View Full Version : Celica
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. Does anyone know anything about the 5AFE engine
  2. Need Help with Celica ST 89
  3. Swap 1JZ-GTE
  4. Replacing a lowbeam headlight on a 6th generation Celica
  5. please help
  6. 2002 Celica GT Auto Tranny Stuck
  7. 2002 celica gts is this woth it
  8. stupid air conditioner
  9. Bought celica, tiny problems.
  10. Mr2 lsd tranny fixed but....
  11. How many miles do you have on your 91 Toyota?
  12. Cruise Control Problems...
  13. NEW Gas tank? - 1991 celica
  14. Trying to remove a mangled brake line
  15. Coolant bleed screw location 2000 Celica
  16. The Right Car
  17. 86 Celica GTS - Small yellow door clip?
  18. help on 91 celica o2 sensor
  19. Rebuild of front end help
  20. 87 gts aftermarket help
  21. Overheating...help!
  22. Wich is the best celica
  23. Accelerating problems! pt.2
  24. BRAKE LIGHT FUSE ERROR. any help?
  25. BRAKE LIGHT FUSE ERROR. any help?
  26. Steering wheel
  27. where could i find a spring that allows hood to latch.
  28. Racing Chips
  29. '01 Celica Jerking Problems
  30. starting problems
  31. Aftermarket Stereo Problem
  32. 2000 Celica GT engine swap?
  33. Accelerating problems!
  34. Rubbing Noise
  35. Turbo!!
  36. Changing struts
  37. Celica ST turbo upgrades
  38. 93 Celica engine replacement?
  39. my 1991 celica gts stalls with the air conditioner on
  40. 87 cellica need conv. top assembly + pump
  41. 1985 toyotqa celica gt timing
  42. Help w/1976 Celica GT
  43. Which Celica(if any) and what upgrades?
  44. 4A-FE Timing on mark but knocking
  45. 86 Celica GT steering wheel removal
  46. 1979 celica gt
  47. 94 Celica GT-S Turbo
  48. 91 Celica GT - only high beam lights working.
  49. Headlight Problems
  50. Changing clutch
  51. '92 Celica ST, Low beam, drivers side burnout...2x Help!!!
  52. Engine Trouble
  53. Amp problem
  54. Looking at 01' GTS. Why is there no logo?
  55. swap problem
  56. Changing stuts on an 89 convertible
  57. Which celica gt-s year would be better?
  58. low side port air conditioning
  59. Cold or Hot plugs?
  60. help with coolant bottle in 2001 celica
  61. websites
  62. GT4 being resprayed/rebuilt
  63. 5sfe and 3sgte
  64. '92 Celica ST, Won't Start. 1.6L 4A-fe.
  65. V6 Celica?
  66. need help
  67. In Need Of INJECTORS FAST!
  68. 2003 Celica GT Belt Change
  69. why wont my 91 GT be loud
  70. 1977 Toyota Celica ST
  71. 76/77 GT Liftback
  72. Helppppp
  73. Finally
  74. head change
  75. ASC documentation??
  76. Car Shaking at stop light
  77. Need Help In A Hurry!!!!
  78. Emergency!!! Please Help! Engine problem!
  79. 94 celica st
  80. Instrument Panel lights, very basic, NEED HELP
  81. Thinking about gettin Coilovers???
  82. brakes prob
  83. Celica Spark Plug Replacement
  84. 94' gt engine tuning?
  85. Can I Use A Std Fender On A Convertible?
  86. celica bodies
  87. 2000-2005 celica
  88. Motor mounts on a 1990 Celica GTS
  89. 1990 celica problem
  90. I wanna but this celica.
  91. celica dead :(
  92. Can a '94 ST tranny fit a 94 GT motor
  93. yay or nay
  94. Turbo Fo A 91 Celica St
  95. 1993 GT what to look for, before I buy.
  96. HELP 3S-GTE in 93 ST is it possible?!?!?!?!?!
  97. alternator not charging battery
  98. Check It Out
  99. Increas Horse power for a 1990 celica
  100. engine swap for 01 celica gt
  101. New Celica Owner
  102. what engine for a SA63??
  103. which wiring will start 3sge motor
  104. New to celicas...need some advice plz
  105. turbo upgrade
  106. Need Help Changing A Fuel Filter!
  107. New Ideas For Weight Reduction? Have any?
  108. Any one no where to get a wide body kit for a 1991 GT Celica
  109. 94' GT exhaust question!!
  110. Swap Auto Tranny for Stick?
  111. poly urethane body kit?
  112. 94 Celica - oil gets dirty
  113. Celica Purchase
  114. 00 celica gts tick, and idle problem
  115. can i replace my damage 3s turbo with 7mgte one
  116. Celica Question
  117. Toda Parts
  118. 3s-gte
  119. 90 Celica 54SE Engine Problem
  120. hey guys, need help
  121. Overdrive/Tranny probleme on 5SFE
  122. GT-S rear disc brakes?
  123. a/f guage
  124. strange problem
  125. no spark
  126. tein super street?
