How Do I Test My Brake Light Switch?
Pekoe
08-16-2003, 02:40 PM
I just put a continuity tester on my brake light switch and didn't get a light. On the tester, you hook black lead to ground and touch the metal tip of the tester to power and get a light - correct?
The brake light switch has a red and a black wire connected to it. I disconnected the red wire and put the metal tip into the red wire and got no light.
Am I doing this right? Shouldn't the tester light turn on when I touch it to the red wire?
Thanks
V-8Fan
08-16-2003, 11:59 PM
Sounds right to me. I would also check to see if the black wire is hot though. Ya never really know. Make sure you have the alligator clip on a good ground, though, otherwise you're spinnin' yer wheels.
jeffescortlx
08-18-2003, 03:29 PM
Or just jumper the switch and look to see if the lights are working.
Did you check all the fuse's?
