rough idle
saturnsc2
02-28-2006, 10:16 AM
o.k. here's what's going on. i'm getting a rough idle when in gear when the engine's hot. when it's cold, the engine idles very smooth & you can hardley feel it run. as the engine starts to warm up, the idle starts to get rougher & rougher. i just recently had the top engine mount replaced because it was collapsed. they changed it from the second design to the first design per the service bulletin. i also had that vibration damper installed per the service bulletin. the other mounts are like new. i was getting vibration at speed from the bad mount, but that's now gone. my steering wheel even shakes a little at idle. what happens is when i come to a stop, it almost feels like the engine's going to stall, but it never does. it's a constant, rough low idle. if i put the car in neutral, it goes away. when i come to a stop, the engine rpm's drop close to just above zero, then pickup a little to a rough idle. the car's a 2001 sc2 & it only has 22,000 miles on it & everythings factory original under the hood other than the battery, that vibration damper, & top mount. any ideas?
saturnspeed_12
02-28-2006, 02:43 PM
well this sounds perfectly normal. saturns are not smooth at idle. over the years it has gotten better. what are the rpms it is idling at and does it bounce a very tiny bit at idle(like 800 up to like 850)?
if its smooth driving, then its just most likely the normal old saturn rumble.
