View Full Version : Metro
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16
  1. Temp and Fuel Gauges
  2. I think I killed my compressor
  3. EGR Valve for 1.3L
  4. Dash swap
  5. Lifters or Cam?
  6. should there be a slight vacuum when you open the gas cap
  7. Instrument Cluster
  8. Overheating 91, Fan probs
  9. TPS adjustment
  10. Exhaust Manifold Cracked
  11. i need some help with tranny questions
  12. One of those questions... hmnn...
  13. selling 1998 metro engine+parts/need body
  14. Who sells aftermarket A/C compressors?
  15. Need an ECM for 93 PLEASE HELP!!
  16. problems continue for my lemon (metro)
  17. Intermittant drivebelt squeek
  18. Rear wheel rumble, can't pull
  19. what's it worth?
  20. 1997 metro 1.0
  21. 96 1.3 probs
  22. Fuel Gauge
  23. want to buy 97 and up Geo Metro HB
  24. what's my 97 geo worth?
  25. 2000 Metro question of questions
  26. Wanted: Used Geo Metro
  27. 91 Geo Metro A/C Question
  28. help
  29. 92 geo metro
  30. Anybody want to buy a used head?
  31. metal flakes in tranny oil
  32. Plug gapping question
  33. Geozuki GTi auto to man conversion
  34. Heater/AC fan works only on top two settings
  35. surge
  36. my Suzuki Swift wont start and my mechanic is stumped! can someone please help me!
  37. transmission shifter cable
  38. 1996 Geo Metro Sedan rims
  39. A/C problem
  40. Swapped engine out & it won't start '94 Geo
  41. Canadian vs. Japanese Metros
  42. headlights
  43. 95 MEtro Check Engine Light will not stay off! HELP!
  44. No Spark
  45. speaker cover removal
  46. '95 Metro - Dim Headlights
  47. timing belt problems
  48. Time estimate on swap?
  49. 91 Metro Adjustment....
  50. Lots of smoke
  51. F/S: 1991 Suzuki Swift GT
  52. 2000 STUPID METRO!..ignition key won't turn
  53. engine surge...i think...
  54. what mileage can I expect out of Geo Metro 1.3 L Auto
  55. Does the XFi get highest MPG?
  56. Idle Speed Control Valve
  57. 95 Metro Temp sensor Problem
  58. auto to manual trans swap
  59. Geo Metro in TX?
  60. what is the difference in the EGR's Auto vs. Manual?
  61. 1995 Geo Metro Door Stuck
  62. Tach reference signal
  63. (yet another) problem
  64. Will not hold speed
  65. engine swap and tranny questions
  66. pluged egr
  67. Timing
  68. drive my 97 to Oakland from Peoria, Illinois
  69. strong gas smell
  70. Fuel Pump
  71. Engine squeal
  72. Radio
  73. 95 Metro 27 MPG ALREADY TUNED. Suggestions? BEtter MPG??
  74. 94 Metro problems
  75. Sprint Motor Swap
  76. sick Metro, no codes.
  77. Metro pause wiper and cruise control?
  78. tranny swaps question just to be sure...
  79. 98 metro tranny swaps and smoking engine
  80. trans
  81. Reringing Old Geo 1.0 Engines
  82. Wanted: Used 94 Metro factory service manual
  83. Wanted: Swift gt with bad motor for......
  84. 1995 Geo Metro Questions!!
  85. Where To Find Used Engine?
  86. Would it be possible?
  87. Cigarette lighter and radio on same fuse?
  88. Cooling problems
  89. 91 Metro still rough idle
  90. cv shaft
  91. 96 metro causing me problems
  92. 1991 Metro ignition cylinder
  93. anybody know?
  94. 95 Geo Metro Upkeep
  95. 93 Geo Metro belt Squeal
  96. '94 geo metro -electronic spark control distributor
  97. Strange engine vibration at idle
  98. throttle body
  99. 93' Metro convertible parts *free*
  100. 1.0 compression test
  101. 1987 or 1988 Sprint/Firefly Parts Needed
  102. Sell Metro
  103. 95 Metro No Front Signals, Valves Rattle at Start Of Accel. and smokes for one second
  104. Can a 91 Geo Metro go 75mph on 2 cylinders?
  105. Where to buy new OEM or better suspension arm bushings?
  106. F/S 14" aluminum rims w/tires.
  107. catalytic EGR cleaner any good?
  108. no poser. starts shifts. when I turn off muffler is noisy
  109. starting problem (timing belt?)
  110. blowby
  111. engine swap what about the tranny?
  112. new fuel injectors?????
  113. 93 metro convertible
  114. metro parts for sale
  115. how many vaccum hoses are there?
  116. 93 geo wont run help......
  117. Code readers..
  118. Engine numbers
  119. ok... I need some help.
  120. overheated geo solved
  121. should I buy an 02 sensor off the internet?
