View Full Version : Metro
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16
  1. turbo question?
  2. timing a 1.0 geo?
  3. wont start again?
  4. Good compression, but still burning oil. Help!
  5. antenna?
  6. motor running but have some ???s
  7. Geo Metro Upgrades
  8. HELP!! Fuel Pump not working?!
  9. geo metro 95
  10. radio antenna
  11. removing alternator
  12. HELP:rear main seal
  13. Metro bodies in Illinois
  14. What size is it?
  15. timing
  16. Engine compression test
  17. Key stuck in ignition - '95 Metro
  18. Driver's window off track - 95 Metro 3-door
  19. I am an idiot!!
  20. Need a timing belt cover
  21. Motor swap issues
  22. what do you think?
  23. timing belt
  24. 92 Metro key broken off in ignition
  25. rpm question
  26. Trick to stabbing the engine?!
  27. idle rough
  28. Just bought a '94 Metro
  29. pcv valve trouble..at wits end
  30. The DREADED clutch slip!!!
  31. Fuel Atomizer 2000
  32. No spark
  33. 95 1.3 check engine light
  34. Coolant temperature switch connector removal
  35. Over Heating
  36. need help
  37. 3 cylinder head help
  38. Occasional Mystery Smokescreen
  39. Auto transmission slow to engage
  40. Idle begins to race very high after I start
  41. brakes
  42. Transmission help
  43. 92 geo metro - alt or battery???
  44. tune ups/coil/stuff
  45. Auto to manual conversion
  46. A tool/toy to improve everything running wise 96+ Geo's
  47. Metro Engine Problem
  48. I need an information about 3 cylinders suzuki
  49. 5 spd transmission
  50. Help!
  51. Cng Metro?
  52. Easy 5 speed question
  53. Car wont start
  54. Anyone ever run their geo on an alternative fuel?
  55. GTi Engine
  56. Automatic Overdrive
  57. 1991 Engine Noise
  58. 1995 Geo Metro - Engine Oil
  59. Head Gasket Price
  60. Timing Belt Leaking
  61. 97 Geo Metro 1.3L Engine Problem
  62. Steering control box
  63. need brakes in front
  64. F1 Fuse keeps blowing Advice Needed
  65. final drive ratios
  66. Rear side window seal
  67. Odd radio question
  68. ERG valve
  69. Washer fluid pump
  70. Hatchback release lever and cable
  71. a few questions
  72. Stupid headlight question.
  73. 95 Metro questions
  74. Surprised!#!
  75. 2000 metro timing belt problem
  76. metro wont start backfire through throttle body
  77. line blows off ,runs poorly
  78. Need help on combo headlight switch wiring
  79. 96 1.0L Where's the fuel filter?
  80. Possible Engine Swaps?
  81. cv joints
  82. Metro Running Again
  83. piston rings
  84. Overheating
  85. Steering wheel and airbag removal question.
  86. WANTED:: Geo Metro LSI Convertible top boot cover BLACK
  87. 96 1.0L Timing belt looking for instructions
  88. making tubular headers for my metro
  89. compression
  90. how reliable are Geos?
  91. Checking for codes
  92. sounds like an 18 wheeler
  93. 92 XFI For Sale $450
  94. geo 1992
  95. 93 geo metro won't start
  96. Metro will lurch, lope, surge, cutout on driving
  97. Need parts...
  98. 95 Metro very hard to start, squealing noise until warmed up...
  99. Surging & missing fixed
  100. 97 metro running rough
  101. How do you check the transmission fluid level and what kind of fluid does it take?
  102. new motor change wiring problems
  103. Water leakage at pipe going to water pump
  104. Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!!
  105. my 91 metro won't start...help!
  106. Got it!!
  107. Code P0400
  108. pooor gas mileage
  109. 97 geo metro distributor
  110. WTB Geo Metro convertible
  111. quits at normal operating temperture
  112. Error code 14
  113. Cannot get engine up to temperature
  114. Regular Beam lights won't come on 2000 metro.
  115. O2 Sensor seized in manifold....HELP
  116. insulation
  117. 97 Metro Heater Fan Prob Solved.....
  118. Another way.....
  119. intractable mystery solved 96 metro
  120. Turn the key forward and nothing! Electrical gurus please help
  121. Was a CD an option?
  122. brake rotor removal
  123. Heater Fan Only works slow on 3rd Position..97 Metro
  124. Should I buy?
  125. Anyone got a Transmission Pump For 3cyl
  126. 92 Metro eating belts
  127. 2000 LSi blowing a fuse
  128. Engine Swapping
  129. Crank Pulley/Belt Cover-last things in my way to completion!!
  130. Wanna meet my metro?
  131. Transmission Fluid Change
  132. exhaust
  133. 97 Geo Metro Problem
  134. Timing Belt/Exhaust Manifold
  135. 95 metro starter/headlight problems
  136. Manage Your Heat!!!!!
  137. 96 Geo Metro, Whats wrong?
