View Full Version : Aurora
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. Front Urethane Bushings......
  2. dead as a duck
  3. Oldsmobile Aurora 2000 mysterious oil leak engine
  4. Electrical
  5. 1998 spare tire
  6. Ravin Mufflers by Midas
  7. electrical question
  8. 32 v caddy vs. 4.0 aurora
  9. Heated seats
  10. T. control/Cruise
  11. Terrible Vibrations!!!
  12. Aiming foglights
  13. Brakes are thumpy!!! Brand new brake job!!!
  14. Electrical Problem on 96 Aurora
  15. 96 Aurora
  16. '95 4.0 1/4 mile time
  17. 98 hesitation, miss when warm
  18. Injector problems-'98 Aurora
  19. Keeps dying, but only when in gear???
  20. floor mats and homelink remote
  21. Turn Lights off
  22. Why no superchip for 96-99?
  23. Considering an Aurora, ? is 3.5 or 4.0?!
  24. Changing radio
  25. aurora vs. riviera
  26. Speed sensor question
  27. 95 subframe???
  28. 96 aurora hesitation problem
  29. Breaks and Roters for '98 Aurora
  30. Voltage
  31. Installing 12 Disc CD Changer
  32. Recommened Tires For 1998 Aurora?
  33. Weird Cooling Issue
  34. Help! did anyone has a used electronic unit
  35. extended warranty
  36. cooling problems
  37. Turn Signals do not work
  38. How big of a rim can I go?
  39. Engine Won't Start...STRANDED...need help
  40. Power Seat Fuse?
  41. Serpintine Belt
  42. Hello All...New To The Board
  43. tire pressure monitor
  44. Fuel Pump Fuse
  45. cam shaft sensor
  46. Stalling when idling at lights
  47. Ignition Key Problems
  48. 1995 Aurora - Time to get rid of it??
  49. Any Recommendations on Front Brake Pads
  50. 95 ran good, ran rough, won't start
  51. changing the right headlamp, lowbeam & fog lamp on 95 Aurora
  52. A really easy fix!
  53. heater blower
  54. A center brake-light...
  55. RSM Lowering Kit
  56. fuel gauge after fuel pump replacement
  57. Turns over but wont start!!!
  58. Major Aurora problems, need help/advice please with transmission+dash lights/gauges
  59. Chasing electric drains/shorts
  60. 2001 Aurora 4.0L OE Spark Plugs
  61. ipod set up for aurora
  62. Help Please!!!!!
  63. 350 HP out of the 3.5L
  64. Lights around stick shift don't light.
  65. new member
  66. Fuel Pump Preasure Regulator
  67. What Compares to The Aurora??
  68. 1998 & 1999 Auroras
  69. Tranny Fluid Change at 153,000 miles?
  70. Plugged Hole In Firewall on Drivers Side 1998 Aurora
  71. cd changer won't eject-help!!
  72. Noobie with Aurora problems
  73. Northstar in Aurora Engine Swap
  74. Need HELP ASAP - Fuel Rail Recall '95
  75. 1996-99 Engine Swap into a 1995 Aurora
  76. Opportunity to part out 96 Aurora
  77. Snapping sound from front passenger side!!!
  78. Olds Dealer Can't Find Problem
  79. factory head unit problems
  80. Why Can't I Hate This Car??
  81. Aurora runs away while idling.
  82. 1996 Aurora Rear Brakes
  83. tweeter removal
  84. what do you think about this?
  85. fuel tank screen
  86. Twilight sentinel problems & dashlights out
  87. Frusterating water leak / Help!?
  88. starter
  89. how long to warm up?
  90. Aurora is dead in the water - idler pulley seized up , shattered belt
  91. (k)no(w) when to say when ?
  92. 2001 Aurora Interior Lights
  93. Coolant Temperature sensor
  94. Wanted to buy - set of Aurora wheels
  95. Releasing the fuel pressure
  96. Fuel Injector(s) Replacement
  97. New Aurora, Good idea???
  98. Spark plugs
  99. Changing the 2 Crankcase Sensors easy?
  100. Question regarding Radio and CD Changer (use as aux input)
  101. fuel pump ???
  102. transmission swap
  103. ??? on 95 Rail Recall vs. 96/97 Rail Recall
  104. speakers
  105. Head Gasket
  106. lighting up the rear bar
  107. Brand New Engine
  108. Outside Mirror - Just the glass
  109. 1995 Overheating Issue
  110. burning smell + exaust white/gary smoke
  111. NorthStar?
  112. Button on Shifter
  113. 96 Aurora tranny
  114. Intake noise
  115. service engine light
  116. SS Brake Lines
  117. parking brake... how does it work??
  118. Making Progress
  119. Aurora suddenly lost power
  120. how often should I change my trans fluid?
  121. Whine and seat switch
  122. antenna modification
  123. Where to buy / How to replace drivers power window motor
  124. Front end Moaning sound
  125. '95 Aurora transmission shifting strange
  126. aurora parts
  127. 2001 Fog Light
  128. tranmission fluid change
  129. Front Axle--differential
  130. Hesitation Issues
  131. water pump replacement-won't budge
  132. Misfire in Cyl #3 - solutions?
  133. Accident Pictures
  134. Who has the most miles
  135. Starter and Intake Manifold
  136. water pump belt replacement
  137. Alternator Question
  138. when accelerating, surges??
  139. 96 Shift position indicator light out
  140. replacing control arm? Is it difficult?
  141. Razzi I think I seen your Aurora, or a twin
  142. Water in Trunck and Trunck latch
  143. CODE PO502 & PO503
  144. 95 Aurora - Transmission Mounts Problem
  145. Selling my Aurora $1500
  146. racing parts
  147. want to buy 95 olds aurora service manual, HELP
  148. Recall Question
  149. New Tire Problem
  150. Tire suggestions for 96 in Northeast
  151. Please tell Grandma how to disconnect the torque converter lockup solenoid
  152. seat problems
  153. suspension problems
  154. Grandma needs more help with Grandsons car URGENTLY
  155. Cooling mystery????????
  156. 98 Aurora Buring Oil?
  157. Loud Bang, white smoke from engine: Blown gaskets?
  158. Air/Fuel Performance Chips!?!?!
  159. Passkey Module Help For Oldsmobile Aurora
  160. Steering rack question
  161. Will someone answer my questions......
  162. Ride Control
  163. headlight question
  164. 2001 Aurora Transmission
  165. Master cylinder
  166. garage opener
  167. parting out aurora
  168. Aurora Engine Cover Trap Heat?
  169. Aurora Aftermarket
  170. headlight replacement
  171. Dash Lights Out?-Check rear Park Lmp Fuse
  172. Is it hard to change plugs and wires??
  173. 2002 Aurora V6 Starting Problems...HELP!!!
  174. Aurora Is DEAD!!!
  175. sometimes pulls to the right
  176. exterior lights or park lights wont go off
  177. Need DIS help
  178. Died twice now?
  179. Inheriting Grandpa's Aurora
  180. 1998 Aurora oil pressure problem
  181. Fuel Rail Recall
  182. Dash Lights Wont Work And Headlights
  183. Spark Plugs
  184. no power/rough idle/but new plugs
  185. control arm bushing-- where is it?
  186. Crank shaft positions sensors on 95 Aurora
  187. winter tires
  188. rear soeaker wire +/_ color ??
  189. Can AC Condensors Be repaired
  190. couple of problems
  191. Where Is The Temp. Sensor On A 95 Aurora Engine?
  192. Problems with 98 aurora
  193. what car to buy?
  194. Aftermarket seat heaters
  195. AC control unit not working on my car but will work on my friends car ....Please help
  196. 95 Aurora Trany acting really wierd or is it the ECM?
  197. Grinding Noise on Aurora
  198. Vibration in Steering Wheel ?
  199. aurora troubles
  200. Stalling when cold
  201. Loud pop in bottom left.
  202. Tips on fixing broken wires / harness driver door
  203. 95 aurora trannsmission issue. help!!
  204. Air Pump Noise
  205. Factory Radio
  206. exhaust Mods
  207. wrecked or ruined auroras
  208. how do i take the front door panels off??
  209. O2 Sensor Locations
  210. 1996 aurora 4 SALE
  211. fuel preasure regulator
  212. Wanted to Buy:
  213. Misfire and Hesitation
  214. how do i put up car pics on here?
  215. new info
  216. Delayed Charging / Alternator
  217. Grandson needs help with Aurora
  218. Chattering Wiper blades
  219. 1998 Aurora Factory Shop Manual
  220. door speakers, what size????
  221. 1995 Aurora-For Sale
  222. Squeak in the right front?
  223. First SPEEDHUT Order
  224. whats tha( EMIISION SYSTEM) MODULE CONTROL is for?
  225. transmission
  226. figured out the problem
  227. How to get rid of this SpeedLimiter
  228. Aftermarket Calipers
  229. Starting Problems
  230. On Star and steering wheel lights
  231. More Horsepower for 2001 4.0L
  232. 98 making noise in turn
  233. Parting out 1995 Auora
  234. Auxiliary power fuse #22 Aurora 2001
  235. Trunk switch/Dead wire
  236. Lights around stick shift don't light.
  237. It Won't Start But I Do Have Power...
  238. It Won't Start?????
  239. 1995 Aurora Part Needed Heater/AC Big Control Know
  240. Bose stereo amplifier.
  241. your opinions ???
  242. Trunk Layout....anyone else try??
  243. 95 Heater Problems
  244. i need the name or the part# of the silver box under the driver seat
  245. 1996 Aurora O2 Sensor Problem
  246. 95 Aurora - Drivers Side Door Electrical Problems
  247. license plate holder (bracket)
  248. Heater problem - where is the "blend box"
  249. recall completed
  250. heated seat not heating
