View Full Version : Aurora
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13
  1. Intermittent Air Conditioning
  2. 2001 water leak on drivers side floor
  3. 2001 Aurora
  4. 95 Aurora - Dead Stall in Reverse
  5. Need Help..
  6. Passenger side turn signals don't flash
  7. harder start when hot
  8. Thermostat gasket
  9. Is a 1995 Aurora A good Buy??
  10. Need Help..
  11. Charging System Problem (02' Aurora)
  12. Help!!!!!!
  13. 97 aurora fogging windows problem
  14. God, I scr**ed that up. Hole in my PS pulley
  15. 98 aurora missfire
  16. Idler pulley gone bad
  17. Power Steering Pump Removal and Installation
  18. 2001 oldsmobile aurora crankshaft sensor
  19. Still Having Heating Issues
  20. Need Help finding Parts
  21. i whant a custome body kit
  22. Reverse lights inoperable
  23. Help! no heat in my new car
  24. Aurora lettering emblem on taillight
  25. new ecm....new problems
  26. PO741 Torque Converter Clutch Stuck Off HELP
  27. computer problem
  28. Engine spins, but won't start
  29. '95 Aurora "Blue" smoke out of exhaust..help
  30. no heat
  31. Need help
  32. '96 heavy transmission leak
  33. 2001 Power Steering Problem
  34. '96 Aurora - washer fluid loss
  35. '95 Aurora stays in only in 2nd gear
  36. battery voltage
  37. Repair rear shock air lines
  38. 2001 3.5 Aurora - Rear Valve Cover Leak
  39. 1998 aurora drivers seat
  40. Questions from a new aurora owner
  41. ecm or tranny???
  42. HELP!!! 95 aurora guages not working
  43. '99-headlight flicker & fuel gage erratic
  44. Autobahn Tranny Problem?
  45. 1998 Aurora - Fuel Rail Leak
  46. 95 Aurora
  47. No Heat
  48. Problems help please
  49. Headlights?? '97 Aurora
  50. Progamming a 2001 Aurora Key FOB
  51. Water Leak
  52. Oil Pressure problem
  53. 95 Aurora won't start or crank
  54. Tapping noise after turning off the car
  55. grunt on start up
  56. Replacing Side Bulbs
  57. testing fuel pressure regulator and crankshaft position sensor
  58. Still not working
  59. 2001 v6 surging, stalling, and tach issues
  60. Warranty for Emissions
  61. aurora mpg
  62. Coil Pack Screws-Change Plugs
  63. My car - im lost =(
  64. 2002 Aurora key fob programming
  65. Are these lights good or no good
  66. Fuel Door, Trunk Release Not Working
  67. leather seats
  68. rear shocks air kit
  69. Ball Joint Rubber Boot
  70. Front struts
  71. Parking lights wont turn off?
  72. '95 Aurora-Transmission Leak
  73. head gasket blown wondering the best stuff to keep the car going befor i get a new on
  74. 2001 Aurora Speedo
  75. Rear Air Shock Hissing
  76. heater not blowing
  77. driver seat locked in position please help me
  78. Temp display Heat/AC controls quit working
  79. nead help with pully on cam shaft
  80. 99 aurora rough idle
  81. Aurora Vented Battery - Where to Find?
  82. High Oil Pressure
  83. belt routing diagram
  84. 1995 Fans wont turn off
  85. 97 aurora delayed start when turning key
  86. 98 Aurora Neutral Start
  87. Steering Rack
  88. boiling trans fluid
  89. code readers (scanners)
  90. high RPM's, Trans wont shift out of 1st, help please
  91. Aurora Tail lights, Dashboard, Fog lamps, Turn signal, Headlight and Cruise Fixed!
  92. Battery discharging
  93. turbine speed sensor
  94. Sounds in my Aurora
  95. oil leak
  96. Fuel Question
  97. instrument panel and DIC
  98. 95 power window intermittent
  99. 95 aurora
  100. exhaust tips
  101. 1995 Aurora motor/transmission issue
  102. 1995 unknown problem
  103. Dying at Stop Signs
  104. is it me or there's something wrong with the car
  105. Plugs & Wires - Aurora
  106. 97 Aurora, Traction/ABS/ Check Engine Lights On
  107. Engine service soon
  108. 95 Aurora-Need Help From Mechanic
  109. Lighting Very Screwed UP!!
  110. Solved - Burning smell through vents
  111. Hard Shifting at startup
  112. 13 nuts to remove front radiator cover?
  113. A/C unit stays on.
  114. Differences in ECM .. PROM only?
  115. New Trans or New ECU
  116. low low coolant
  117. 97 aurora no start
  118. Burning smell through vents
  119. 99 aurora heated sets
  120. front seats removal
  121. no heat on passengers side
  122. clicking from power window
  123. 95 Aurora rough idle, surging
  124. Window Cable??
  125. Aurora traction control
  126. tapping noise in engine
  127. steering position sensor
  128. 02 has no 4th gear
  129. Intermediate Steering Shaft
  130. 95 aurora air pump
  131. oil cooler lines
  132. 95 Aurora- Which Fuse?
  133. jet performance module
  134. whining moaning sound front left
  135. gas gauge problem & oil leak
  136. rear shock
  137. 1997 Aurora--Running very Hot--tried several things __HELP
  138. shaking while driving and braking
  139. Need new radiator...Suggestions?
  140. Hard Starting, not sure its the FPR
  141. $28 intake
  142. seat control problems
  143. 95 Aurora-Help From Great Auto-Electric Specialist Wanted
  144. Passenger window switches don't work?
  145. 95 Aurora idles rough and hard starting.
  146. Can I Unplug The A/c Compressor
  147. Grinding noise coming form A/C?
  148. Many "How To" write-ups
  149. 97 aurora tune up
  150. rack
  151. '99: Some Problems - Radio, and A/C
  152. Problems Charging the A/C
  153. Battery Life, Just had to share
  154. 1996 Aurora Trans Issue
  155. what is this little box???
  156. '97 washer fluid tube connector
  157. AC delay problem
  158. Coolant Leak Problem
  159. need headlight parts 95-9
  160. Just got my baby - couple problems
  161. 95 Aurora Water pump HELP, PLEASE
  162. Water Pump Leaking - Need Help?
  163. Code 119 Injector Open or Shorted
  164. Bank 2 Sensor 1 Oxygen Sensor location and removal
  165. Looking to buy 99 Aurora
  166. Runs Bad when Hot
  167. New Member 95 Aurora many questions
  168. 1998 Aurora AC compressor noise.
  169. Blower Growl
  170. Transmission
  171. Preparing to Replace a 98 Aurora Water Pump...
  172. recent repairs did i get took???
  173. fuel filter
  174. P0101 MAF Sensor
  175. aurora ns v8 supercharger
  176. Transmission exchange
  177. where to find used aurora parts??
  178. drops back to 2nd
  179. 01 aurora pcv valve
  180. Sticky Gas Pedal
  181. Aurora Engine Dies/Sporatic Electrical Issues
  182. Code P0410?
  183. Confused
  184. Headliner rattle
  185. Camshaft sensor, Need Help
  186. The Air Conditioning System
  187. parking lights won't turn off
  188. PK2 Passlock 2 system failure and bypass proceedure
  189. whats your oil pressure?
  190. Might be getting a 99 Aurora today
  191. front end problem HELP
  192. Front end noises
  193. Loud Rubbing Type Noise When Steering
  194. Crank shaft positiong sensors
  195. Need Info on 2002 Aurora
  196. 1999 Aurora hard starting
  197. 1998 Aurora
  198. Front Wheel Bearing Assembly - lubricate spline?
  199. 2001 plug gap Aurora
  200. A/C Won't Work
  201. 1997 Aurora Transmission Slipping?
  202. Oldsmobile Aurora
  203. 1998 Battery Location
  204. MAP sensor Specs
  205. running some wires??
  206. turn signals
  207. Water Leak at Firewall
  208. Where is the ECM/PCM located?
  209. 1999 aurora needs new air compressor
  210. radio reinstalled now car wont starting
  211. Dash lights out
  212. ac problems in 95 aurora
  213. certi trans problems in 95 aurora
  214. Caddy 4t80E swap
  215. 1997 aurora starts then dies.
  216. Complete Electrical Failure
  217. Air Conditioning clutch not engaging?
  218. Traction Cont., Abs Light, Bad Rotor
  219. AC & Temp display
  220. Need Info on replacing alternator for 95 Olds Aurora
  221. how do i find out right transmission
  222. Service engine light and O2 sensor
  223. Time to charge A/C??
  224. Throttle Position Sensor / tranny jolt
  225. Bearing 'Thump'?
  226. 95 shifting problems, PCM or Selenoids?
  227. 1998 aurora riviera service manuals ORIGINAL
  228. Outside Driver Mirrow
  229. 1996 Aurora how to program key fob remote
  230. Removing DIC and Climate Control
  231. FPR replacement with Steel Rail
  232. A/C Question... need to replace condenser?
  233. Stop dinging you stupid car!!!!
  234. 95'- need code read. Paperclip an option?
  235. 95 Aurora-Service-Engine-Soon light OFF
  236. Front End Noise
  237. 95 aurora poor acceleration / milage
  238. body parts needed
  239. windows
  240. 96Aurora 4t80E trans
  241. aurora fluctuating gas gauge
  242. A/C Compressor/Condenser Repair Question
  243. A/C Recharge/Refill problem
  244. 95 Aurora- Service Engine Soon Light
  245. Important: New and Old Members Please Read
  246. 345 hp aurora
  247. 1st Aurora, good deal but a problem
  248. Repeated Stalling at Stops!!!
  249. '95 Aurora-electrical/starting problem
  250. Steering wheel locked up, Service Engine Soon light, Flickering head lights
