air ride auto leveler
rwagoner56
02-19-2005, 05:11 PM
2001 Aurora.
My auto leveler is acting up. The air pumps up the rear end and stays up. Any idea how to fix this?
thanks
55624096
03-27-2005, 07:29 AM
Had same problem found water got into the system and ruined the valves in the minature compressor. found identical compressor on a buick at junk yard just had to mount the buick compressor on the aurora mounting bracket. total cost 35.00 and 1 hour work, plus lots of junk yard time finding the compressor.
Isnibs
03-27-2005, 06:48 PM
Sounds like your electronic level control sensor.
See one here
http://aurorah.proboards20.com/index.cgi?board=Gen&action=display&num=1106065031&start=
If the adjusting arm and electrics are connected OK and it still doesn't work then you may need to change it.
