Blower wont start?? ne help!
luisguzman23
06-14-2004, 02:57 PM
Ok, The blower on my 98 Aurora went out. or at least i think it did.
If I turn the controls to the on position but it wont shoot any air (hot or cold) But I know the AC & Heater are working. Now My questions is how can I replace the Blower motor & where is it located.
Any help or comments are very welcome
Thanks,
Luis
Bill V
06-14-2004, 10:08 PM
If you have no voltage at the blower motor, the most likely culprit is the blower control module. They tend to go out without any warning...
luisguzman23
06-15-2004, 08:06 AM
Thats a good idea but, this might sound like a dumb question, But How do I gain access to the motor and control module??
Bill V
06-15-2004, 09:23 PM
They are on the right side of the dash behind the glove box area. Remove the right close out panel (2 7mm head screws), stick your head under the dash, and look up... ;)
LarsBars
05-26-2006, 01:23 PM
Does anyone know where to buy a control module, besides the dealer?
55624096
05-28-2006, 11:42 AM
Lots of Auroras in junk yards now. The insurance co are totalling them so there are plenty. Great place to find expensive parts at low price.
newscarver
05-28-2006, 06:36 PM
heres a tip ..when you get that cover above the passenger side foot area off you will see the blower motor..with the blower turned on full grab the bottom of the motor and feel around for 2 small rubber spots and give them a sqeeze the motor may begin to work again when you monkey around with the field...it saved mine and continues to work although it somtimes needs a jolt to get it going again
baron1701
05-30-2006, 11:30 AM
I Have My Wife Kick The Plastic Panel, Not The Best Solution But It Works Until I Replace The Blower Motor.
diecast_man
05-30-2006, 01:51 PM
Sounds like the blower motor is frozen up. The shroud that the blower motor mounts to, the area gets water in there. It messes up the motor. Look for a drain plug which gets plugged every year. Clean out the drain line and see if helps.
diecastman
baron1701
05-31-2006, 07:07 AM
Has anyone pulled the motor out and cleaned the inside with electrical contact cleaner? I pulled it a few weeks ago, but didnt get a good look.
