pnp
PHAREAL
02-20-2005, 05:05 AM
can someone tell me where the neutral safety switch is located and how i can adjust it?
Isnibs
02-20-2005, 07:16 AM
The Park/Neutral Position (PNP) Switch
Neutral Safety Switch 1996
Set parking brake and set gear selector to the "Neutral position.
Remove linkage cable bracket to transaxle shaft retaining nut.
Remove linkage cable bracket from transaxle shaft.
Remove Park/Neutral position switch attaching bolts.
Disconnect Park/Neutral position switch electrical connector.
Remove terminal nut on starter solenoid, then disconnect cable from starter.
Remove Park/Neutral position switch from vehicle.
Reverse procedure to install.
This is to remove but it may give you some idea how to adjust it.
Hope this helps.
Hope this helps.
