View Full Version : Aurora
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13
  1. 1st post!!
  2. Oh No :-( New problem??
  3. DIC gas gauge,speedometer, temp gauges not working
  4. bose screams
  5. VATS Problems
  6. Electrical Drain "95"
  7. How much can I sell a 95 Aurora for?
  8. 95-99 NEW power window switches
  9. spark plug gap?
  10. Performance chips
  11. Anyone Know about A/C????????
  12. Fire
  13. Anyone need 95-99 factory wheels?
  14. serpentine belt problem
  15. 99 shop manuals swap for 97 shop manuals
  16. Clear coat peeling - Any temporary/quick fixes?
  17. Ticking when A/C Is on?
  18. tranny problem P0741 2001 Aurora
  19. Please HELP
  20. A/c Compressor
  21. Window Thingy
  22. Brake troubles
  23. Replacement Brake Lines
  24. Have to change Transmission
  25. Muffler
  26. Roaring 1997 Aurora
  27. Bad Sound Front Drivers Side????
  28. Changing Dash lights
  29. Starter
  30. 95 aurora tranny problems
  31. Timing Belt
  32. ticking from dash
  33. Incorrect Outside Temperature Reading
  34. Side rear lamps (turn signal)...
  35. Name That Sound
  36. Wont Start
  37. A New POWER ANTENNA won't go down.
  38. No torque converter lock or overdrive?
  39. Looking to get rid of my Aurora
  40. CD Changer for '99 Aurora w/Bose System
  41. shuddering
  42. completeEngine Wire harness 97
  43. Spark plugs
  44. 98 electrical issues
  45. Allmost new Aurora Surges
  46. hummming noise
  47. Volts drop, engine stalls, lights dim
  48. Alternator help please
  49. factory radio questions
  50. Relays
  51. Anyone have this problem before??
  52. Overheating Problem!!!!!help
  53. neutral control switch
  54. Bose stereo cuts in and out
  55. Drivers window rattles
  56. Drivers power locks, lumbar, seatl does not work
  57. 97 Aurora FIRE
  58. rear view mirror please
  59. Tranny shifting woes
  60. Keyless entry programming for 01 Aurora
  61. 4.6 northstar
  62. interior trim
  63. Nutty Gas Guage
  64. '99 Aurora error code 741
  65. sputtering
  66. Exposed Anti-Lock Brake Wiring
  67. oil pressure
  68. Turbine Speed Sensor
  69. Coolant Flow
  70. alternator issue?
  71. Windows jam
  72. Check engine
  73. steering wheel size
  74. Fuel rail recall~~Is it too late???
  75. HID Headlights
  76. Door Wont Open..... Help!!!
  77. pnp
  78. security
  79. Snapping sound from passenger front side
  80. air ride auto leveler
  81. Error Code 741
  82. Reset computer??
  83. trunk release
  84. oil filter
  85. 1995 How Many Miles?
  86. passenger window sticking
  87. 1998 RKE compatibility?
  88. Stuck bolts on front hub assembly
  89. RSM Lowering Kit for 1995-1998
  90. Antifreeze
  91. There's a Set of Service books on eBay only $90.00
  92. Is there an adjustment for the gear shift cable?
  93. Turn signals won't work
  94. anyone need a foglight bulb?
  95. Cracked bumper
  96. vent no blow
  97. gas gage gone wild
  98. Cracked head
  99. 4T80E downshifting or will not shift
  100. Tranny down shifting check engine light
  101. Recall
  102. 95 motor into 96 / manual
  103. no info on waterpump
  104. New steel fuel rail-vapor lock
  105. Pcv Valve
  106. Rear Speakers
  107. where can I find a listing of Olds or Caddy Dealers near me
  108. clunking
  109. Replacing waterpump
  110. Fuel Injectors
  111. Tune up
  112. Idle Surge Problem PCM?
  113. Safety Switch
  114. Protect Mode Or Neutral Safety Switch
  115. 95 Aurora Overheating Problem - HELP
  116. Buick lucerne= aurora ?
  117. 1998 Aurora OEM Floor Mats
  118. Car now starts but having some other issues
  119. waterpump
  120. gonna buy new tires help???!!!!