  138. Engine Teardown
  139. 92 auto trans slipping
  140. What options were available on a Metro?
  141. 96 geo 1.0
  142. Compression Test results
  143. At my wits end!!!
  144. tranny fluid on manual tranny
  145. Increase Performance AND Mileage!
  146. 99 Chevy Geo Bumper
  147. Almost ready to end crankshaft seal saga...
  148. 97 Geo Metro won't start
  149. New board
  150. NO START update....
  151. Merry Christmas!
  152. Phantom air leak
  153. Thrown Rod?
  154. Need A/C compressor
  155. HELP!!!-car won't start
  156. diffrent distrubutor
  157. Hope someone can help.
  158. How to replace woodruff key on crank?
  159. Selling Haynes and Popular Mechanics manuals
  160. alternator belt problems
  161. wipers wrong?
  162. Snow Driving
  163. code 31
  164. 92` Metro,cure for high idle,poor mileage
  165. P0113,P0400,'96 Metro
  166. vacuum help
  167. Heater won't heat
  168. Looking for 1996 neon gauges
  169. 93' metro died on hgwy
  170. 97 Geo Metro Lsi fuel injector problem
  171. 1995 1.3 L crankshaft pulley clearance
  172. Block oil port?
  173. Power Steering Pully
  174. Metro Hood?
  175. 96 to 95 engine swap?
  176. 92-94 radio bezel
  177. Metro Upgrades 1.0 3 cyl Standard
  178. fastest metro? who has it?
  179. oil cooler sandwich mount?
  180. Good radiator.
  181. anyone need tail lights?
  182. WTB: Timing gear for a 96 1.0 3 cyl
  183. Help a Newbie Please
  184. Think I ruined my engine (w/ pics)
  185. wheels and tires on 94 metro
  186. Alignment and New Tires (Issues)
  187. 93 e-brake
  188. Body water leak - drivers floor fills up
  189. manual transmission drain plug
  190. Intermittent reverse on geo metro
  191. Did I bend a valve?
  192. which clutch should i use?
  193. uses a little oil 89,000 miles worry?
  194. Hi-Low Rpm's?
  195. '92 Metro----Blower motor only works on top 2 speeds!
  196. need to carry a little more weight in back
  197. best spark plugs for 1.0
  198. changing clutch, how hard? 3-cyl metro
  199. metro looking for speed
  200. '92 - 5 spd problems
  201. f/s: GT bumpers/sideskirts/spoiler
  202. No manual. Need help to set clock.
  203. Automatic transmission noise
  204. creaking scary noise.
  205. timing of a 96 geo metro 1.0 liter
  206. Hesitation after idling in gear....HELP
  207. engine swap, not typical?
  208. cheap good wheels n tires, will they fit?
  209. outside door handle stopped working (metro hatch)
  210. green sensor on intake?
  211. Source vehicles for Metro
  212. Timing Gear won't come off
  213. what to check
  214. idle
  215. 29 miles per gallon on my 3 cylinder
  216. testing oil pressure?
  217. massive amounts of oil getting ran tbi unit
  218. Idle Recovery
  219. No power in my metro.......need help
  220. pipe,exhaust source?
  221. air valve on TBI 89 metro?
  222. How do you remove driveaxles?
  223. 95 5-speed troubles
  224. geo hubcaps
  225. Platinum Spark Plugs
  226. Just one more to go. Next Level Performance
  227. SpiralMax .. very interesting ..
  228. About lightcovers
  229. timing
  230. how much to change timing belt (3 cyl 1.0 L '97)
  231. front control arm/ water pump
  232. $70.00 Turbonator/ YES or NO?
  233. IAT Sensor 1 ?
  234. 1992 Metro throttle body
  235. Metro Steering!
  236. Geo metro 91 pdf repair manual
  237. 29.5 mpg / 3 cyl hatchback
  238. Ignition Switch
  239. 96 Geo AC has stopped working but everything else OK
  240. stock piping size
  241. 98,99,00 good buy?
  242. ?( that sensor below idle adjusment screw)?
  243. child safe locks
  244. Smooth ride at 75mph ?
  245. 89 Metro boggs on acceleration
  246. Alternator remove
  247. WTB: winter car
  248. mmm.. Fresh Stories...
  249. About gas type
  250. Pulled Engine for Chk UP, Now tranny doesn't work.
