1989 cherokee abs conversion
89ltd
11-26-2004, 11:55 AM
My abs pump does not work, I just bought the rig as is so I really don't know what else is screwed on the abs system. It is not on the road yet so Chrysler will not fix it. I pulled the booster and proportioning valve off an 88, also the coolant tank for $45. Ordered new master cyl. for $36, (canadian). I just checked the bolt pattern from the 88 and everything looks good. This is going to take me a while, on and off for a week as I have to do the lines and the rear brakes as well. I will keep everybody posted along the way.
Jimmmmmmmmy
Jimmmmmmmmy
scuba4321
11-26-2004, 09:22 PM
good luck :ylsuper:
89ltd
12-01-2004, 08:50 AM
Okay, I ripped all the abs stuff out, clean up, sanded and painted the booster from the 88 non abs unit. I just finished installing it last night, I put the combination valve and lines in first then the new master cylinder. Was not as hard as I thought it would be. Everything lines up and bolts up nice. Who wants all the old abs crap. I had to snip the wires from the sensors in the wheels, couldn't remove them as it would leave a hole in the backing plates. I put my garbage out on Sunday nights.....
89ltd
12-12-2004, 12:34 AM
Everything is finished. Same brake light switch, pedal bolts up nice to the 88 booster's rod. They seem to work fine, how ever, the pedal sits a bit lower than before. Something I will have to get used to. If I were to do it again, I think I would have also replaced the combination valve, as this one is 16 years old, don't know how long they last or if they ever wear out. I am satisfied with how the project turned out and feel much better about having a reliable system in place.
Redline_7000rpm
01-24-2005, 05:45 PM
I was wondering if you needed to change anything inside the ltd. ie:brake pedal swing arm, inner mounting brackets for said arm, etc...
I had the same job done last summer at a garage and they told me it was normal for me to have no "feel" of the brake pedal. Whether I brake soft or hard I get no feedback from the pedal at all. I can lock up the brakes without feeling any backpressure on the pedal. It kind of floats, something like the feel of the gas pedal. The only ressistance I get is when it hits the floorboard, and by then it has locked up a long time ago.
89ltd
01-24-2005, 06:45 PM
I didn't change anything inside at all, everything lined up perfect, the only thing I have left to do is to replace a faulty master cylinder I bought for it at the time of the conversion. I have been driving it , the pedal feels pretty good, how ever it is a bit low, I am still getting some air in the lines though and I believe its the rebuilt master i bought for it. I'll keep you posted.
jeeponthebeach
03-06-2005, 05:50 PM
Jimmmmmmmmy
what causes the pump to stop working? mine is currently purging on and off as if it is trying to pump up pressure??? i have read quite alot about the braking system on these cherokees maybe if i catch it before it dies a simple sensor or pressure releif valve can be changed??//
Jimmmmmmmmy
