View Full Version : Aurora
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13
  1. 95Aurora TrackCont./Antilock lights both on
  2. Accelerator padle sticks!!
  3. new aurora owner
  4. Need Tourque Info.
  5. head lights dim occassionally 2001 Aurora
  6. Aurora fuel rail recall
  7. Any indicator on the dash that indicates "Park" "Reverse""Drive"
  8. Piston Slap?
  9. '96 Aurora engine miss
  10. replacing lights in steering wheel controls???
  11. Shifter light replacement..
  12. crazy control panel
  13. Front Door Speaker Removal??
  14. daytime running lights are bullshit
  15. crazy climate control
  16. DTC P0171, Need Help.
  17. Oil Change intervals using synthetics
  18. Heater/AC Fan Won't Stop Running
  19. 1996 Aurora Strange Problem
  20. Power Steering Pump/Hoses Procedure(s)
  21. creaking in steering column 2001 Aurora
  22. battery?
  23. 2004/2005 Aurora?
  24. New Member
  25. Loud wind noise (2001 Aurora)
  26. finding knob for radio
  27. OBD II Scan Tools, where to buy....
  28. Where is the flasher relay located ??
  29. Aurora Meets?
  30. Oil Pressure Drop
  31. Carfax
  32. RPM drop-off when coasting (30-40 mph)
  33. Trim on body chipping paint?
  34. OBDII Trouble Code Meaning?
  35. Engine "shaking" at idle.. running poorly
  36. Oil Pressure Question
  37. Changing front pads & cutting rotors
  38. Replaced Fuel Rail, Now Car Won't Start!!! Any Advice
  39. A few questions
  40. 2001 fog lamp replacement
  41. replacing strut bearing???
  42. fog lights constantly burning out!!!
  43. Front Pads & Rotors
  44. Two Questions - hopefully simple
  45. Coil Packs
  46. shift solenoids
  47. I was bad lol
  48. Bought 1995 Aurora
  49. A couple problems with the Aurora!
  50. Stupid Vent on Door
  51. Multiple Problems 95 aurora ANY HELP WOULD BE GREATLY APPRECIATED
  52. went to get 6x9's for trunk and...
  53. Where are the spark plugs in 98 aurora?
  54. 98 Aurora stalling out
  55. Why are the ABS and TRACTION CONTROL lights!!!!
  56. Where is fuel filter?
  57. Cassette Stuck Question
  58. huge fuel leak under the hood
  59. Confused newbie
  60. Interchangable Coil packs?
  61. Shudder when breaking at high speeds / pulsating breaking
  62. Waterpump
  63. best spark plugs
  64. does a 95 rim fit 97 aurora???
  65. Compression Help!
  66. Eibach drop springs
  67. ABS Diagnostic Error Codes (how to flash codes)
  68. I need help!!!
  69. door speakers
  70. wtf is wrong with my car
  71. Aurora audio, whose got something nice?
  72. Hot Engine Message Withpower Loss
  73. Aurora Engine External Dimensions?
  74. Autobahn Package In The Aurora
  75. water pump housing and heater core
  76. 95 Aurora Trans Mount (or Other Problem)
  77. how do you get the idler pulley off?
  78. Idler pully
  79. Ding, ding, ding
  80. rear window won't go down.
  81. '96 Low Oil Light
  82. Heater question
  83. 95 aurora electrical power will not shut off with key off
  84. Rain-x
  85. Electrical diagrams
  86. governer on 1995 Olds Aurora
  87. Keyless entry remotes and drop-in K&N for sale
  88. Steering column
  89. The fastest
  90. starter
  91. Dash lights - display lights wacky!
  92. whistling noise
  93. cigarette lighter
  94. Programming a second Keyless Remote
  95. power seat stuck 1997 Seville
  96. windshield washer fluid doesn't work right
  97. power seats memory???
  98. 95 Aurora acceleration troubles
  99. Tranmission Replacement
  100. 4.6 Northstar into a Aurora
  101. Are calipers and pads interchangable between?
  102. Denied Silverstars at Pep Boys
  103. Engine speed swinging during Idling
  104. Tachometer/Speedometer...and a few other things
  105. 99' Aurora question
  106. 95 Aurora - compatable parts?
  107. Water Pump Replacement
  108. dumb question
  109. radiator
  110. Water Pump Cam Pulley
  111. steering shudder low speed
  112. New here, need exhaust opinions
  113. Built-in diagnostic service mode?
  114. Waterpump Idler Pulley
  115. Service engine soon light?
  116. Question For Speedyguy
  117. 95 Aurora - Oh Boy!
