View Full Version : Aurora
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13
  1. Wow!! Dex-cool Vs. Green Antifreeze
  2. Horn Problem, 1995 Aurora
  3. Does Anyone Know For Sure ??
  4. Going Crazy
  5. help?????????
  6. Going in to A/C shop in the morning.
  7. speed sensor
  8. More on starting problems
  9. CV joint, wheel bearing, & A/C
  10. over heating, L47 engine
  11. fuel gage
  12. very intersting find about Aurora
  13. 98' door locks won't work (all of them)
  14. oil weight, why not 20-50
  15. 1998 Aurora cooling problem
  16. 1998 alternator question
  17. wierd!!!
  18. 1995 Aurora, rod knock (may part out)
  19. pwr driver seat problems
  20. '02 Aurora Nav question
  21. AURORA STOPS AT RED LIGHT, other info...
  22. recall question
  23. Yugo here,Yugo there, Yugo Everywhere
  24. Gurgling sun roof
  25. Heat Extraction
  26. AC Troubles 95 Aurora Need HELP!!!!
  27. 1998 aurora stalling with air on ???
  28. Recall for 95
  29. Steering wheel controls
  30. Automatic door locks won't work
  31. Tranny Issues
  32. Headlights flashing....again
  33. Stuck spark plugs- Help I can't get them out
  34. Starting Problems 2001 Aurora
  35. Help, I need to change out a motor
  36. Removing the Insert
  37. how remove cover over idiot lights?
  38. Change transmission fluid and oil NOW!
  39. should I change the tranny fluid?
  40. Engine Removal Tips
  41. billet steering wheel?
  42. took my Aurora in for the recall
  43. Blue Headlights
  44. Gas Mileage??
  45. Hard Starts
  46. help electrical problem with flashers
  47. Service Manuals on CD-on ebay
  48. Lamp Control Module Information
  49. Service manuals, What do they cover?
  50. Temperature blinking?
  51. Stability System???????
  52. 2001 Aurora-Check Gas Cap Warning
  53. Front Driver side Hub (spindle) replacement
  54. Air conditioning DIY, need advice
  55. will these wheels fit my 1998 aurora????
  56. 2001 Rear Seat Bench Removal
  57. Trooper Pulls Suicidal Woman Off Bridge
  58. Code 410 Stored Air Pump ?
  59. Radio Removal
  60. Wtb: Etcbm
  61. 1997 Factory Manuals For Sale
  62. What was that?
  63. Failed emission test
  64. Transmission Mystery
  65. Instrument Panel Not Working
  66. Diagnostic Codes Po 300 and PO 441
  67. Air conditioning problem
  68. 2 questions
  69. Question About 2001 Trunk Wiring Harness
  70. What's causing a chirping squeeking sound when I go over bumps and in turn
  71. disappearing oil
  72. engine codes?
  73. $1000.00 --95 Aurora--
  74. Aurora Collectable ?
  75. '95 Trunk Lid Disassembly Help, Please
  76. Any Advice At All PLEASE.....BEGGING
  77. Oil Opinion
  78. Security Light always on
  79. Need pages from 1995 Aurora service manual to replace drivers side mirror
  80. 01 front foglight problem
  81. Fuel Pump R&R
  82. oil pressure relief valve
  83. head lights flashing on and off
  84. where to put "hide-a-Key" ?
  85. damn recall
  86. Electrical Problems... NEED ADVICE!!!
  87. New England
  88. horrible gas mileage
  89. New dynomax turbo exhaust
  90. 2001 Tsb
  91. What can it be?1995 Aurora
  92. OBD code reader
  93. Desactivating the auto door lock system..
  94. Starting delay
  95. 97' Service Manual For Sale
  96. Where is coolant temp sensor 95?
  97. power antenna
  98. Goodbye Aurora Fans!
  99. ODB Help please.
  100. check engine light wont go away!
  101. steering wheel lamps in '96 aurora
  102. 1996 Aurora with new GM Northstar engine
  103. Lumbar support haunted
  104. Air-intake Mod. Question
  105. 20-22" RIMS ON 95 AURORA
  106. check engine light
  107. driver's rear side window doesn't work
  108. Happy Fourth
  109. Exhaust?
  110. Replacing a PCV Valve?
  111. outside temp going crazy.....
  112. Rough Idle
  113. power antenna doesn't go up (sometimes)
  114. For Sale: 95 Aurora $1000 -Pittsburgh, PA-
  115. under hood light???
  116. Tranmission Issues
  117. Adding CD changer
  118. Mouse In Steering Wheel...
  119. parts
  120. why mix coolant 50/50?
