View Full Version : Metro
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16
  1. 94 Metro odd reverse
  2. 1993 Geo Metro Flywheel problem
  3. Good Deal?
  4. Interesting Symptom, What Do You Think
  5. Can I do a "Home Front Wheel Alignment" ?
  6. Hopeful Metro owner...
  7. heres a new one-fuel filler tube
  8. 97 metro broken a frame
  9. To the Forum Manager - BIG Problem!
  10. Burning Valves in the 3 cylinder engine
  11. Please Educationalize me on Clutches...
  12. ...My 96 Geo .....
  13. 94 metro flywheel transmission bearing
  14. 38mm tire offset work on a 92 Geo?
  15. Taillights interchangeable?
  16. Need spare tire clamp/jack bolt???
  17. '93 Metro 5 spd manual oil level
  18. DMV notification when changing engines?
  19. Can It Be Done??
  20. My Hwy Breakdown and Quick Fix
  21. Distributors
  22. Results on my 92 Metro so far...
  23. Any auto trans parts worth saving?
  24. Engine turns over but won't start
  25. Battery hold down bolts/bracket?
  26. checking o2 sensors with multi meter
  27. Map Sensor - 1990 Geo Metro, 3cyc.,Auto, Air
  28. 02 sensor
  29. '97 four cylinder
  30. Throttle Position Sensor...malfunctioning?
  31. Ignition system...92 Geo Metro
  32. very fast idle
  33. Temp Guage Stopped Working
  34. Towing with a Geo Metro.
  35. 92 1.ol crank seal
  36. New coil...MSD 8202 or 8222?
  37. Metro want to raise suspension.
  38. Wal-Mart's 5W-30 Motor Oil
  39. 1990 Geo Metro - Little Or No Power At Cold Start
  40. Splash shield...passenger side front
  41. geo metro speed parts
  42. tranny
  43. 1990 Geo Metro Gas milage?
  44. Cold starts and Mmisfires - 1990 Geo Metro
  45. 97 metro still bad milage
  46. Diagnostic Scanners
  47. Replacing water pump
  48. New Ignition coil...MSD Blaster 2 good?
  49. fuel tank size
  50. Using ATF To Thin 10W30
  51. im loomin for a windsheild
  52. need some serious help on this one
  53. 93 Geo Metro - Won't start/stay running
  54. Block drain?
  55. Engine question
  56. Tight Ignition Switch
  57. Different ECUs
  58. Warning System - Lights On - '93 Geo Metro?
  59. Check Engine Code: 1995 Geo Metro
  60. Windshield Replacement
  61. anyone running 3 cyl on carb help me???
  62. auto/manual starter compatability
  63. Oxygen Sensor
  64. Manual Transmission - Clutch Bolt Fill Hole
  65. Uneven Idle
  66. what tranny's would fit?
  67. Will P275/80 R13 tires fit a 1995 LSI?
  68. How insane can this lack of privacy thing get ??!!
  69. Driveshaft question
  70. Do Auotomotive Parts Manufacturers Listen?
  71. Nuther airbag question...
  72. Okay seriously, WHY did they stop making Metro's?
  73. pulling engine
  74. Anyone have a '93 Metro 3 cyl Fuse Box Map?
  75. Folding Back Seat
  76. 97 metro hold brake and car still picks up idle
  77. Need everyone's advice - thinking about getting a Metro!
  78. EVAP tank pressure control solenoid vac valve??
  79. 93 Conv. Metro available
  80. Airbag question...
  81. Sticky front end, 93 Metro....
  82. Question about Clutches
  83. Battery Corrosion
  84. 1998 Metro No power to fuel pump - Emergency Switch???!!!
  85. Broken clockspring
  86. 92 Geo and 99 Malibu Same Problem
  87. does 95 hood fit on a 94?
  88. oil in carb
  89. Does anyone KNOW which Oil Filter is best?
  90. What Pressure Should Be Run In Tires (Nitrogen?)
  91. defroster fan switch
  92. Loud ticking/knocking in engine
  93. smokes bad ,good comp, running rich, help
  94. Suspension change: Good idea or Bad?
  95. Piece of Junk Geo I am beginning to hate these things....
  96. Problems with timing
  97. Geo Metro Code 15 Help.
  98. Can a 4,6,8 cylinder Tachometer be set for a 3 cylinder?
  99. 1995 1.3L, Canadian Model, Two Automatic Transaxle Questions.
  100. 96 1.3 LSi with a P0420 Code
  101. How do you reset the "check engine" light?
  102. Dropped alternator into motor oil. Is it scrap?
  103. Oil Level - How Important Keeping It at Top Mark?
  104. '94 Fuse Box... where?
  105. Tires - Nitrogen versus Air
  106. fuel injector problems
  107. Problem with pulling to the right
  108. The Flight of the PHOENIX !
  109. Which brake pads/parts?
  110. Adding 'Cruise Control'
  111. Geo Metro No Spark--No Start
  112. Metro Lighting Solution
  113. Oil Type And Brand Preference?
  114. ScanGauge question
  115. Parts for Airbag Replacement
  116. 1993 metro, front right rattles on take off
  117. Loud as Heck squealling
  118. timing question '94 1.0
  119. Anyone ever put a 350 in a Metro?
  120. 1996 Geo Metro Radio interchange
  121. Heater Vent for Dash
  122. 96 LSi tranny problem...help!
  123. Any techniques for getting a valve cover off?
  124. Paint code location
  125. '95 Metro questions!!!
