View Full Version : Celica
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. AT-5SPD Swap...tranny change.
  2. And so ends an era...
  3. For all the 5th Gens out there
  4. pics of the new hood
  5. Car Bogging. Need Help Please
  6. chk engine lite on, MPG goes down drastic, any idea?
  7. thermostat
  8. Transmission question
  9. Stock Shift Knob Removal
  10. Engine swap?
  11. 3sgte vs Monkeywrenchracing 1zzfe
  12. Petrol smell
  13. difference between a 00 Celica Gt/GT-S
  14. HID on my 2000?
  15. engine won't shut off with key out!!
  16. Celica Turbos
  17. Tranny swap 5-6
  18. Oil Filter
  19. Short shifter for a 90 celica?
  20. 1995 celica gt
  21. Need to know about 95-98 celica engines
  22. question about brake shoes changing
  23. 2002 celica gts
  24. GENESIS IS BACK!!! Needs advice on his baby
  25. FWD -> RWD -> AWD
  26. how come they....
  27. The bar has been raised - 466whp 1zz
  28. 2000 GT brake light change
  29. Rattle in engine compartment
  30. Read if you want to turbo your celica *revised
  31. Rims
  32. bad computer?
  33. Rear Engine Possibilities
  34. GT-S Tach video
  35. Anybody here know custom fibreglass?
  36. 5th Gen taillights
  37. What computer makes the engine go?
  38. my celica jerks when hot??help!!
  39. windshield washer pump
  40. Short Shifter for 88 Celica
  41. Body Kits
  42. 2jzgte or alltrac in '91 celica
  43. Parts that give most power
  44. enginebay fusebox by the battery need help
  45. trying to find a convertible top frame for my car
  46. Check Engine Light on then off?
  47. Celica drift or "power slide"
  48. 84 celica will not start
  49. driveaxel? brake? CV joint? any help apreciated
  50. Turbo on a 00+ celica?
  51. 1995 Celica accident
  52. Sleepy eyes for 5th gen
  53. Problem on 1986 celica gt
  54. 4agze project hellica
  55. 92 ST Clock/Vent Removal
  56. HUGE loss of top-end power
  57. New alternator, no lights
  58. AE86 vs. Celicas
  59. Again on the look out
  60. Exhaust or Headers??
  61. seriously....can someone host a vid or some pics?
  62. Celica My Be-yotch!
  63. How Big of a Gas Tank?
  64. 87 celica gt question
  65. replacement/aftermarket Steering Wheel
  66. 1zzfze?
  67. camry v6 engine and tranny
  68. If you did a Swap, help me !!
  69. how do I tell I have gt or gts?..just bought car
  70. Crashed.. Need parts
  71. my heat just stopped working
  72. engine swap
  73. High Idle problem
  74. 87 celica heat
  75. 94 celica start up hesistation!!!
  76. 5sfe block with g head
  77. 1976 celica ignition
  78. what to do?
  79. sway bar end links
  80. Question regarding 1990 5SFE Celica's power steering pump!
  81. 7afe to4age swap
  82. opinions on mods and Strut questions-long post
  83. DIY Articles
  84. still trouble with front halfshafts
  85. 92 Stereo AUX RCA Inputs??
  86. Engine knock problem
  87. engine question amung others
  88. 4agze in an ST
  89. axle-back exhaust
  90. Rice..Define it please
  91. Just FYI on Gauges
  92. entertainment
  93. Your engine option
  94. JUSSTTT Missed It.
  95. $8 Subscription to Car & Driver, Motor Trend, and Road & Track
  96. Is it true that "tC" is teh new Celica?
  97. bodykit help
  98. not a celica problem but..
  99. Celica Engine, need help
  100. Progress of my car.. been away for a while *pics and vids*
  101. Cannot shift from park without shift release
  102. 00-05 GT-S 6 sp on a 3SGE?
  103. Draining a gas tank?
  104. Extremely Strange 6th Gen Headlight Problem
  105. Intake and exhaust questions.
  106. Will 19's fit?
  107. another update: 4agze in my celica
  108. Rims. On a cheap budget
  109. Reverse Glow Gauges
  110. Race.. can i win?
  111. celica axles
  112. front halfshaft removal
  113. Celica (2ZZ-GE) parts for Will VS?
  114. venom module and cam gears
  115. what will work/what wont work...
  116. Sound Problem
  117. Vid, modded 93 civic si, 03 celica gt, 91 celica st
  118. drum to disc brakes
  119. HELP!!! crazy problem
  120. The Great Northern GT4 gathering
  121. Low idle?
  122. ¿ Hyper Voltage System - Voltage Stabilizer ?
