse
  50. 98 sl2 1.9l dohc timing chain broken
  51. Timing Chain
  52. 1999 SC2 Shifting problem
  53. Installing Stereo/wiring 2000 sl
  54. 1994 SL won't start just click
  55. 2000 SL2 will not start
  56. 02 SC2 - Bogged down/suffocating - ideas welcomed
  57. losing power furthur up the tach
  58. Steering wheel / Rotor problem
  59. Parts Diagrams???
  60. 1992 SL good buy?
  61. 2001 saturn sl2 won't start
  62. 1997 SL serpentine belt
  63. Unidentified Strange Sound
  64. 1999 saturn intermittent start when hot
  65. Running now not later
  66. Coolant Leak 01 DOHC
  67. A/C clutch replacement
  68. Dex Cool Fool
  69. 1996 SL2 Won't Start - Electrical - Dash Lights Go Out
  70. Spit Sputter Die.....hard to restart
  71. 1997 sw2 won't start
  72. Crazy Security System/Radio Issue 99 Sl1???
  73. 1997 Saturn SL2-codes and what they mean
  74. Coolant fan issue..
  75. Turbine speed sensor
  76. Bad Starter - SL2
  77. 1999 sld automatic
  78. exhaust pipe diameter question
  79. Abs
  80. Coolant spitter
  81. how much trans fluid after i drain it?
  82. no horn?
  83. haha!!! just my luck!
  84. 1998 Saturn wont stay running
  85. '97 SL2 Clutch problems (go figure)
  86. 1997 SL1, High Altitude problems
  87. Need help asap!!!!!!
  88. 95 sc2 motor swap with 99 sc2?
  89. 96 SL2 wont start after running for a while.
  90. 92 Saturn SC2 Water Vanishing
  91. Fan always runs when the engine is running
  92. Muffler strap problem (99sl)
  93. problem starting my car
  94. 2002 sc2 engine codes
  95. 2000 SL2 emissions evaporator.
  96. 1996 SL2 missfire on 1 and 4 cylinder
  97. Still throwing codes at me
  98. advice on my cracked interior door?
  99. What can I replace the original headunit with?
  100. Clicking sound when braking - '97 SW1 w/Man. Trans.
  101. New problem. Window reg..
  102. 2002 Saturn SL Sedan Engine Knocking
  103. P0113 code after 25 miles of driving
  104. Need help
  105. Radiator is leaking - now what?
  106. 1997 Saturn SL2 A/C curious, yet annoying problem - HeLp!
  107. 1994 Saturn SL service engine light after running for a while
  108. Gost wipers
  109. Checking codes on a 94SL2
  110. Where is the starter located on a 98 Saturn Sl2 DHOC
  111. Perf/Norm switch 1997 saturn SL1
  112. Any special issues servicing antilock brakes?
  113. 1994 SL bucking when starting
  114. 99 sl1 wont start? Alarm problem????
  115. Transmission/Connector Wiring Diagram
  116. Engine compartment steamcleaning
  117. Need advise
  118. 98 SW1 would not crank
  119. No Backup Lights on 1996 SL2
  120. 99 Saturn SL Won't Start!
  121. 99 SL shifts but won't go?
  122. 95 SL Stuck in park WTF!
  123. 93 sl2 transmission problem?
  124. SL1 reception problem with new stereo
  125. 2001 SL1 Question
  126. 95 sl2 fan won't run
  127. SL2 intermittent rough idle in gear
  128. Sputtering and Stalling
  129. harsh shift in all gears----up & down
  130. 96 SL1 - Broken "Door Check Link". Can't Fin.
  131. 1992 saturn with codes 53, 48 and 26
  132. Shakey/Hard to Start
  133. 98 SC1 clutch cylinder problem?
  134. Re Ring ?
  135. 2000 SL2 Smoking while Idoling only
  136. 98 Saturn SL2 - how do I reset alarm?
  137. '94 sl2 electrical problem
  138. 1999 saturn sl 2
  139. slips b4 shifting into 3rd?
  140. 5 speed stuck in reverse!
