View Full Version : Elantra | Avante
Pages : 1 2 [3] 4
  1. 2000 Elantra
  2. 1996 elantra, Alternator or voltage regulator?
  3. 2001 hyundai elantra po456 code
  4. raising compresion on 98
  5. 2001 Electrical Meltdown
  6. Air conditioning
  7. Type of power door lock
  8. How to get out the battery?
  9. Computer Gone BAd!!!
  10. steering wheel wiggle
  11. Eectrical problem
  12. down to 14 mpg on my 02 elantra
  13. Hood spacer bolts
  14. HMA Service site...
  15. '99 power window problems
  16. 97 Elantra: Where is airbag control module located?
  17. Power Window (PLEASE HELP)
  18. timing belt replacement
  19. Elantra 2001 in accident. Check out the pictures
  20. Spedometer Cable
  21. starter
  22. I just got a 2004 Elantra GLS
  23. Taking advantage of 100 octane fuel?
  24. 02 elantra cluster question
  25. F/S Elantra Sunroof wind deflector - Lets Discuss
  26. window problem/door panel removel
  27. I've noticed
  28. 2000 Elantra horn problems
  29. Elantra 92 1.6i DOCH ECU pictures
  30. 1997 Hyundai Elantra Differential Torque Specifications
  31. 95 elantra wont start
  32. Hyundai Elantra
  33. Noises coming from front brake area
  34. Aftermarket Shift Knob Help
  35. Aftermarket CD Player
  36. Should I get Hyundai CD Player?
  37. replacing clutch
  38. ?
  39. Cruise controll... and clock =)
  40. Idle surging? idle problems
  41. Oil pan bolt size...
  42. considering purchasing 2005 Hyundai elantra gls... anything i should be worried about
  43. ??
  44. Horn Location
  45. AC problem?
  46. Dreams
  47. bleed point for coolant/radiator, if there's one. 98 Elantra.
  48. Where can I find the Cast # for a 1992 Elantra head?
  49. 92 Elantra Power Steering and Brakes die out when driving.
  50. '94 Elantra shift points?
  51. Frozen Left Rear Wheel
  52. Elantra failing to start
  53. 2001 elantra transmission filter location
  54. Identifying motors
  55. My 2001 Elantra
  56. 2001 Delay on acceleration
  57. 1996 hyundai elantra OEM Engine G4CN
  58. bargain prices
  59. helpppp
  60. Deck problems...
  61. 2002 used elantra...only 37k but worn out brakes...... is it possible or ...??!!?
  62. 2003 Hyundai Elantra Check Engine Light
  63. Wheel bearing buzzing
  64. where are the spark plugs located?
  65. Rear drums
  66. Computer? Throttle Stays On
  67. Synthetic oil
  68. Purchased a 97 Elantra at an auction
  69. Stereo wiring diagram
  70. 02 Elantra calipers
  71. More Problems
  72. Mirror glass replacement
  73. Hot CD
  74. Help with rear brakes on 2002 Elantra GT
  75. driveline whine
  76. My 04 Elantra GT
  77. '02 Elantra exhaust manifold recall???
  78. Garage to Garage
  79. custom cat back
  80. Programing a keyless remote
  81. Fuel Pressure Regulator or Fuel Pump?
  82. How do I reprogram a keyless remote?
  83. I need a big help
  84. 2001 Elantra GT: Problems Starting Car
  85. Engine ticking
  86. Automatic 97 Hyundai Elantra starts but not without a little hesitation
  87. Latest from my car. Help me out......
  88. backfire,rough idle,no power...Help!
  89. Shud I sell it????Confused !!!!!
  90. aftermarket support?
  91. thermostat on the elantra- where is it? follow which hose?
  92. Faulty Injectors?????????
  93. hiundai elantra avante tunning
  94. Ashtray for Elantra 4 dr sedan
  95. Elantra Body Kit
  96. manual swap questions
  97. gasoline gushing on rear tire when filling up
  98. Cap & rotor
  99. Working On Rear brakes
  100. Recommed tires for 99' Hyundai Elantra?
  101. Hyundai Warranty
  102. Does this harm my tranny?
  103. Wheel bolts
  104. Pronton WAJA or Hyundai Elantra?
  105. 3rd upstreem 02 sensor fail in 6 weeks??
  106. hyndai elantra 2000 check engine signs after change spark plugs
  107. RPM's go down when gas pedal pressed
  108. Elantra turbo??
  109. brakes wont depress
  110. Intro and maintenance questions on 96'
  111. Engine light blinking + other issues '96 Elantra
  112. Transmission Problem
  113. 96 Elantra, makes clanging noise when starting
  114. 94 Elantra Radio Code
  115. Slow start 2000 Elantra
  116. How to remove seats with airbags.
  117. how do you change the fuel pump on a 97 elantra?
