Service Manual?
90Jeep
10-05-2004, 02:29 PM
Hey,
I am going to be working on the brakes in my 90 Jeep Cherokee Laredo this weekend and was wondering if there are any online service manuals?
tgrudzin
10-05-2004, 03:58 PM
Rear?
Remember, the longer shoe of the two goes to the rear of the vehicle. Front?
Brakes pads are mostly the same. Except for the wear indicator. Open the bleed valve to push out the old fluid, versus sending it back into the system.
Most public libraries have books you could copy the page or two you need. I suggest, if the rear brakes, you look and try and draw what you see from examining your own brakes. Then, go to the library and find the drawing of the brake system that resembles yours. When you take it apart, lay the pieces on the floor in an order that resembles the way they were put together. Lay the forward shoe forward, the in-board pad in-board. Spring parts in order. Do one side at a time.
Get a separate tray for all the little parts that come off. New spring kits are really cheap. Purchased them. Remember, you are saving the money doing the labor, and probably better than 50% on the parts. Don't get too cheap in doing the brake job. A second can of brake cleaner or a bigger can of brake fluid is cheaper than going to the store a second time. On cheating on it.
Ted
90Jeep
10-07-2004, 07:50 PM
Thanks for your advice Ted!
d_lay123
10-07-2004, 08:41 PM
I was able to download the entire manual for my XJ at jeepforum.com
UPDATE: The link doesn't seem to be there anymore..... If I find it again I'll post it. Sorry guys.
glennco1
10-08-2004, 11:53 PM
affirmative, alldatadiy.com They have full specs in there for everything. It costs $20/yr, but I find it invaluable.
dickboren
10-17-2004, 11:01 AM
They have a lot of information and diagraims on line.
fredjacksonsan
10-22-2004, 09:50 AM
Digital pics of what you've got in there, after you take off the drum but BEFORE taking it apart helps out, if you don't have anything else.
AnAlphaMan
10-23-2004, 03:00 PM
I found this in another thread earlier today that I think will have all you need...
http://4wheeldrive.about.com/od/jeeprepairmanualsdiagnostic/
Saudade
10-24-2004, 11:50 AM
Seems like the links to the FSMs from 4wheeldrive are dead ends.
d_lay123
10-27-2004, 05:03 PM
I knew I saw them somewhere......:bloated:
http://www.lunghd.com/Downloads_and_Links/Downloads.htm
d_lay123
10-27-2004, 05:08 PM
I gotta believe your breaks are done by now, but anyone else looking can look here also...
http://jeepin.com/features/drums/index.asp (http://jeepin.com/features/drums/index.asp)
http://jeepin.com/features/discs/index.asp (http://jeepin.com/features/discs/index.asp)
http://go.jeep-xj.info/HowtoFrontDisks.htm (http://go.jeep-xj.info/HowtoFrontDisks.htm)
http://go.jeep-xj.info/HowtoRearDrums1.htm (http://go.jeep-xj.info/HowtoRearDrums1.htm)
Cam7
10-30-2004, 05:48 AM
Tyr this site www.billhughes.com/jeepbookmarks.
Bushpilot1
11-25-2004, 11:38 PM
:shakehead Link does not seem to work, or am I doing something wrong?
Cam7
11-26-2004, 09:37 AM
www.billhughes.com/jeep_bookmark.htm I might have coppied wrong.
Bushpilot1
11-26-2004, 12:35 PM
:grinyes: Now that link works fine with the _ in it instead. Thanks, apparently they don't have the 89' FSM & the dealer says these are not available. Any further hints or help would be greatly appreciated. Bill hughes site is a wealth of information though too, thanks again. Good reliable info is hard to find anymore. Jim :smokin:
