View Full Version : Metro
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16
  1. 96 Metro - No Go
  2. 91 Metro 3cyl Timing belt help. Timing belt tensioner?.....
  3. Duh......1.0l Fuel Adjustment???
  4. overheat issue
  5. Metro TBI
  6. Any 5 speed Transmission rebuilds with pictures available?
  7. I named my rebuilt Metro "The Phoenix" - now NASA has one.
  8. Auto transmission difficult to shift out of park.
  9. Blinkers won't come on and fuses good.
  10. 94 XFi engine swap into 93 nonXFi-No Spark
  11. Does 92 Metro have auto door locks???
  12. Can the Metro accommodate a Toyota 5SFE drivetrain?
  13. 1995-2000 Trans/Clutch Removal Guide (PICS)
  14. Bummed Out On Rich Fuel Problems
  15. starters
  16. 98 3cyl Metro Randomly cuts out and stalls
  17. AC problems
  18. Very Rough Idle
  19. Egr "sensor"
  20. Storm Seats into a Metro?
  21. Help - Eng identification, crank pos sensor
  22. Timing Belt Cover
  23. Summer Gas Mileage WOW, is this real?
  24. 91 Metro High Idle When Warm
  25. hard to start
  26. Coolant Tube Problem
  27. tach
  28. VSS code 24 after installing cruise control
  29. Almost had to shoot my geo
  30. One thing I hate besides the fuel filter's location
  31. Just as I pulled in this morning ..
  32. Metro A/c Freon Capacity??
  33. Parking Brake Release Button
  34. Metro Newbie with a 1.3L
  35. 3 Cyl Interference Engine Debate
  36. $4.00 a gallon gasoline??
  37. tires
  38. Front Crank Seal Removal
  39. Odd & Assorted Questions for Metroglodites
  40. 97 Metro LSI dies when it gets hot
  41. Control Arm some help please
  42. Temp Gauge readings
  43. 13" Wheel upgrade mpg drop...
  44. If you plan on exhaust upgrades
  45. compression on a 1.0
  46. 91 Metro 1.0 3cyl. Automatic Crank seal advice needed
  47. 95 1.3L timing set, and specs
  48. Rocker Panels?
  49. 91 geo metro lsi help plz
  50. 95' 1.0 trans
  51. Bad fuel pump?
  52. Article on CNN.com
  53. Metro Frame can be saved!?!?!?
  54. Rough idle while cold
  55. Failed Emissions Test
  56. Speedo problem
  57. Control Arm
  58. Exhaust/oil pan
  59. bypassing Oxygen sensor after cat
  60. Selling my 92 Geo Metro (*tear)
  61. My Metro's new exhaust!
  62. Getting a newer car (not a Geo though) thought I'd share...
  63. Will 175/70 fit 99 Metro?
  64. 1994 metro dying
  65. Super high idle
  66. 1993 Metro Back Strut Removal - Blast!
  67. 1994 metro stalling
  68. Looking 4 Geo Metro 91 Parts
  69. metro with oil in air filter housing.
  70. troubles with trouble codes
  71. discrete wiring idea
  72. need air intake hose
  73. Hard to start & no power
  74. 91 Idle Air Controll!!!! Where Can I Get One
  75. Could a 3 Cylinder Metro be made to run on Ethanol?
  76. 99 metro uneasy on highway
  77. 94 Metro Engine/transmission swap
  78. Idle Speed Control Motor
  79. Tire size
  80. Replacement Top Recommendations
  81. CV axle noise how to tell
  82. Throttle Position Sensor
  83. Climate Control
  84. Getting Vehicle Warrentee Offers - Garbage?
  85. Dashboard Painting
  86. Timing belt cover
  87. 95 Geo wiring issues
  88. Adjusting timing
  89. O2 Sensor and Fuel Filter Where Are They?
  90. Engine I.D.
  91. Instrument cluster installation
  92. tach problems?
  93. Help 97 Geo Metro throttle position sensor
  94. Installed an A/C belt now New sounds
  95. Geo Gauge White Face overlay
  96. 91 Lsi Convertable. Shocks and Vacuum Hose Chart ?
  97. It's a BumbleBee!
  98. Crazy Parking Jobs In A Metro (Picture)
  99. New P155-80-12" KUMHO POWER STAR TIRES - 2 Sets of 4 left!
  100. test
  101. my 12 to 13 inch steel wheel upgrade project PICS
  102. The way Metros Die - rust out in the control arm / underbody area (PHOTOS)
  103. Help, Car Engine Runs Fast
  104. Exhaust upgrade
  105. strut time
  106. 97 1.3 metro dash light
  107. 1.0L Head removal guide
  108. hwy mileage in the city
  109. Alternator noise
  110. Head light issues
  111. Does it do ANY good to use STP (Oil Additives) ?
  112. Exhaust Pipe Soot
  113. 96 LSI revving engine when in neutral
  114. going from 12 to 13 inch wheels, alignment needed?
  115. 93 Metro cuts out @ hiway speeds...
  116. Automatic trans blowing fluid on top of trans???
  117. 12" tires & rims.