  118. Availability of Fog Light option for '05 Elantra GLS?
  119. Cleared code, and air bag light is still on?!?
  120. Speed sensor/misfire problem - 2000 elantra
  121. 2002 Elantra GLS - Door Lock Question
  122. 2000 Elantra code p0455
  123. engine troubles
  124. Please Help Troubleshoot Engine Noise
  125. Problem 96 Elantra daytime running lights
  126. 4G67 Engine Swap to a 91 Eclipse
  127. Which Transmission Fluid to use?
  128. 99' Elantra - Fuel Pressure Regulator question
  129. Gas Smell from Heater - 2001 Elantra
  130. Sound from underhood when AC on
  131. 04 elantra brakes?
  132. Did engine swap now get PO455 code, engine misfire and smell
  133. Door trim panel
  134. 99 Hyundai Elantra
  135. Is it the coilpack?
  136. 2001 Elantra electrical smell
  137. 2005 hyundai elantra gls warning light
  138. wrecked frt end
  139. '95 Elantra 1.8 "Sport"
  140. 2000 Elantra, slow start and gas smell
  141. Seeking. Person who knows alot about problems
  142. cracked exhaust manifold
  143. Changing Hubcaps?
  144. changing headlights?
  145. car
  146. car
  147. 2003 Elantra Front Brakes
  148. window problem/door panel removel
  149. big problem
  150. 99 Elantra Window Crank Removal?
  151. Airbag Light
  152. Instrament Cluster lights
  153. Rough idle only when stopped in gear with lights on
  154. Elantra MOLDY smell wasn't the AC unit
  155. rear end cause mechanical damage?
  156. MPI fuse keeps blowing
  157. 01 Elantra GT Emergency Break problems
  158. IS there a way to reprogram the remote on a 2003 Elantra
  159. airbag recall
  160. tie rod ends
  161. Wheel bearings
  162. 5 spd swap
  163. engine problem
  164. 1994 vs. 1995
  165. Korean manufacture complaint!!!!
  166. how much?
  167. is it gona make it?
  168. wuts this?
  169. 1993 elantra, wat do u think?
  170. oil wieghts ?
  171. spark plug cover 1996 elantra
  172. Hey hows it going =)
  173. 1999 owners manual
  174. 2000 elentra gls speaker replacement
  175. shoot redline help
  176. Piston Rings
  177. 2003 Elantra radio question
  178. '96 Enantra Wagon brake rotors
  179. Overdrive/Transmission Issue
  180. 16” and 17” Wheels
  181. Elantra 2001 Overheating
  182. 97 elantra engine problems
  183. Funky Smell
  184. K&N Air Filter
  185. Headlight
  186. Elantra Stereo & Satellite Radio
  187. 2000 Elantra outer CV boots gone
  188. engine compression
  189. How do you fix a sunroof?
  190. Stiping Tires?
  191. How many miles to a tank?
  192. Who has the most trouble free miles?
  193. Timeing belt question
  194. New owner 2005 elantra gt
  195. Hyundai died
  196. 2005 Elantra GT
  197. 94 elantra engine troubles
  198. Auto transmission issue
  199. Bitter owner
  200. Rear springs
  201. How long can a 02 elantra last?
  202. Intermittent Hesitation
  203. how do I remove window crank - 94 elantra
  204. 2 bad window motors, 1 bad lock motor
  205. help with overdrive 94 elantra
  206. 1994 sonata will not shift overdrive
  207. Wanted: 2002 passenger front fender
  208. Why so week motors at the power windows?
  209. Cleanest Elantra Engine I've seen
  210. Replacing Stock Radio
  211. Delaying 2001 Elantra
  212. 98 elantra running wierd
  213. please help
  214. air conditioned Filter
  215. engine spec?
  216. Daytime Running Light
  217. unexpected shift to neutral
  218. An off the wall request
  219. Elantra hesitates
  220. Side View Mirror
  221. HORRIBLE Gas Mileage...HELP!
  222. No power
  223. Rear Strut access
  224. Need Help ASAP
  225. Rear Brake noise
  226. Exhaust Manifold
  227. air bag light
  228. 2004 Elantra
  229. Class Action on Elantra Air Bag Sensor Problem
  230. Please Help Asap
  231. Horn Puked
  232. Drivers window
  233. Front end noise
  234. How do I turn off the annoying chime??
  235. Noise coming from throttle body unit?
  236. How to Change spark plugs?
  237. Check Engine Light and Loss of Acceleration
  238. 2001 zefiro body kit
  239. evap canister
  240. Funky Odor
  241. Gas slow to fill and check eng light
  242. rear window cable
  243. changing color of instrument panel lights
  244. 2001 Elantra poor handling on turns
  245. 2002 Elantra GT Hesitation
  246. locks
  247. 1996 elantra 5spd. gear oil question...
  248. 2000 Elentra trouble
  249. Quick Paint Question
  250. Brake Problem
