View Full Version : Forced Induction
Pages : 1 2 3 [4] 5 6 7 8 9 10
  1. question for the pro's,experts if u will!
  2. increase hp on 01 prelude?
  3. 97 Civic D16 1.6L SOHC Vtec JR Supercharged--Lots of ????'s
  4. anyone with forced induction in CT, please HELP!!!
  5. Boost Controllers
  6. New clutch for Turbo???
  7. I want 200+ whp
  8. turbo or supercharger?
  9. Driveshafts
  10. turbo exhaust manifold problem
  11. DART block question
  12. Forged Pistons & Rods
  13. Need some suggestions....
  14. why do you inject water into the chamber?
  15. oil drain
  16. Question
  17. 2 turbo questions
  18. best b-series motor for turbo is......
  19. Anyone have a TurboXS's BOV?
  20. WTB 99' civic si ecu
  21. For Sale Jdm Type-r Lsd Gear Type
  22. E-bay Intercoolers?
  23. Nos (zex) on Stock si good or bad idea?
  24. not again!!!
  25. Ignition upgrade for nitrous CRX
  26. fuel system for turbo
  27. D16 with turbo
  28. Turbo for Lewd! (dependable??)
  29. Can someone give me a rundown of HOW you engage nitrous?
  30. Really Important
  31. Supercharger?
  32. Turbo (or supercharger) and Nitrous for a 1985 chevy 5.0 (305ci)
  33. painting charge pipes
  34. superchargers
  35. custom downpipe
  36. ebay turbo?
  37. k&n filter worth it???
  38. 91 prelude DOHC turbo
  39. WOW! Civic + B18 + Turbo - Interior = FUN
  40. need some help with a turbo d16
  41. grounds=more hp/tq???
  42. What turbo for my gsr
  43. Changing Internal Wastegate
  44. A turbo question for 95 Civic
  45. upgrades before nos
  46. 94'gsr turbo problems
  47. N20 and turbo?
  48. JDM B20a turbo project
  49. worth it ? A guy wana sell me a JRSC with 1500 USD . worth it ?
  50. tranny swap
  51. 50 Shot nitrous on a prelude
  52. turbo for 91 accord
  53. Turbo with miles?
  54. forced induction: additional wear and tear?
  55. turbo kit for 98 civic hatch
  56. how much will it cost for turbo intall.
  57. Turbo/Supercharger relation to fuel mileage.
  58. can a turbo run without a wastegate?
  59. hard ass built B16
  60. GM 3800 SC tech question... ...
  61. Look what the fed-ex guy left at my house today
  62. 354 hp out of crank? GSR with stock int and 7psi of boost ?
  63. gsr turbo
  64. Lebaron Turbo
  65. edelbrock turbo kit
  66. Turbo and smog check
  67. radiator hoses
  68. Post turbo install TUNING
  69. safc or safcII
  70. Super charger like ideas?
  71. tapping the oil pan a must?
  72. Exhaust
  73. white smoke
  74. superchargers? takes power to make power
  75. Does anyone know where to get the d-3
  76. d16 turbo question?
  77. n2o
  78. air induction
  79. b16a2 turbo ????
  80. Turbo Tuning
  81. how to tune?
  82. Are intercoolers really that effective???
  83. Help Hooking Up Zex Dry Kit on My B16A
  84. nawwwwwsssss
  85. Turbo, Turbo, Turbo
  86. Fuel/EMU
  87. k27#8 880hp? help plz
  88. Sotck 94 Accord F22B1 w/ Turbo???
  89. Build a SUPERCHARGER
  90. Any point in 20psi?
  91. Turbo + Nitrous
  92. This is you Piston on N2o
  93. Newbie needs Odyssey help!!
  94. What size T3 turbo for a D16z6
  95. turbo,supercharge,or ls/vtec
  96. Frankestein Engines
  97. b164a2 turbo? psi?
  98. go turbo or all motor?
  99. Greddy turbo kit on H22a?
  100. resleeving and port/polish question
  101. Custom Turbo Setup
  102. turbo accord qestions
  103. quick spooling turbo setups
  104. just a few more questions and ill quit buggin y'all
  105. T3 or t3/t4
  106. turbo question
  107. what pistons to use if i want to run alot of boost?
  108. Advice..Turbo on my 11:1 gsr motor????
  109. 2 Stage NITROUS
  110. A Contraversial Issue!
  111. A Contraversial Issue!!!
  112. twin turbo honda
  113. noob turbo questions
  114. Ideal compression ratio?
  115. whats the cheapest complete turbo system?
  116. help.... 22psi
  117. help..... for 22psi
  118. N2O on top of a Centrifugal S/C
  119. supercharger setup
  120. Custom Kit or FMAX?
  121. je pistons... and crower.. and darton
  122. b16a block
  123. do u need turbo software?