  123. Best Way to Get Rid of The Rust
  124. Speedo offset with new rims?
  125. Passing Inspection
  126. straight piupes, who wnts one, what size?
  127. mountain run *video*
  128. 83 celica does not like hot weather
  129. Rims to big?
  130. Forced Induction On Daily Driver?
  131. would a stock 3sgte block support a garrett GT Series turbo gt28rs or gt30r?
  132. Instument Panel 91 GTS-Light Location?
  133. Shift kit?
  134. 85 wheel weights
  135. Turbo maifolds, 4afe/5sfe/anything else? lol
  136. off topic(sorta): lol my welds
  137. Group Buy: lambo doors
  138. Can't find my HORN!!
  139. Big Problem Help Plz!
  140. Unuseable Windshield Wiper Fluid
  141. NEW 4th gen 3s-gte coming out in japan, hope we get it here...
  142. deciding what engine to use
  143. pics of my raggedy azz car
  144. Celica Gtx?
  145. rebuild or replace '86 gt 2se...please help!
  146. 5sfe w/ forged internals vs 3sgte block
  147. 3sgte links needed
  148. wondering what the difference is between a gt and gts transmission?
  149. upgrading suspension
  150. Dies when I fill up gas tank...
  151. Warranty voidage with header?
  152. HID info?
  153. Brake problems
  154. 1GGTE which car should it go in?
  155. 95 GT...Mods?
  156. loud idle and coolant in exhaust
  157. ignition
  158. Cruise Control Fix?
  159. straight pipes
  160. Kill List..?
  161. Any good sites for celicas?
  162. 5th GEN: It's Time We Get Better Body Kits
  163. car alarm question
  164. body work
  165. 84 GTS engine swap
  166. Speedometer darkness
  167. coolant in my cylinders
  168. Replacing rod bearings
  169. 83 Celica Engine Upgrades
  170. almost done
  171. Performance Intake on 88
  172. Very Loud Tapping Noise
  173. What's wrong with my '90 GT?
  174. lost
  175. converting celica to rear wheel drive
  176. 1987 celica gt problems
  177. Carbon Fiber Hood Probs
  178. GT4 power outage
  179. exhaust whats the difference
  180. Compression test question
  181. transmission problems?
  182. Replacing Blown head gasket
  183. help please
  184. 95 celica
  185. 90 Celica GT Rims and Tires??
  186. New to the world of upgrades
  187. stx?
  188. Idle problems
  189. 93 celica st swap
  190. All-Trac???
  191. Besides the 92 celica gts, what are the other models with the 3s-gte
  192. I have a 1990 celica gt-s, im rebuilding I need suggestions, and what kinda engine?
  193. head home smoke show
  194. Your Celica
  195. i cant win
  196. Notch In the Clutch
  197. CAI finally installed :)
  198. need help!
  199. 3RD Gen again
  200. The Rights of Automotive Hobbyists - NO MORE UNLAWFUL VEHICLE INSPECTIONS -petition-
  201. NOS and oem replacement parts
  202. air ride system for celicas
  203. Help!!!!
  204. 3sgte block weight?
  205. need some help 91 celica
  206. 2002 Celica GTS
  207. want 350 to 400 Hp what kit to go with?
  208. 80 Supra overdrive transmission
  209. Got my new exhaust
  210. my car is crazy! i need help
  211. Upgading transmission
  212. Celica Intakes
  213. Early 90's Celica + 3SGTE
  214. targa top
  215. looking for a new car
  216. still up in the air
  217. looking for gear heads near akron ohio
  218. torque spec's for 99 Celica (flywheel & clutch)??
  219. 91 celica gt vs 94 probe se
  220. '98 Prelude vs. 2001 GT-S
  221. im not sure about anything with my celica...
  222. Color
  223. throttle body spacer
  224. I need a 5sfe block
  225. Does an 83-84 Celica 5 speed have any potential?
  226. 93 Celica 5th Gen. will not start
  227. fuel injectors
  228. Intake for an ST
  229. 7afe
  230. spoiler removal
  231. Engine swaps
  232. 3rd Gen. Owners!
  233. How much is this car worth? (if anything)
  234. carlos sainz front bumper
  235. Cold Air Intake
  236. 86 celica no start
  237. Where is FUEL FILTER on 92 GT??!!
  238. 1988 celica problems
  239. 91 gt-s factory amp replacement?
  240. Sell This Car!!
  241. new celica
  242. 92 GT Hood Release
  243. I want a Celica but....
  244. !!!idle Adjustment Help!!!
  245. help with 3SGTE swap
  246. Boost is back...
  247. help! with 86 Celica
  248. [b]Rack and Pinion Steering Repair for '95 Celica ST[/b]
  249. 4agze swap upadte- Part 2
  250. celica shakes
