View Full Version : Elantra | Avante
Pages : 1 [2] 3 4
  1. 02 Elantra Overheating
  2. "Passenger Air Bag Off" light is on- Why?
  3. 97 hyundai elantra ecu question.
  4. car won't take gas!!
  5. help needed
  6. OEM brand parts
  7. 2000 Elantra cyclinder positions
  8. Transmision Problem or Other?
  9. 2000 Elantra with engine fan problems
  10. newbie needs help
  11. 2003 Elantra - Overheating
  12. 2003 Elantra Tranny service details?
  13. What is the problem
  14. elantra relay
  15. 2000 Elantra - Hard steering
  16. 1996 elantra wont start
  17. front rotor probs?
  18. Possible '05 Elantra purchase.....
  19. Checked Fuses now Air Bag Light stays on
  20. 2002 Rotor removal
  21. REPLACING HEADLIGHT on 2004 elantra
  22. Electrical Wiring Harness
  23. Help! Neon Windshield Washer Nozzles
  24. Transmission removal
  25. 2002 Elantra valve noise?
  26. 2000 Hyundai Elantra 5th gear pops out
  27. 95 Hyundia Trans Trouble
  28. Hyundia accelerates slowly
  29. '99 Elantra Killing/Tranny issues?
  30. 2002 Elantra clutch/tranny issue
  31. 2000 Elantra with Electrical Gremlins
  32. 2005 elantra gls alarm issues??
  33. Parking brake question
  34. Transmission problem 2002?
  35. 2000 Elantra stereo - how to program?
  36. Cil Po420
  37. minor clutch issue
  38. Power steering
  39. Detonation on a 2004 Elantra
  40. looking for trailer connector on my 2004 hatch
  41. Thinking of an Intake system
  42. 2004 elantra gls brakes issue
  43. no rpm and no codes
  44. Brake Problem. Anyone heard of this
  45. 1996 Engine Rattling/Grinding Noise
  46. Brakes... Should I drive or tow?
  47. Random Lock
  48. 2000 elantra wont start
  49. 99 Elantra strut problem odd can not figure out.
  50. hyundai elantra 2000
  51. News of the Weird
  52. 1999 Elantra need help with strut install
  53. Gas Gauge not working right
  54. i replaced my alternator and now my car is ready to die again!
  55. Outside Humming Noise
  56. 2005 Hyudai Elantra Idle Engine Noise?
  57. Malfunction Indicator Light
  58. Please help real Quick - What's the rear speaker size for 03 Hyundai?
  59. how to remove driver side fender???
  60. 92 Lantra
  61. Thumping in front wheel, jerking when stopping
  62. Wipers Not Working
  63. Hills
  64. 05 Thermostat location
  65. Should I buy 05'/06' elantra GT hatch back?
  66. Front brake help and replacing Wheel Stud
  67. For BOB Rohrman
  68. noise at idle
  69. Elantra fuel filter
  70. 2005 elantra, hearing a noise??
  71. Cel
  72. Parking Brake
  73. Can't remember how my remote starter works!
  74. Check Engine Code PO136
  75. 2002 Elantra fuel filter
  76. 1999 Elantra Exhaust Noise??
  77. timing belt
  78. 93 Hyundai elantra trany vs 94 hyundai accent trany?
  79. 2000 Elantra Intermittent Stumble
  80. 2002 Elantra P705 P715 and P1529 Codes
  81. shimmy at slow speed
  82. Hyundai windows
  83. 2000 Elantra, what to look out for
  84. lantra gearbox
  85. headlight aiming
  86. 95 Elantra Air conditoner just shuts off and will not cool for short time
  87. 02 Elantra Overheating
  88. 2006 Elantra front seat covers...
  89. Problems after switching 99 engine/trans in 98
  90. 2000 Elantra Overheating
  91. Fuel Pump
  92. Fuel Pump(I think)
  93. Need programming instructions for keyless entry remote - 2004 Elantra
  94. I am tired of this WHAT YEAR IS THIS CAR?!
  95. Engine choises for a 93?
  96. Speed Sensor Problem? Help! P1529, P0501, P0500
  97. 2000 Elantra Battery HELP!
  98. navigation system
  99. Any modifications needed
  100. Tail lights?
  101. Manual Transmission install
  102. What AT Fluid
  103. 2005 reliability=?
  104. AT Slow to Respond
  105. Waht Spacer
  106. Should I buy?
  107. 2000 elantra codes P1624 and P0713
  108. 2000 elantra squeaking
  109. 2003 Elantra overheating
  110. 2000 Elantra SW radiator fans quit...
  111. Elantra 'o4 changing brakes and rotors
  112. Replace '05 Brakes Already??
  113. Elantra fuel filter
  114. iPOD interface install to Factory EGT head-unit.
  115. Torque Specs
  116. Replacing Suspension on a '99
  117. problem with borrowed friends '02 elantra
  118. Big quality problem!!
  119. 02 Elantra over heating thermostat????
  120. Vent Guards/ Rain Guards
  121. 2000 a/c controls
  122. 1994 elantra
  123. air bag control modual help
  124. Disc Brake Rotor Removal
  125. How Do I Hook Up Subs In The Trunk
  126. Fuel filter placement '99 Lantra (Oz model)
  127. suddenly my car's gone crazy!
