View Full Version : Metro
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16
  1. just purchased
  2. 02 sensor/MAP sensor
  3. fuel guage is wonky
  4. HELP! Bad TPS?
  5. 97 metro 1.3 l spark timing-please read
  6. Reassembling the TBI and getting it running again.
  7. 95 Geo metro
  8. 97 1.3 Timing mark Alignment - belt
  9. radio panel
  10. Best oil weight/type
  11. Tailgate Struts
  12. 96 Metro start/run issues
  13. Does the 1992 Geo Metro have power steering?
  14. What else can I check?
  15. 96 metro starting problem?
  16. stripped bolt won't come out
  17. 1.3L engine swap - manual to automatic? Help pls.
  18. Where is the "check plug"
  19. Rain X Removal
  20. '97 metro clutch problems
  21. 94 Metro ignition switch
  22. compression test
  23. Failed HC (PPM) Emissions
  24. New engine for my 2000 puddle jumper
  25. Searching for parts...
  26. oil filter dripping
  27. turbo cam
  28. 9th digit of VIN
  29. o2 senser #1 bank#2 (geozuki,help!!
  30. Poor MPG / California ECU - I think I may have found the problem!
  31. 94 Metro suspension questions
  32. Oil drain plug tightened by Superman!
  33. Need to know which front wheel bearing is bad!
  34. 96 Metro Shift Solenoid A
  35. Good place to buy accessories
  36. Tailgate Lock
  37. BrainBuster - Bet you cant figure this one out!!!
  38. 98 metro california duel cat converter
  39. Need Technical Assistance
  40. transmission squeal?
  41. replaced engine, no fuel, no spark,
  42. Year compatibility
  43. Year compatibility
  44. 96 Brake adjuster
  45. High Pitched Whiny Metal Sound from Front Right Tire
  46. 02 sensor #1 heater failure?
  47. I need wire harness and diagram for 97 3cyl
  48. 3cyl in Tracker, What do I hook to run???
  49. Engine Swap 1997 I3 into 1990 TRACKER!
  50. Annual 95' Geo Metro Summer Update
  51. hmmmm makes me wonder.....
  52. 97 Geo Metro
  53. '92 Metro w/ Racing Stripes
  54. Homemade oil catch can and new air filter
  55. Homemade oil catch can and new air filter
  56. Steering wheel shimmy
  57. Head replacement?
  58. was there a daihatsu metro?
  59. what struts should I buy?
  60. belts
  61. Anybody ever welded the unibody/control arm?
  62. explain thie ghetto race...
  63. Putting Different Horn in Metro question
  64. Choices: 4 door 90 Auto or 2 door 92 5 spd
  65. radiator flush help
  66. repair manual recommendations?
  67. swapping 1994 l3 into 1997 chasis
  68. Rebuild current engine or do a JDM swap?
  69. Anyone disable the Daytime Running Lights?
  70. 96 metro cranking problems
  71. Huge clouds of smoke intermittently coming from car
  72. 94 metro 5 speed sloppy shifting pattern
  73. 98 Metro Lsi: A/C has failed after light impact
  74. electrical failure
  75. Is there a "performance" ignition timing setting?
  76. Timing way off after timing belt job
  77. 96 metro fan won't work
  78. How do I replace the Fuel Pump?
  79. Do we have to set ignition timing after timing belt install?
  80. Severe oil leak from crank seal
  81. Body replacement?
  82. Will Sprint 5 speed transmission work in metro
  83. Air Conditioning
  84. How much would you sell for? 96 130k, 1.0L...
  85. 95 engine into 96 metro----crank sensor??
  86. 5W30 vs 10W30
  87. What is wrong with the A/C system ?
  88. Bearing popped out of control arm
  89. Fuel Milage Update
  90. 2000 metro 3-cyl rebuild
  91. engine conversion
  92. Idle constantly going up and down
  93. The Dreaded Milky Oil
  94. question???
  95. Will a seat from another vehicle fit Metro?
  96. Geo Metro Simply The Highest Mpg Car
  97. Desert Driving, HOT: Suggestions
  98. 94 xfi sticking starter solenoid
  99. Rod knock - Can this sometimes be an easy fix?
  100. 1994 Geo Metro overheating/GloriaMetro
  101. 1999 service manual for sale
  102. Check Engine light comes on only at heavy load
  103. hinge bushings
  104. 95 geo metro 1.0 Rebuild and now I have no oil pressure.
  105. AC Question
  106. 96 LSi Tranny fluid puddle on top of tranny
  107. 97 metro changeover 1.3 to 1.0
  108. Help with Installation of Timing Belt
  109. HELP! Looks like I got the wrong timing cover from Chevy dealer.
  110. Simple Chevy/geo Metro Question
  111. 95 Metro LSI losing power
  112. this is gonna be interesting
  113. overheating
  114. Metro Mud Boggin!
  115. Awsome Interior? Whaddya Think?
  116. Oil leak on timing cover side
  117. 97 metro check engine light
  118. hood latch position
  119. how to replace hood 94 metro
  120. 97 metro wont start.
  121. Why can't I post pictures?
  122. 96 1.3L idler pulley?
