View Full Version : Metro
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16
  1. Destroyed radio antenna
  2. cig lighter and radio
  3. 98 chevy metro- no spark whats the problem?
  4. Water on passenger floor
  5. Geo Metro Roof Rack!!!
  6. 1996 Geo metro distribitor
  7. Geo 1.0L Vibration is kicken my BUTT
  8. Roof Rack for my Metro...
  9. I need to know!!
  10. This one is a tuff one to solve, PLZ help!
  11. Steering Problems/Wheel Tugging
  12. manual transmission plug problem
  13. 90 Metro 1.0
  14. wheres the paint color code
  15. Metro steering wheel
  16. Are metro clutches hard to fix?
  17. Thinking about buying a Geo Metro. Couple questions and are these good prices?
  18. Crankshaft Pulley Bolt TOOOO TIGHT
  19. 1995 Geo Metro Idle speed
  20. Do it yourself brakes
  21. 98 Metro Will Not Fire.
  22. Engine Change Options...
  23. SCARY Car Problem (not Metro related)
  24. Engine Internals! Where to buy?
  25. Timing / idle irregularities
  26. engine dies and won't restart
  27. Parting out. 89 GTi automatic
  28. transaxle
  29. Would you prefer a 5 speed manual or an automatic?
  30. naughty automatic transmission
  31. Timing Belt walking off
  32. '95 3 Cyl Man 1.0L 25 lbs of compression loss in cylinder!
  33. timing belt installation w/o marking
  34. Convertible Frame
  35. Electrical Problem
  36. Key broke off in a 92 Metro
  37. Key broke off in a 92 Metro
  38. Mechanical engine noise - 3 cyl 1.0 L. ?
  39. swap 4 cyl to 3 cyl is it possible 1997
  40. Alternator belt tension
  41. Fuel pump info
  42. Ordering a JDM
  43. Noise Diagnosis
  44. Coil Spring Ratings
  45. new engine?
  46. Need Help identifying part
  47. JDM help
  48. '95 Metro OBD-II
  49. Can a Geo Metro with 12 inch tires use 13 inchers?
  50. The Problem buying 12 inch tires for Geos !
  51. First post -- first Geo
  52. Pulley pulling problems!
  53. 1996 Metro CV replacement.
  54. sry
  55. Need some advice
  56. ugliest frikin cars ever!
  57. got some major probs with my 96 metro
  58. 1998 Geo needs motor!!!
  59. CV Shafts - What years will fit?
  60. HELP !! CHEAP CRankshaft for metro 2000
  61. 1996 geo metro//should I keep it???
  62. 1993 Metro 1.0L BlowBy
  63. 2000 1.0 wont turn over at all..
  64. evaporator ac 1996 geo metro 1.3
  65. replacing the dimmer switch
  66. Metro 3 cyl thermostat temp
  67. Is there a SMALL, CHEAP Tachometer for a 3 cyl Geo?
  68. 2000 Chevy Metro
  69. How to get rotor off? Hub retaining screw stripped
  70. 1.0L JDM engine
  71. AC parts for sale
  72. Geo jumped time
  73. gremlins in my geo!
  74. Water warping rotor? EGR question too...
  75. 94 help!
  76. 92 Metro Ragtop-Parts
  77. 89--sprint 3-cly carb engine-need help
  78. cuts out @ full throttle
  79. Paint removal
  80. 1.0L 5spd 38 mpg w/o AC -- SO WEAK IT'S DANGEROUS TO DRIVE ON HIGHWWAY
  81. maximum driver height
  82. Running Rich Injector
  83. you don't know 91 geo metro( i need help)
  84. Valve Lash Adjustment on 1.3L engine
  85. 95 1.3 engine parts for sale
  86. Does a '93 have a Fuel Filter ?
  87. PCM location???error code 42
  88. 96 geo metro passenger mirror
  89. Mechanic running me crazy
  90. Does anybody know what this car may be worth ?
  91. where to find head bolts?
  92. 1989 2door dodge shadow
  93. 1997 Geo Metro LSI needs home
  94. Fuel Tank Capacity
  95. Cam gear marks alignment
  96. New Exhaust System?
  97. 2000 metro wont start
  98. Replaced 1.0 head- Can't get it started
  99. 98 Chevy Metro Heat Fan Switch Control
  100. 98 Metro Auto Transmission Problem
  101. 97 Geo Metro Stalls
  102. Metro Wanted to Buy
  103. In the middle of swapping engines
  104. Ragtop Repair
  105. replacing timing belt
  106. 1.0 hp specs
  107. Looking to purchase a 1990 LSi Metro Conv
  108. Burnt exhaust valve...again
  109. Gas Light
  110. 93 metro for sale to good home.
  111. Need a transmission
  112. 93 geo metro wont start
  113. Loss of power/backfiring under load
  114. AC System Removal question
  115. How to Change the Fuel Filter?
  116. 86' Tempo for SALE
  117. engine swapping
  118. Another 5 speed tranny
  119. How to time a 1997 Geo Metro
  120. 5- speed tranny
  121. 1993 metro antenna
  122. Rough idle with air on, dies when coming to a stop
  123. A/C Compressor Seal
  124. Left front click with Vehicle Speed
  125. Center console from another car?
  126. new to metro lsi
  127. A/C wiring schematic??
  128. 95 Geo Metro Engine Change
  129. Aftermarket radio antenna 91 Metro
  130. EGR CLeaning
  131. 97 Geo Wont start!!!!