  124. Accord 98 turbocharged F23A1 engine
  125. Does anyone know anything about the KKK K27 turbo?
  126. Garrett Turbocharger
  127. greddy turbo 4 sale
  128. compression vs. boost
  129. which motor is better for boost
  130. Ls/vtec turbo
  131. Removing sleeves from stock JDM H22a?
  132. Turbo Kit or put one myself. Which one???
  133. how much hp increase can i expect from the cheapest greddy
  134. GSR & Type r heads?????
  135. turbo give good power gain?
  136. d16z6 superchargers?
  137. over boosting
  138. anyone runnin the greddy kit?
  139. Eclipse/Talon turbo on integra ls
  140. Someone asked this already.
  141. 'Most' Easy to install....?
  142. anyone with VAC/BOOST gauge installed in car?
  143. Best BOV runnin 8psi
  144. VTEC Controllers
  145. Vacuum gauge install????
  146. Just recieved shippment of Manifolds!!
  147. Does that Sprial Max thing really work?
  148. Water cooling lines for T3?
  149. nitrous + turbo
  150. T3h Setup
  151. blow off valve location
  152. Porting, turboing and stroking.
  153. 96 cavilier rear defogger
  154. How to hook up FMU?
  155. t25 vs. to4e
  156. T3 Turbos From A 80's T-bird
  157. vtec safc for sale on ebay!!!!
  158. Turbo vs Supercharger
  159. want turbo!
  160. ls turbo..??
  161. Whats better? N2O sprayer or Co2?
  162. 10 psi LS Vs. 8 psi Gsr
  163. bar websites?
  164. HELP!! in the metro Atlanta area
  165. Whats the diff in the N2O setups?
  166. Zex Install
  167. Turbo help
  168. Worth it to turbo H23 lude?
  169. how much boost is reliable
  170. N20 + Turbo, to much for a stock motor?
  171. Carb number?!?
  172. overall turbo questions
  173. Nitrous Pics
  174. I need help installing a turbo on an LS
  175. turbo question. HELPPP
  176. Lowering Compression Ratio
  177. Making final Turbo decision
  178. wich diagram to use?
  179. turbo.oil.pressure.
  180. blow off valve flutter
  181. Turbo specs...
  182. Cost for engine Testing
  183. Help me out, putting T3 turbo on my B18B1
  184. Newb Lookin For Answers
  185. rsx tuning
  186. B16A2 turbo experience
  187. how should I tubro a stock LS
  188. New Garrett To4 for sale
  189. Difference between turbos
  190. High-compression & turbo
  191. racing
  192. how do external wastegates work?
  193. Turbo/Supercharger help!
  194. for a turbo
  195. Need turbo guidance?????
  196. what needs to be done to my engine to add a turbo
  197. SC Resale Value?
  198. supercharger leaking oil
  199. T3 cheap ... Worth?
  200. T3/T04E Turbo , what do you think?
  201. Building Turbo kit, B18B1... FMU, MAP, Manifold Questions
  202. how much to install revhard stage 2 kit?
  203. Can someone help?
  204. how to switch to external wastegate
  205. Which turbo 2 use???
  206. SOHC ZC/VTEC and NOS
  207. wanting to turbo my d16z6, what do i need
  208. Upgrading questions.
  209. OBD II tool
  210. Dyno daze in the corn field, do we need it?
  211. turbo kit install is done!!
  212. which setup is better???
  213. Turbo install
  214. I need to build a supercharger, and i don't have any specification to do it.
  215. One Beast of a Honda!
  216. B18a Turbo
  217. Best Turbo for Ls/Vtec??
  218. best turbo/turbo kit for integra GSR???????need help
  219. best supercharger for acura integra GSR????????????
  220. oil pressure switch
  221. V8 turbocharger
  222. integra supercharger on 2001 honda?
  223. compression ratio?
  224. What is turbo lag?
  225. How does a blow off valve work and what does it do?
  226. check engine light
  227. safc tuning
  228. what can i do to make my car faster
  229. Piping 101
  230. slow progress
  231. Nos
  232. ANOTHER turbo question...
  233. turbo my D16z or b16
  234. B16 turbo
  235. The best intakes and Turbo manifolds
  236. Installing wet kit on b16
  237. Nitrous/Turbo theories
  238. Turbo Book's
  239. Vid: My JRSC RSX-S
  240. anyone got a turbo for sale??
  241. Header, Intake, Exhaust
  242. prepping for high boost.
  243. Turbo Manifold Questions
  244. EGT Probe/Gauge
  245. B16a2, turbo, injectors questions
  246. b16 or b18c1 w/ Vortech Supercharger?
  247. Installed turbo, now car wont start, Help!!
  248. Garrett AR Escape 47/AR 51 Compressing, small for b16a2
  249. Best Honda/Acura for the 1/4
  250. What do u think of electric turbo that works