  122. Need an EGR for a 97 metro 1.0
  123. EGR really clogged w/carbon clean out or new?
  124. 1996 geo metro ignition problem
  125. Headlights
  126. Is EGR sensor same as o2 sensor?
  127. EGR VALVE change on 97 Metro
  128. Blower Fan
  129. Catalytic converter
  130. Need To See Hooked Up Geos!!!
  131. runs like crap if i rev it up
  132. engine knock
  133. want to buy one
  134. 94 metro unpredictable non-starts
  135. 94 w/funny timing marks
  136. vaccum leak cause loss of power?
  137. tuneup?
  138. Curious about coolant temperature sensor operation
  139. swap or not
  140. noise in rear of car
  141. 96 manual transmission question
  142. Metro went for a trip through a river....
  143. 95 metro code 15
  144. burned up after cat oxygen sensor and burned out catalytic convertor
  145. geo still overheats
  146. Is it a dog to slap another tranny in?
  147. Engine interchange..
  148. Throttle Position Sensor/Throttle Switch Adjustment
  149. front seal leak
  150. error messages
  151. Chevy Sprint: Tranny shifting irregular!
  152. Geo Metro Transmission ?
  153. Removing 1995 Metro steering wheel\airbag
  154. forced air intake
  155. 94 Geo Metro idle and performance trouble
  156. Oxygen sensor cause loss of power?
  157. cat converter or transmission sound under car?
  158. timing belt easy to install? Oxygen sensor?
  159. Metro for sale
  160. suzuki Motersports
  161. How to set static timimg on 93 convertible
  162. How to replace the alternator?
  163. geo overheating
  164. 90-93 Geo Metro Top NEW!! $155.00
  165. Fuel & Temp Gauge max out when driving forward
  166. starting problems
  167. Small water leak behind water pump
  168. 97 Geo Metro Starting Problem, very unique, please help!
  169. metro oil air filter??
  170. Oil and air filter?
  171. Wanted
  172. '97 Engine Surges
  173. 94 automatic poor acceleration
  174. Tach and Dwell Meter
  175. Tachometer
  176. parts for metros
  177. lost two lower speeds on heater fan,
  178. Adding air conditioning refrigerant
  179. metro mpg
  180. '95 Metro - The cure for burnt valves is...
  181. Geo Metro Radio
  182. audio comp car....
  183. used engine problems
  184. recieved used engine
  185. My geo will not start
  186. Oil Consumption ?
  187. only 18 mpg
  188. Metro Mod
  189. Throttle body w/ Manifold for SALE
  190. interior lights
  191. Tapping Hydraulic Valves
  192. headlight wiring
  193. Question About A/c
  194. 93 Metro, not getting gas
  195. '93 Convert A/C from R-12 to R-134a
  196. No Power - Sluggish!
  197. Please help *IAT location*
  198. Is it really the clutch?
  199. What's the best year metro to buy?
  200. Transmission Question
  201. suzuki swift web pages.....
  202. should i replace belt before i put used engine in
  203. question with headlights
  204. 1996 Geo Metro 1.0 only firing on 2 cylinders
  205. metro will not start
  206. 97 metro died
  207. NO Dash Lights?
  208. Low Idle
  209. Metro 3 Cyl Firing Order
  210. anyone need a map sensor
  211. Metro rear disk brake conversion possible?
  212. 1992 metro parts for sale
  213. 98 chevy Metro (what rims?)
  214. 97 METRO for sale
  215. Project Metro Vert II Arrived!
  216. 1994 Geo Metro
  217. Idenity of button behind shift???
  218. How to Loose bolt in end of crank.
  219. 97 Geo Metro Service Engine Soon
  220. 90 metro DIed on the road, see what I've tried I DESP need Help
  221. replacing CV axle shafts
  222. drive line vibration
  223. Rattle from under the car durring shifts
  224. LUGNUTS!?! and turbo questions
  225. No spark
  226. going to buy one, maybe
  227. Changing oil
  228. Used head and cover
  229. TB w/ Manifold for sale
  230. Trying to air up tires on Geo Metro
  231. 96 Metro headlight problem
  232. 96 1.3 liter metro problem
  233. My own project vehicle
  234. metro performance......
  235. Need help. 91 Metro
  236. Used Radiator w/ fan
  237. Hello
  238. front disc rotor replacement
  239. Radiator for sale
  240. Fan Blower switch broke - replacement?
  241. 94 Metro died and wont start
  242. Need ECM for 95 Metro 3cyl
  243. 1.3 liter engine troubles...
  244. Wanted: Geo Metro convertible
  245. A/C Vacuum Solenoid Valve - 1993
  246. Guidance Needed!
  247. 95 Geo Metro check engine light
  248. 1997 metro codes
  249. 94 Metro Will not Start HELP!!
  250. 96 geo mpg and 420 code