  141. 2000 Saturn SL Outer door handle removal
  142. Valve Cover Leak
  143. My 1998 saturn SL2 wont start
  144. Key less Entry
  145. 1998 Saturn SL2 no start
  146. 1997 Saturn SL driving then just died and won't restart
  147. Service engine light
  148. 98 saturn 1.9 DOHC hard to start when cold
  149. Saturn sl2 engine diagram?
  150. How to prevent reverse shifting slam?
  151. Dead A/c
  152. Air Conditioning Valve...?
  153. 95 Saturn Sl start but stumbles
  154. shift problem
  155. 1999 SC2- Fuel in water
  156. 96 Saturn inspection monitors won't clear
  157. Cheap Magstar Racing Wire Set
  158. Help! Sc2 Rad Fan not running
  159. 99 Saturn
  160. A/C compressor and condenser...
  161. Rpms dip in Neutral
  162. 1996 SL2: no idea whats going on
  163. 99 sl2 ABS light
  164. 96 Shifting Problems.....PLEASE HELP!!
  165. Turbo 2001 Saturn SC1
  166. 1999 SC2 Won't start, stalls, radio presets lost
  167. A/C problem in a 97 SL2.
  168. 93 Saturn SL2 stalling more and more
  169. 98 SL1 wheel alignment question
  170. 94 sl2 erratic ticking high idle
  171. 94 Saturn SC 2 AC not working
  172. Short Ram Intake help...
  173. Intake Manifold 2002 SL2 DOHC Removal
  174. `01 SL A/C problem
  175. Manual transmission Problems 1998
  176. 96 SL1 Over-Revs at Start
  177. not firing on all cylinders.. my car either....
  178. install stereo?
  179. 95 SL2 Transmission won't engage
  180. 92' saturn sl pwr locks, alarm, and cigarette lighter won't work!
  181. 97 saturn sl starter problem
  182. 96 sc tranny problems please help
  183. Horn not working!!??
  184. Possible broken fuel pump???
  185. 1st vs. 2nd gen cars??
  186. Oil Consumption?
  187. 99 sl2 wont start
  188. 1997 Saturn SL not starting
  189. Advice: 1994 SW2 Alternator, worth replacing?
  190. 92 SL2 tranny into 94 SC2
  191. rebuild engine?
  192. Sounds like bucket of bolts
  193. anyone??????
  194. Steering Wheel Squeal
  195. need advice on what to do... 2001 sc2
  196. 1998 Saturn won't crank over, no pw. locks, radio, or cig. lighter
  197. PCV Valve?
  198. Possable to adjust speedo???
  199. 2002 LW200 ignition key won't turn
  200. 97 SL2 wont start Please Help ASAP!
  201. oil consumption
  202. 92 sc2 vaccuum leak?
  203. How Can I Stop My Trunk From Leaking When It Rains
  204. Passlock???
  205. 98 saturn sl2 stalls
  206. blinking battery light
  207. sc1 keeps blowing emissions fuse
  208. 96 SC1 code 301
  209. vibration?
  210. 94 sc2 won't turn on
  211. Unusual metallic sound many are stumped
  212. blower motor?resistor?
  213. Ami I missing an engine mount bracket bolt?
  214. '97 SL1 Engine Hiccup
  215. 93 Saturn SC2 High "Idle"
  216. 99, sl1, muffler leaking
  217. 1999 SL2 info
  218. 99 Saturn SL1, gauge needles
  219. 1999 SC2 Tire Size
  220. 3xgood start...then nothing. continuoosly
  221. No Tail light or Dash Lights
  222. 2002 SL2 EGR Problem
  223. 95 sc2 fuel filter??????
  224. Low cost LRR tires??
  225. Oil Consumption?
  226. Replacing struts
  227. Repairs after roll over?
  228. Very Little Heat???
  229. '93 SC1 won't turn over
  230. 94 Sl2 problem with power loss and battery goes dead
  231. Engine Cooling problem
  232. '96 SC2 Starting Problem
  233. 99 sc2
  234. '98 Saturn SL1 (manual) shifting problem...
  235. ABS sl2 1999
  236. 99 SC2 Engine Swap
  237. 2000 s engine blown!!
  238. 1997 saturn sl won't start
  239. 02 saturn SL2
  240. Vibration when idling in gear?
  241. 2002 SL1 - Help from someone who has one..
  242. cel code po442
  243. '98 saturn coupe sc2 start problem
  244. 95 sc2 wiper arm broken???
  245. interchange info for rear qtr panel 98 saturn SL
  246. 94 saturn fuel problems
  247. applique removal on 3 door coupe
  248. Gas in oil
  249. scanner
  250. Need Help with my 02 SL1!