  121. Changing the radio
  122. aurora weatherstripping
  123. Replaced motor & tranny but won't turn over
  124. hard to start
  125. Mounts, O2 Sensors, CV Joints
  126. custom ignition
  127. Climate Control Possessed!
  128. Radio prob aft keyless FOB programming
  129. Changing ignition coil
  130. 96 aurora, won't shift to OD, seat problems?? Thanks!
  131. Thermostat replacement
  132. oil use
  133. Button on shifter sticking
  134. Change To Synthetic Oil?
  135. Voltage
  136. I want more bass in my bose sound system
  137. EGR question...
  138. PASSKEY ll module
  139. another overheating question
  140. reverse lamps
  141. Transmission Problem
  142. ABS speed sensor harness
  143. Door chime contact ?
  144. Which Ac Delco Rear Air Shocks?
  145. Lights Dim when Brakes applied
  146. engine light code: crankshaft timing is off
  147. Repair manuals
  148. What's the psi that you fill the tires to?
  149. Hacking the Aurora...
  150. Heat question
  151. Fogs up in winter
  152. Where is the ECM?
  153. Unknown Powertrain DTC???
  154. Check Charge System
  155. Re-doing the cloth upholstery, what are the prices?
  156. New Stabilizer bar info for the classics.
  157. New radiator, new warning message...
  158. Surging, Bucking, Backfire
  159. wipe key wait 3 minutes
  160. Wheel bearing problem ???
  161. removing idle speed motor
  162. help
  163. how often do I change Trans. Fluid?
  164. Oil Level Sensor
  165. Transmission
  166. Better gas milage?... ANYONE?
  167. Reseting The Dic
  168. cooling question
  169. Engine swap 95 to 97
  170. Climate control dead
  171. How much oil in a 95 Aurora?
  172. Cruise Control
  173. custom air filter
  174. Buying Plug Wires & MAFS
  175. removed catalyst converter
  176. Passenger seat problem
  177. Stalling At Stop
  178. idle problem while warming up
  179. 97 wiring diagram HELP!!!!!!
  180. coolant temp sensor
  181. turbine shaft speed sensor question
  182. tach bounces stalls
  183. problems
  184. amplifier question
  185. Air ride compressor for a 95
  186. 1998 4.0 "Knocks/Tics"
  187. Miles Annually
  188. custom air intake
  189. 95 old aurora noise after shutoff
  190. Sunroof/Moonroof what do you think???
  191. Adjusting Voltage?
  192. Outer door handle replacement?
  193. engine noise what is it?
  194. passkey system fault
  195. what motor oil to use
  196. Non-Air Shock Rear Replacements...?
  197. no abs light or trac control
  198. stalling problem easy to fix....or should I stay away...
  199. Ignition module may be bad no power
  200. Twilight Sentinel does not work
  201. Stalls when warm
  202. tranny Slip
  203. 1998 Aurora owners manual pdf?
  204. Buffed up olds
  205. Temp at 240
  206. power window problems
  207. speed sensor failure
  208. New Axle Too Long?
  209. Track1
  210. Brake Pedal Fades, 95 Aurora
  211. Gm Th400
  212. Power-Steering Leaks
  213. T. control, and abs light
  214. help please!!!
  215. powering steering gone (reads CHECK SYSTEM CHARGE)
  216. Serpitine Belt
  217. Passenger Door will not open
  218. Just Bought My First Aurora
  219. A/c Compressor
  220. 255/50's
  221. Sounds Like Lifter Noise( Help )
  222. Power Steering Issues
  223. clicking noise in dash???
  224. sticking gas pedal
  225. I Have Parts
  226. Which mufflers have the lowest frequency
  227. Front end
  228. 97 Aurora - What do you think???
  229. seatbelt retractor for 96 aurora
  230. nutral safety switch
  231. aurora club
  232. Good price for front end work???
  233. 2002 Front suspension feels loose
  234. Car stalls when driving
  235. Turn Signals are Winding Down
  236. Crappy Editing Pics
  237. ding ding ding
  238. cassette adapter problems
  239. dipping tachometer
  240. ipod setup option for aurora
  241. headlights
  242. Input/Turbine Speed Sensor...
  243. Idle Problem Help!
  244. top of motor
  245. Check engine light after replacing fuel pump!!!
  246. Check Engine
  247. fuel rail not holding pressure
  248. How do you Change the Alternator in a '97 Aurora?
  249. abs sensor / computer chip out
  250. Trunk switch