  126. Lower Strut Brace From Turbine Tech?
  127. Seat Belt Return Springs
  128. '91 Metro Quit, now won't start.
  129. What to do with a "parts car"
  130. Cylinders...
  131. Ignition short
  132. Transmission Problems?
  133. Brake Pad clips
  134. Finding Rocker Panels?
  135. Trouble finding 12" tires
  136. Official Metro Parts Mail Order list
  137. 1991 geo metro engine swap
  138. Diode module?
  139. 96 Engine swap
  140. Rust on rocker panels?
  141. Valve adjustment
  142. Rebuilt engine, Drinking oil...
  143. 97 metro 3cyl.timing
  144. heavy black smoke from exhaust pipe
  145. awesome mileage on dirt roads!
  146. Rear buzzing or humming sound
  147. 1998 metro help please!!!
  148. Clunking sound in Metro rear end question
  149. Replacing Struts on a Metro 92 1.0 liter
  150. Anyone thought of a Hybrid Metro?
  151. Different MAP sensors...?
  152. 1998 Metro Idle Problem...HELP FAST!!
  153. Metro 3 cylinder 1989 - 2001
  154. 1994 engine in a 1997
  155. P0136 code - can I wait?
  156. 1.0 atx transmission problems...
  157. Need picture of how charcoal canister is hooked up
  158. A compilation of all my '93 Metro threads saved to a CD
  159. Replacing Fuel lines on 92 metro 1.0
  160. clutch slippage when i lay on gas
  161. Looking at 95 Metro 129,000 miles
  162. Highest Mileage on a Geo Metro? I mean Odometer Mileage not MPG
  163. Setting up the Timing Belt & Distributor
  164. 1997 Geo Metro 1.0 Low MPG
  165. Results from my compression test
  166. 96 metro 3cyl cold start floods bad above 1800 rpms when warm runs fine
  167. How does the older 3 Cyl Metro advance the spark?
  168. coolant problem question
  169. Broken timing belt
  170. ignition problem
  171. Man trans swap
  172. Spark Plug Poll - For and Against Bosch platinum Plugs
  173. Metro won't start
  174. intake manifold
  175. Rough idle and misses sometimes when taking off from stops.
  176. desperate for an answer - geo clutch
  177. What happened with Platinum Spark Plugs? Almost quadrupled in price!
  178. '97 metro - clutch and TBI questions
  179. Rusty rocker panels
  180. '97 metro - control arms/ball joints
  181. I need some help...
  182. halfshaft help
  183. Holy Molie! You can save these threads to a CD !
  184. 98 metro po400 egr code
  185. Help replacing a part on a '93 Metro
  186. 92 Metro 1.0 Auto install to 92 Geo Metro Manual
  187. A way to Clean the Carbon out of the IM Passageways !
  188. Selling my dead 91 Ragtop.....
  189. New Tires
  190. Window Hop Cured!
  191. Need gas filter (in between pressure sensor and tb)
  192. Need to know what a part is
  193. Erratic idle speed
  194. Haynes manual missing a half-chapter??
  195. timing sprocket spacer or crank walk?
  196. Geo Metro 1994 1.0L, No Spark from Secondary on Coil! ECM? Please help!
  197. water leak
  198. Message to Moderator(s)
  199. How does oil get thru all those bearings?
  200. 1995 Metro 4cyl-Auto Trans Problem
  201. Airbag Malfunction
  202. Metro 1.0L: What's the letter after G10 mean?
  203. Disable daytime running lights
  204. idling versus shutting off at lights
  205. Need a new IAC valve...anywhere I can get a new one for cheap?
  206. My wife's Idea! Can it be done...?
  207. How do you clean the Carbon out of the Intake Manifold Gallery?
  208. Car tries to die when headlights on/heater on, any suggestions?
  209. I need help ID'ing a knock...
  210. Need Headlights..
  211. wanted metro 13 inch wheels
  212. Good buy?
  213. Headlight Bezel
  214. headliner replacement help
  215. Oil Pan, RTV? Gasket? or Both?
  216. Thought Metro Was Dead
  217. drive shaft won't come out
  218. Why does my car sound like this? (VIDEO)
  219. Alternator belt broke on the road
  220. Air Bag Diagnostics
  221. Persistent Annoying Timing (Or Something) Malfuntion
  222. '93 Metro electrical question:
  223. Timing help
  224. 94 Metro shift issues
  225. need cat converter info please
  226. nothing!!!
  227. A discussion of engine function.
  228. Valve Adjustment
  229. 93 Geo, no start.
  230. Looking for a replacement Metro :-(
  231. Vacuum diagrams
  232. If my 3 cyl dies - I have a solution !
  233. HELP! can't find Metro part
  234. Strange brake problem
  235. NOT the end of my '93 metro...Life after death! RINGS
  236. Busted Piston Skirt - '92 XFi - how long will it run?
  237. JDM or Replacement Engine Geo Metro
  238. Electrical short causing shifting failures
  239. JDM engine in a 95 metro
  240. 97 Geo Metro 1.3 no hot start
  241. air intake question
  242. Is a "cover" needed?
  243. 93 Metro 1.0, Slow Crank/No Start problem
  244. That's the end of my '93 Metro.....
  245. 94 GEO prob
  246. rough engine idle and fuel pump noise
  247. Fouled spark plug on 92 Geo Metro 1.0
  248. 5sp Manual tranny FILL PLUG?????
  249. EGR Solenoid
  250. 97 1.0 Horrible Performance