  123. anyone looking for a motor swap for their metro?
  124. HELP! I cant get my darn tires off!
  125. ECM Help
  126. instrument cluster swap
  127. trouble removing centerbolt
  128. Headlight Problem Revisited
  129. can you help me balance my brakes?
  130. loosing spark - '96 1.0l
  131. Surge, surge, surgin' when warm
  132. check engine light
  133. New Brakes squeaking
  134. Anyone need a G10 1.0L motor - eastern Ontario?
  135. 91 metro ideling problem
  136. Clunk from rear
  137. Geo Hubcaps
  138. 1996 Firefly (with 1.3 L 4 Cyl Metro Engine) low compression #2 Cyl
  139. Idle constantly changing
  140. 94 Metro HORRIBLE Emissions Test!!!
  141. Two questions
  142. miss in 90 metro 3 cyl LSi
  143. need back window for 2 dr 91 metro
  144. 94 geo error code 13
  145. spark knock
  146. radiator for sale: for 1.0 5-speed, 1 year old
  147. A/C not Working
  148. 1997 geo metro
  149. Would it hurt anything to remove the AC Pump?
  150. Lets get this bugger back to working!
  151. I'm Baaack.... Got off my dead butt! Timing Cover. WITH PICTURES!
  152. fuel guage
  153. geo metro bad milage 33mpg help help!!!
  154. Help with replacing Rad on 96 1.0 manual
  155. JDM engine dist.
  156. Where to get parts?
  157. changing auto to manual
  158. changing auto to manual
  159. wheel bearing noise?
  160. 16 valve engine on99 and up
  161. Time for me to move on to the Celica Forum.
  162. Older Convertible Tops - Hazy Windows
  163. resistor spark plugs -- ignitors (coils)
  164. How to improve gas mileage?
  165. Help with 1997 Metro Wiring and Vaccum lines
  166. Water Pump O ring
  167. geozukigti where are you?
  168. 1994 Metro Codes 46 & 51
  169. 1994 Metro Codes 46 & 51
  170. Exhaust Hanger
  171. Auto Transmission Fluid level
  172. Transmission swap 95-98
  173. work vehicle?
  174. Platinum Spark Plugs
  175. Cabin Air Filter
  176. Scored a 61k actual mile car
  177. repair procedure for rusty control arm supports?
  178. About to Buy a Metro
  179. fuse, turn signals, auto transmission
  180. Geo Metro factory Delco radio question
  181. Engine swap.. Need help!!!
  182. weatherstripping 1998 geo metro
  183. picture of a 97 geo 3 cyl with the timing belt cover removed
  184. parting out 93 swift: 1.3 sohc - eastern ontario
  185. coolant leak at tube on back of water pump
  186. geo metro wanted
  187. 2000 Metro rough idle with air on
  188. 92 metro convertable body rust ?
  189. 93 - front rotor replacements - hubs
  190. Broken Radio Antenna
  191. '94 tranny quirk, control solenoid?
  192. Disc brake conversion
  193. Great price on Walker exhaust for my 97 Metro
  194. Another '98 not starting
  195. Where is the Blinker Fuse located?
  196. I need help!!
  197. Auto Transmission Gasket
  198. Headlights Problem
  199. Oil pressure sending unit location
  200. White Face Guage Overlays
  201. 4.10 vs. 3.89
  202. 94 engine R & R
  203. 92 Geo Metro Squeeling
  204. 94 Geo Metro questions
  205. 92 geo metro 1.0 won't run
  206. Lower control arm bushings
  207. 98 wont start
  208. 92 metro help needed
  209. 98 Metro Transmission question
  210. Soon to be for sale
  211. Metro Run on
  212. Will a 2000 1.0 replace my 1996 1.0
  213. MPG question
  214. Weird Surging problem-93 w/ 90 engine
  215. Emissions related question
  216. Woodruff key
  217. Rotten Egg Smell from car
  218. 1989 Geo Metro LSI: sputters/lose power at 55mph..... again
  219. 93 Metro Bucking
  220. 1994 Metro 3Cy 1.0Ltr
  221. 98 Metro clutch R&R?
  222. 92 Autimatic To Manual Conversion
  223. looking for cheap small parts
  224. WTB: 90-93 convertable LSI
  225. cabin air intake
  226. what wheels fit?
  227. Engine practically dies when lites on.
  228. Looking for a parts car
  229. 2001 Geo Metro mileage drop from 52 mpg to 38 mpg, why?
  230. how much does it cost you to drive?
  231. 95 Metro Rough Cold Idle
  232. 92 Metro convertible horn (lack of)
  233. lubing hatch rails
  234. rear brake adjustment
  235. Idle roaming.
  236. Still no start 97 geo metro
  237. front end clunk
  238. V4?
  239. Should tires turn freely or have resistance?
  240. 97 no start
  241. brakes and rm\pm affected by fan blower
  242. Need a few parts--Does ne1 have these!??
  243. Car just started skipping??
  244. measuring rims/and off set
  245. Best way to lubricate a Speedometer Cable?
  246. roof rack weight limits
  247. Vin #
  248. replacing lifters
  249. Bogging with anymore than 1/4 throttle
  250. too much heat