  118. Oil Leak
  119. Keyless
  120. New Wheels and Tires
  121. Wheels and/or Tires For Sale
  122. Still Noisy
  123. Valve Cover removal / Spark plug and wires???
  124. central shaft in the transmission snapped in half
  125. RR Defroster
  126. Climate Contol Blower has a mind of it's own
  127. Keyless question
  128. That Chirp is DRIVING ME INSANE
  129. 95' aurora keyless entry
  130. smokes from under hood
  131. a few questions
  132. Can you tell Indy8 has the day off?
  133. electrical problem
  134. Battery Problems
  135. Rattling sound coming from A/C?
  136. passenger climate control knob
  137. new member here - quick question on ebay intake
  138. Anyone who needs a radiator, read this!
  139. Diagnotic codes through climate control center
  140. Power steering steers hard to the left
  141. INDY RULES - Another Question
  142. Message For Conundrum
  143. rear bumper skin 2001 aurora
  144. Why should I buy American Again?
  145. Eibach Springs?
  146. power antenna
  147. GM TSB for using Time-Sert aluminum bolts?
  148. o2 front sensor
  149. battery trbl or worse ?
  150. Engine control module......
  151. Random "Security" Light
  152. CHECK OIL LEVEL on DIC wont go away
  153. Aurora running hot
  154. missing and bad gas mileage
  155. How difficult is it to replace waterpump
  156. Whistle when cold and low RPM
  157. New Member...'95 Questions...
  158. delay windshield wiper '96 aurora
  159. Are my rear shocks gone?
  160. Fuel Rail (smell of gas)
  161. Starting my Aurora
  162. Strange electircal behavior, is it just the starter?
  163. quiet flashers?
  164. Traction Control Light---Low Tranny fluid???
  165. clicking from controler under seat
  166. hard to start when very cold out
  167. Noise at back of car
  168. Clean Key, Wait 3 Minutes.... getting me mad
  169. radiator leaks bad need info
  170. ABS System Questions 95' Aurora
  171. Theft System Fault
  172. wiper arm trim piece
  173. Blower control location?
  174. 95 Aurora stalls out at 70mph
  175. Headlights
  176. Water pump socket
  177. Lights are flickering????
  178. Aurora Service Manual
  179. Dash lights out
  180. 1997 aurora seat heater
  181. cruise control
  182. Heater Problem
  183. Starter Installation
  184. Another New Member
  185. Need advice on computer / transmission.
  186. Some questions
  187. how do I adjust high idle?
  188. Bose Stereo System
  189. Front passenger seat door controls don't all work.
  190. Will a '99 radiator fit into a '97?
  191. A few Problems - Please HELP!!!!
  192. Long List of problems. Should I fix or sell???
  193. Smoke from underneath car!!!!
  194. How do I test for codes? (95 Aurora)
  195. power mod ebay
  196. Belt Removal ?? Replacing Alternator
  197. new oil leak...need parts
  198. Heat Blocker Air Filter
  199. vibration
  200. Sticky Shifter
  201. 02 Aurora reliability
  202. coolant flush 1998 aurora
  203. ooh! sexy photos of cylinder heads!
  204. interior light problems
  205. Steering Wheel Controls
  206. hp ideas
  207. plug gap
  208. Running rough at idle and while driving???
  209. Traction, Traction who's got the Traction?
  210. Clicking from under the dash
  211. My passenger seat doesn't work?!
  212. Have a Great New Year everyone!
  213. okay dumb question
  214. Transmission only works in second
  215. Twilight Sentinel 97 Aurora
  216. My Exhaust Plans
  217. shudder at low speed turns
  218. Aurora power windows/locks
  219. Fuel gauge wackey
  220. rims and tires
  221. Extended Warranty
  222. speaker problem
  223. copying a transponder key
  224. Followup on alignment and popping noise
  225. what is this part?
  226. dirt accumulation under the hood
  227. 95 Aurora left parking lights don't work
  228. Total power loss and stall
  229. Headlight Replacement???
  230. Problem with Left Side Mirror
  231. Fuel Pump amd MAFS
  232. Transmission problem?
  233. transmission relay?
  234. Followup on Alignment and snapping noise when turning
  235. 1997 Stock Chrome Alloys
  236. Need help rough idle
  237. Hi Everybody!
  238. Noisey Serpintine belt
  239. 95 parking brake cable broken.
  240. '96 Aurora radiator
  241. subs and amp
  242. Tps
  243. Please Help INDY!!!
  244. '96 Headlight weirdness
  245. Crazy Tint
  246. rpm at speed check
  247. Transmission nightmare
  248. front end vibration
  249. 2001 headlight problem
  250. cupholder stuck in
