Incorrect Outside Temperature Reading
96OldsAurora
03-07-2005, 08:29 PM
Hi Guys, first timer so be kind. I've used the information in this forum several time for information, very informative.
I have a problem with my outside temerature reading. Itis ok when i first start driving but then it drops all the wat to -39 and goes up and down while i'm driving. Any help would be greatly appreciated.
Thanks keep the flow on info going
Day 2 now it dosen't even display the outside temp. will try to clean the sensor thanks.
treeboy38
03-07-2005, 11:16 PM
First I would try to clean it. Lay down in front of the car looking underneath the bumper. See that black canister shaped thing in the middle of the radiator? Try taking a clean towel and wipe the top of the sensor off. There is probably 9 years worth of crud on it. Get back in the car, start her up and drive around the block. If the temp reads ok then your done. :smokin:
If not, its time to be a new sensor. :mad:
ODEANOK
09-23-2007, 05:29 PM
Treeboy38.....I did both of your suggestions and it's still bad...any other ideas?