  118. 94 Metro timing
  119. '97 Help
  120. Installing an A/C unit on a 96 LSI
  121. wheels and tires
  122. Ignition timing - 92 Metro
  123. 97 metro
  124. Front Wheel bearing Replacement
  125. '92 Metro idle
  126. Over play on clutch pedal
  127. General Metro models
  128. Newbie - 1993 Metro Convertible with fast Idle
  129. Burning Smell
  130. Help Metro multiple symptoms, need fix
  131. test
  132. No more Geo - thanks for all your help...
  133. Here's my Metro
  134. '95 Metro 1.3L Error code 15
  135. 1998 3 cylinder firefly won't start!
  136. The UK gets it...
  137. Compression Test
  138. Code P0420 again.
  139. EGR passage cleaning
  140. Passenger Side Rotor RED Hot, Caliper or Brake Line?
  141. Which weight oil?
  142. clicking noise
  143. Putting the Belt back on
  144. Exhaust Bolt Springs
  145. electric fan
  146. What IS this sound? - Come on you Geo-geniuses! Help me out!
  147. Easier with tire on or off?
  148. Bad gas mileage
  149. Cylinder Valve Job :)
  150. Spark Plug Gaps - Regular vs Platinum
  151. oil on plug 3 only 300 miles.
  152. Rear Swaybar Bushings
  153. Drum Brake Removal
  154. Tbi 911 / 411
  155. How to Post Photographs on the Forum
  156. Help, Crank but no start
  157. 1991 Geo Metro 4 door ( Bad Gas Mileage )
  158. What is this sensor?
  159. Losing Coolant over time
  160. 4 or 5 bolt crank pulley
  161. weak fuel pump?
  162. Lug Nuts for 13inchers
  163. 92 XFI Rebuild. Runs GREAT! But vanishes in a cloud of SMOKE!
  164. Block Rebuilding 91 3 cyl
  165. 91 Geo Metro 5 door 12 inch rims
  166. Fuel pump
  167. 1991 3cyl Metro (FAN QUESTION) Are both fans supposed to run at same time?
  168. 95 Metro - Coolant Temperature Sensor
  169. 92 Metro timing
  170. P0300 - Random/Multiple Cylinder Misfire
  171. 91 Metro 1.0 3cyl. automatic engine idles high then low in park and sputters up hills
  172. Metro Parts Interchangeability ??
  173. Stubborn Bolt
  174. 93 metro xfi no spark issues
  175. 1991 Firefly(Metro) parts available..Toronto
  176. Repair Manual for 97 Metro
  177. Femaledriver prism fuel filter
  178. Code 51 & EGR 94 1.0 L
  179. Need Website for Wheel/Rim Vehicle Swapping
  180. Engine swap
  181. Crankshaft Pulley
  182. 2000 geo metro / suzuki
  183. 0.9 vs 1.1 bar radiator cap
  184. Problem shutting puter down to check timing.
  185. Manual Tranny help
  186. What gives..???..trannys different
  187. 2000 Chevy Mtro wont start hot
  188. Head Job/Ring Job
  189. Replacing front crankshaft seal
  190. 91 egr
  191. Kiss my rear 4 bucks a gallon!!!
  192. Tranny swap, will it work?
  193. Camshaft Pulley
  194. For Dr. Bill...HHO generator
  195. 95 Metro 1.3, loads of work, still no run
  196. 97 Metro speedometer quit
  197. Final drive ratio
  198. Vacuum advance for distributor?
  199. manual transmission oil?
  200. Wheels for a 93
  201. Timing Belt
  202. Strange Smoke and Smell
  203. half-shaft help
  204. transmission whining!
  205. 96 EGR Solenoid?
  206. 12" to 13" wheels
  207. Rear window defogger
  208. 96 Sedan-Check Engine Light-CEL does not blink with the Fuse Test
  209. How does one reset the SRS (airbag) light?
  210. 14 inch wheels? .. anybody?
  211. fuel pressure
  212. Lifters on 1 Lt. engine
  213. Changing front struts
  214. 92 Metro wont start after hard braking
  215. Newbie's 94 died on freeway
  216. Electric Fan
  217. Reasons for poor fuel mileage
  218. 12" versus 13" tires for fuel mileage
  219. Finding a MAP sensor
  220. Metro Achilles Heel (at least in Northern climates)
  221. Front Wheel Bearing change
  222. Syncro problem
  223. 95 metro 1.3L camshaft sensor needed
  224. I need torque specs.
  225. Slow returning to idle speed
  226. Car Won't Start
  227. I really need a timing belt cover and a crank & camshaft sprockets
  228. MAP Sensor, What is it?
  229. engine bogg
  230. Wire harness problem
  231. Another Nasty Noise
  232. Well boys!!! What do ya think??!!??!!??
  233. Engine swap
  234. Car Bogged Down
  235. Factory Service Manual
  236. 90 to 94 Engine block swap
  237. Engine dies when decelerating
  238. Slime!
  239. Rev limiter????? 95 metro
  240. 95 4cylinder wont rev., No power
  241. A Nasty Grinding Noise
  242. Geo fixed
  243. A/C heater fan switch
  244. Great Snapped Bolt on Control Arm! Now what?!?!
  245. Any demand for Metro's
  246. When to call it quits with a Metro.
  247. What is the lug pattern size???
  248. What do you guys think??
  249. PSI Question
  250. annoying squealing belt!