  127. chilton manual?
  128. needs some info
  129. New Look GT4
  130. Top Speed Question for 2001 Gt
  131. Need Help- Idle Problem
  132. Help with my GT4
  133. t3/t4 turbo set up
  134. trouble finding exhaust system to fit....
  135. 2000 GT-S rear View Mirror of fritz
  136. ST215 into a 91 gts
  137. just joing the club with 93 1.6 need wheels
  138. Need advice on a new engine
  139. oil light problem
  140. sound noise heard from the alpine radio
  141. Engine trouble
  142. Hub centric rings
  143. Spark Plugs, and Spark Plug wires
  144. ODB I or II?
  145. new ecu for engine swap?
  146. My First Celica Drawing !
  147. I need some advice...
  148. New Wheels and toys and stuff
  149. Clutch Question
  150. 4AFE peak power
  151. No Spark.
  152. Oil Light Problem
  153. Help!! Front Turn Signals Not Working!!
  154. Please I Need A Hp Increase For My Celica 2002 Gt
  155. how can i make my celica gts faster
  156. how can i make my celica gts faster
  157. Building Toyota Celica tuning an oWners CLUB
  158. wouldn't tis make mre sence?
  159. help:87 celica gt no heat!,n its almost winter
  160. I may be joining the Celica club
  161. 93 celica GT thermostat problem
  162. GE Versus FE
  163. 4age???
  164. spark plugs
  165. Clutch Problem
  166. need heavey duty head gasket
  167. Low power under 2500
  168. I could shoot myself
  169. A few things wrong with my Celica 90 GT
  170. cams
  171. Insurance on a Celica compared to other cars?
  172. Exhaust system question.
  173. motor
  174. Thinking of buying a Celica
  175. tires
  176. new here
  177. need help!
  178. what parts can i use for turboing a 5sfe, PLEASE HELP ME OUT HERE!!!
  179. 7th gen
  180. turboing a 5sfe!!!!!
  181. High RPM's
  182. buying a 94 celica
  183. 85 Celica Tech. Missing and rough idle.
  184. how much is my car worth?
  185. Car Color?
  186. Celica Color?
  187. Platinum Grille Lol!
  188. steering wheel instalation kit
  189. 3s-ge beams
  190. Gas Pedal Stuck
  191. 1988 Celica GT-S Engine Question
  192. collapsible steering column problem
  193. Silver Lining Of Horsepower In The Clouds
  194. God $#!@ Mother !@#$%^& Son Of A @#$%^
  195. I know there's been links like this but I can't find the info for it
  196. 1987 celica st quarter mile?
  197. '93 Celica All-Trac turbo vs. '04 Celica GT
  198. celica question + how much should i pay?
  199. 6th gen headers on 5th gen
  200. 91 celica GT turbo?
  201. full exhaust for 2000
  202. Just wondering
  203. 91 Celica Engine Problem Need Advice
  204. 1988 Toyota Celica Engine Question
  205. Thanks
  206. My Baby
  207. 91 Celica GT slow coolant leak
  208. Pics?
  209. New cylinder head...dangerous!!??
  210. Celica progress
  211. Parts from Japan.
  212. 1988 Toyota Celica Wiring Diagram
  213. 89 3sgte and 93 3sgte block swap
  214. Toyota Approves Use of 0W-20 and 5W-20 GF-4 Oils
  215. 1988 Toyota Celica Engine Question
  216. New Celica?
  217. wont idle?
  218. What is the best trim?
  219. 2001 Celica GT interior Rearview mirror "?"
  220. nother question
  221. "91CelicaST" help..?
  222. maximum hp out of a celica
  223. Bushing kits
  224. noise from rear tire?
  225. Suspension in New Zealand
  226. 90-93 celica engine swap
  227. Rwd.3sgte. Which Transmition Will Fix
  228. 1.6 possibilities
  229. so
  230. Celica Restoration process
  231. im interested in buying a celica!
  232. 2000 celica starting problems and bogging down
  233. questions about actual 3sgte specs
  234. 86 Celica GT Starter Problem
  235. 90 alltrac short block replacement
  236. "02 Celica GTS No Spark
  237. Windshield washer reservoir
  238. Idles too low with A/C on.
  239. affordable 5sfe upgrades?
  240. OEM speakers for '95 Convertible?
  241. Muffler Q
  242. Wheel Torque.
  243. Angel eye headlights for 2000 GTS.
  244. what tires you have?
  245. Stock 1995 Celica Engine
  246. Headlight\CAI Filter
  247. engine conversion question
  248. Celica supra
  249. Swapping Transmission
  250. dude, airbag light.
