distributor cap direction
jrwpmw
12-31-2003, 09:31 AM
On a 98 Dodge Ram, 1500. 5.2.
The distributor cap has a #1 on it for the first cyclinder. Does that #1 point to the drivers or passengers side. It can go on either way, and I forgot how I took it off:)
Thanks!
Thanks!
MustangRoadRacer
12-31-2003, 09:44 AM
you need to look at a firing order diagram. most likely drivers side.
ivymike1031
12-31-2003, 12:24 PM
you could also put cyl #1 at TDC firing (engine off) and look to see which way the rotor is pointing, but the diagram is probably easier.
I have trouble believing that the engine would run if the firing angles were all 360 crank degrees out of phase (180 cam deg phase on distributor).