  132. Broken Convertible Top (Header)
  133. Engine swap
  134. Question regarding Dodge Shadow (lol)
  135. geo metro moter swap
  136. 3800 Supercharged engine swap...
  137. O2 sensor and brakes
  138. Automatic Door Locking
  139. storm and metro blocks?
  140. Ac Removal/Horsepower Increase
  141. Rear disc brakes
  142. Self-esteem boost for us geo guys, lol
  143. radiator upgrade?
  144. MAP sensor for 91 Geo Metro 3 cylinder
  145. Electronic Turbo???
  146. Radio Removal/CD player installation
  147. 1997 Geo Metro Headlights
  148. JDM Motor swap/no power
  149. Oh yea, you're jealous :-P
  150. 91 Geo for sale in Vegas
  151. No Power in a 95 1.3
  152. how much tranny fluid???
  153. brake rotor removal
  154. Cranking Problems
  155. A/C Unit for a 93 Metro
  156. fuse map
  157. JDM engine replacement. Done!
  158. It's 110 degrees outside..........
  159. Window Problem
  160. Any oil pump tips?
  161. why the hell is this happening!!!!!!!!!!!!!!!!!!!!!
  162. Tapping Solenoid Starts Car
  163. Hollowing out the catalytic converter.
  164. geo metro steering knuckle removle..
  165. Whats the average gas millage?
  166. Click at relay box, NOT starter
  167. A/C compressor noise
  168. Intermitent Start Problem
  169. how much hp?
  170. 91 Geo Metro Valves Replacement
  171. 91 geo metero crankshaft removal
  172. 2000 Metro Stock Stereo Removal
  173. tires for 96 metro
  174. Radiator Bolts
  175. automatic/manual
  176. good news bad news engine compression test
  177. Fuel Tank Baffolding??? Something Else???
  178. need for the plastic around CD player and lighter
  179. 94 Metro PCV location
  180. Disappearing Oil
  181. Tps
  182. Parts for sale
  183. How to disconnect auto door locks?
  184. I may have a Geo for sale
  185. Inop A/c
  186. 96 Geo Prizm Squeaking Problem/Steering Pump Problem?...Cant Figure Out what it is?
  187. '93 Geo Metro 1 Lt 3 cylinder MOTORCYCLE Engine?
  188. Geo transmission
  189. Poll - What is your Metro's Gas Mileage?
  190. i want/need a geo
  191. 93 Metro rally car
  192. Where to get window seals & Weatherstripping??
  193. Tps
  194. 5 speed popping out of gear
  195. metro fuel problem female needs help.
  196. 1993 Geo Metro head gasket
  197. Can't find the daignostic fuse receptacle to check my check engine codes
  198. 97 Metro LSI Hatch Dies?
  199. Looking for Parts... and info
  200. Type of Oil?
  201. body parts?
  202. metro/swift valve cover needed
  203. Beeper inside when ignition turned off !
  204. Anyone who knows timing belts replacement?
  205. Is the Suzuki 1.0 L engine an oil user?
  206. Geo Metro 96 Auto Trans check engine light on
  207. Metro - Hatchback, LSi and the XSi - ?????
  208. Remove/Replace Radio- 1994 Metro
  209. still looking for 3 cyl performance parts
  210. Spark Plugs???
  211. Tire Pressure versus Miles per Gallon ??
  212. Are Geo Metro Automatic Transmissions any good?
  213. coolant flow through TB on 1994 Geo Metro?
  214. 99 Fuel Filter, HELP!!!
  215. water
  216. interior exhaust smell?
  217. Fuel Injectors?
  218. 91 Rotor change ( FUN! times)
  219. Could this be a fuel pressure problem?
  220. Geo Mechanic?
  221. Problems starting my 92 Metro ...
  222. 2000 chevy metro, no start, need help
  223. Downshifts into 2nd at 50mph.
  224. Does anyone have a Jensen CD615x CD Player in a GeoMetro?
  225. Summer is coming are you ready to stop your Metro from getting too HOT?????
  226. Any other good forums?
  227. Dashboard
  228. 89 metro timing belt
  229. '90 - '96 Metro Wanted Spokane, WA
  230. Coolant Vanishing Mystery
  231. Window Regulator - Drivers side
  232. Timing belt - scraping noise?
  233. Obd
  234. 95 Metro Dim Headlight
  235. need sterio codes for 95 geo metro HELP???
  236. dashboard and headlights sun damage
  237. Metro 5.5" Brake Booster Question
  238. problem with brakes on Geo Metro 97
  239. 94 metro buy back from insurance
  240. FYI: Code 51 on 95 Metro
  241. radio backlight not working?
  242. I'm looking for info.. on performance mods
  243. SUDDEN no start..
  244. 96 metro fuel capacity? rear deck?
  245. ** Metro Forum Intro **
  246. 92 Suzuki Swift Headlight problem
  247. Dash Vents
  248. temp gauge wacky
  249. stereo wiring for Geo Metro 1997
  250. I've been scarce lately...