  128. Problem with a 03 Elantra GT
  129. 2002 Elantra Gt Rear Seatbelt
  130. Please Help
  131. Need Help!
  132. Wierd Noises???
  133. help needed
  134. Question - Didn't know where else to post
  135. CD Player Installation
  136. Shakey Breaks
  137. 01 themostat location
  138. wrecked 2000 Elantra, years parts exchangable
  139. Idle revs and drops on '01 Elantra GT
  140. 2001 Elantra automatic shifting trouble
  141. Deposit on dip stick
  142. 2001 Gear Shift Light
  143. Replacing Shocks
  144. One radiator fan runs, the other does not
  145. Idle revs and drops
  146. Trouble with starter
  147. front brake rotor stuck
  148. Pulling Front Brake Rotors on a '99
  149. Engine Coolant Temperature Sensor
  150. Fan switch
  151. $750 estsimate for brake overhaul?
  152. Pop Pop! Like someone's knuckle cracking...
  153. 1993 Elantra
  154. engine and ecu codes ?
  155. weard light problem
  156. OBDII Codes
  157. Cooalnt Bleeding
  158. 2005 Elantra Engine Light Question
  159. 2001 Eleantra
  160. Head lights
  161. 2002 Hyundai Elantra Headlight
  162. 97 elantra headlight problem
  163. Front-End Noise Under Braking and Turning
  164. Engine Swap
  165. Want Wiring diagram of 1997 Elantra
  166. Bumper removal
  167. What to do after lease end
  168. Cracked exhaust manifold
  169. Fuel gauge problem
  170. Fan problem
  171. '04 elantra performance???
  172. How do you know when to change the transmission fluid?
  173. air bag light
  174. And the Beat Goes On
  175. Need a Air Bag Module Elantra 2002 GLS
  176. 2002 Elantra Keyless Entry
  177. my vehicle claim history: what does it mean?
  178. Is Elantra a good car to buy?
  179. Rumbling Rear End Noise on 2002 Elantra GT
  180. Wheel Bearings 98 Elantra
  181. '99 elantra common software errors: oil change?
  182. window tint estimate?
  183. headers on 1999 elantra?
  184. wheel/rim/tire compatibility? want to swap wheels...
  185. Vents - air doesn't blow out at all (at any fan setting)
  186. 2002 elantra 76000 miles still wont stay started
  187. car starter
  188. Elantra 2001 - how to replace tail light relay
  189. groan noise when step on brake pedal
  190. front end groans when stopping;brake noise
  191. elantra brake lights remain on
  192. Brake switch replacement
  193. my 2004 elatra died while i was pulling into a parking spot
  194. Elantra 2001 - instrument panel lights go off and on
  195. car is going crazy
  196. Elantra Trans Shifts from 4th to 3rd
  197. Loud noise when driving/bearing?
  198. 1992 elantra water pump
  199. 76,000 mi told I need an engine cel on
  200. Cold Air on 98-00 Elantra?
  201. '99 Elantra Fuel Filter Location/Replacement
  202. 2000 Elantra Speed Sensor Location???
  203. 2001 elantra and oil smell?
  204. 2000 Elantra
  205. Should I buy this Elantra?
  206. Timing Belt Replacement
  207. 60 MPH Shimmy Resolved
  208. Thermostat location 2002
  209. easy elantra starter removal?
  210. Brake light replacement - HELP
  211. 60 MPH shimmy
  212. 2002 elantra rear drum removal
  213. 01 elantra Exhaust?
  214. Both Regular Headlights Out!?
  215. removing stock radio on 99 elantra
  216. like child safety lock BUT front driver door
  217. Alternator Replacement
  218. remove stock radio/ install new one
  219. Rear Brake Caliper Broblem
  220. Scan Tool Recommendations
  221. First Gear In Automatic Transmission
  222. 99 model Elantra
  223. Removing Front Rotor's 2002 hyundai elantra
  224. Timing Belt Replacement ( How To )
  225. Rear Seats on 97 Elantra
  226. Your thoughts on jacking/jack stand placement
  227. P0422 Diagnostic Code
  228. 2001 Elantra stock radio
  229. fuel filter 2001 elantra gls
  230. 1996 Elantra Air Bag Light On
  231. BIG engine and electrical probs HELP!
  232. idle problems/stereo wiring problems
  233. 2000 Elantra overheating...
  234. 2OO1 Elantra GLS
  235. 2000 Hyundai Elantra Stumbling!
  236. I Only Have Until Sunday!!
  237. 97 Elantra check engine light and transmission control module - SOHC?
  238. Accessory Din Socket
  239. What kind of mileage do you get?
  240. 1994 lantra suspension?
  241. How do you get this drum off?
  242. Elantra Recall
  243. Fuel and temp gauge needles...
  244. Can Anyone Identify This CD Player?
  245. 99 Elantra Engine Noise
  246. 2001 Elantra Wheel Bearing problem
  247. 95 Elantra intake
  248. 2000 elantra caliper bolts
  249. No dash lights and more...
  250. Elantra GT
