Question about FI versus Carbs?
Car_Ram/Rod
01-16-2004, 11:09 AM
I was wondering if I was to build an carburated engine could I change to fuel injection without changing the horsepower if I was to get the appropriate injectors? The systems in question are 750 CFM holley performer versus the Holley stealth ram. Help would be excellent cause fuel injection confuses the hell outta me.
SaabJohan
01-16-2004, 03:58 PM
Usually you should be able to get out more hp since the safetymargins can be made smaller.
MustangRoadRacer
01-17-2004, 03:08 AM
from what I understand, FI is better for just about all applications other than all out, top end enignes that need a ton of fuel.
OttawaStreetRacer
01-17-2004, 08:34 AM
Thanks guys I just wanted to make sure when I'm buying for teh build that I don't spend more and get less.
SaabJohan
01-17-2004, 11:32 AM
FI is better for all type of applications, electronic fuel injection can't however handle the fuel management of a Top Fuel so it's mechanical but electronic isn't allowed so there have been no reason to made one that works for Top Fuels.
Formula One switched to elecronic from mechanical fuel injection in the early eighties and gain quite some power due to better management.
MagicRat
01-18-2004, 09:58 PM
Have a look at Holly's website. Their high performance FI systems are good for a wide variety of applications so you should be fine, so long as the camshaft you have is not a really radical grind.
2turboimports
01-19-2004, 09:32 AM
it goes both ways, there are 9 sec carbed cars, there are 9 sec FI cars. Just build it well