  121. 96 aurora manual
  122. Pressure wash
  123. Knocking under acceleration
  124. Dash AC Blower Knob
  125. Front Struts
  126. car redone
  127. Automatic Headlights 2001 Aurora
  128. Passenger Side Cornering Turn Signal Lamp/ How to replace?
  129. Water in the Foglight
  130. Fuel Pump Noise?
  131. Highway Shaking
  132. Power/reverse?
  133. Turn Signal Noise
  134. 1995 Waterpump
  135. book time - changing control arm bushings
  136. Inserted CD always sticks when it is hot outside
  137. '95 Drivers Side View Mirror Needed
  138. Is my rear caliper broken?
  139. Performance Computer Chip (PCM)
  140. need 95 parts, I have them!!!!
  141. Fuel Pump!!
  142. Towing Ability ?
  143. Necessary to clear / reset ABS after repairs?
  144. seen an aurora with hydrolics
  145. ACNA Aurora Meet
  146. Lamp Control Module
  147. Still Hestitating after all this work!?
  148. STB and Aurora/STS similarities
  149. Loose Door Trim
  150. Rear shocks IF I don't want air...
  151. bars leak
  152. Window Tint
  153. Instrument panel lights
  154. 95 Aurora - A/C Compressor
  155. Laboring engine
  156. Tail lights don't work
  157. Fuel rail recal and fuel pump preasure regulator
  158. seat belt won't retract
  159. Removing Rear Bearing Hub = STUCK!
  160. How to determinw hich abs/ trac control sensor
  161. Have to crank engine for a long time to start
  162. Where to get/best freon to use
  163. 1995 Aurora Spark plugs & Wireset advice
  164. pics of a 95 that didnt get recalled in time, trying to fix, anyone have a map?
  165. runaway idle
  166. Water Leak Right Front Passenger side
  167. Many Problems
  168. 1st Aurora God do I love this car but have some questions!!
  169. ANyone had the recall done yet? Any difference?
  170. Air Bag
  171. ABS Codes #35 & #36
  172. radiator flush
  173. front urethane bushing question
  174. Tranny Fluid Change
  175. AutoSound High Flow Cat installed
  176. NOx failure
  177. 95 fuel system question
  178. changing shifter nob
  179. Cabin Air filter
  180. 1998 Remote Programing
  181. Winter Driving
  182. Blower wont start?? ne help!
  183. engine code P 1350 and P 1375
  184. any advice for strut replacement?
  185. 80mm TB
  186. Water pump removal tools
  187. home link system for 1995 aurora
  188. wet rear drivers side floor
  189. Rack and Pinion
  190. help! w/console trim
  191. Cruise Control and Torque Converter connection
  192. cigerette lighter doesn't work
  193. What is a good price
  194. Engine swap
  195. Diagnostic Trouble Codes
  196. 1995 Aurora for Sale- 1st $1,000. Takes It
  197. What do you use to clean the inside of your car?
  198. A/C compressor r/r price???
  199. People with cooling problems - Read This
  200. a/c problems
  201. sideview mirror control's lights don't work
  202. A/C Condensor Replacement
  203. Physical location of RCDLR
  204. 98 Turn Light Switch
  205. A/C compressor replacement
  206. HELP!! popping noises on right turns
  207. Transmission Oil Life Display On DIC
  208. Torque Converter Drain Plug?
  209. Preferred Transmission Fluid Change Method?
  210. Cleaning Injectors? Beneficial or not?
  211. Bose Stereo
  212. Major power loss and spit and sputter at takeoff
  213. Plug Wires - here is part #
  214. Annoying shake
  215. Rear Brake replacement
  216. Hard Shifting into Park
  217. oil on spark plugs????
  218. Computer
  219. O2 sensors
  220. owners manual
  221. Just bought an Aurora
  222. clicking noise when turning right
  223. Anyone know of a good extended service contract?
  224. Are front bearings a maintenance item? Weird sound...
  225. Erratic RPM on start-up
  226. Trunk switch
  227. Recall notice
  228. Aurora Redesigned fuel rail
  229. release buttons
  230. Rear Sway Brace/Tie Rod
  231. Aurora struts replacement...which brand?
  232. rebuilt alternator
  233. battery replacement
  234. Silverstars
  235. replace engine or gaskets
  236. Slow to start
  237. Indy8 still around?
  238. A/C compressor removal?
  239. Stabilus trunk supports
  240. Aurora coolant leak
  241. Aurora Forums??
  242. acna
  243. accident
  244. over heating
  245. blower fan
  246. MPG and spark plug wires
  247. 1996 olds aurora O2 problem
  248. NAPA auto parts
  249. Noise from road/tires
  250. Broken headlight switch
