View Full Version : Metro
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16
  1. electrical question - 95 Geo Metro lsi
  2. Finding a new tranny, what to look for?
  3. I thought it was 'Engine Noise' !!
  4. 93 geo metro Won't start
  5. 1995 Geo pings when under heavy accel or hill
  6. 95 metro 4cly ecu pinout
  7. Fastest way to remove the engine 1991 Metro
  8. 95 engine in a 97
  9. won't start in cold weather otherwise runs perfect
  10. Block or dipstick heater?
  11. re: brake bleeding instructions
  12. frozen steering??
  13. 98 Metro- No Fire
  14. Switching wheels/tires...1997 to 1994
  15. Sprint/Metro transmission swap?
  16. Bad synchro...replace tranny and engine?
  17. Auto dimming side mirrors?
  18. Idle/Brake problem
  19. engine for sale
  20. Would a '91 engine fit into a '93 Metro ??
  21. Auto Tranny Problem
  22. lost my cool(ent)
  23. Incredibly frustrating camshaft seal problem
  24. brake switch problem
  25. What is the correct thermostat to use
  26. Radio light bulb voltage?
  27. Throttle Body Vacuum Hoses
  28. no power/acceleration when going around 45/50 mph
  29. New Geo Owner (93 HB, 5sp, 1L)
  30. Door Handles--Interior
  31. Shifter stuck - Anyone else ??
  32. Belts squeal, but only in cold weather
  33. WTB gauge cluster
  34. finally back...after about a year
  35. 96 geo metro floods out
  36. female looking for help with 96 geo metro
  37. '93 Metro 5 spd Transmission - fill where?
  38. A nice way to discuss Digital Photo Images of Metros!
  39. Piece of Junk
  40. Parting ways with 91 Metro
  41. Exploded Diagram of Geo Metro Throttle Body Anywhere?
  42. Final drive ratio
  43. Big smoke screen - then normal.
  44. 92 metro bad mileage
  45. Flywheel Dowel Hole Missing
  46. What causes all of this smoke?
  47. engine interchange
  48. Oxygen sensor
  49. Motor Oil weights - meaning of numbers?
  50. Back-up light switch - location??
  51. 92 Geo Metro is completely dead!
  52. Should we use High Detergent, Thinner Oil?
  53. XFI and LSI Manual transmission ratios
  54. HELP ! What are symtoms of valve (head) problems?
  55. 94 geo metro
  56. geo tranny
  57. Can't change Idle on Throttle Body
  58. Is 40 mpg enough?
  59. Periodic Poor Performance, missing, no power, etc
  60. 93 Metro - Could run better!
  61. Drive Belt squeak
  62. Ignition Timing Off by 2 Degrees
  63. Is it worth switching to a vert auto tranny?
  64. rear window defroster
  65. Engine Cooling Fan Question for female
  66. Poll - Metro peculiarities - Body & Interior
  67. Poll - Metro peculiarities - the 1 Lt Engine
  68. performance effects of ignition timing advance
  69. lost my service manual: need torque #'s
  70. Carbon Removal
  71. 92 Geo metro will not time???
  72. hatchback release
  73. Snow Tires ?
  74. FOR SALE housing air filter cover from 1992 GEO METRO.
  75. removing drivers side door panel
  76. interior parts
  77. 93 metro vehicle speed sensor
  78. Geo Metro 1995, No tails lights, No head lights
  79. Distributor advance part???
  80. fast idle problem found
  81. DESTROYED my clutch tonight. 4cyl trans. in a 3cyl
  82. larger wheels for 94 metro
  83. Zero Compression Prob. Found
  84. Cabin air filter in 92 Geo Metro
  85. Crank Pulley Removal
  86. radio
  87. Here's a stumper
  88. good or bad sensor?
  89. 2 problems
  90. 1995 geo metro
  91. key broke in ignition
  92. JDM engine blowing steam - Metal Intake gasket?
  93. 15W40 oil???
  94. ECM (ECU) ground wires (E1 & E2, GR/BK) floating!
  95. 2000 chevy metro lsi where is the fuel filter
  96. 95 Metro still having problems
  97. Front Wheel Bearing - Which side from the sound?
  98. Timing belt and water pump replacement
  99. 86 Sprint running poorly
  100. Battery? starter?
  101. ZERO Compression in Cyl 3
  102. Is it difficult to replace a '93 Metro Engine?
  103. Need to replace cam shaft, how much is too much?
  104. Does everyones valve knock under load?
  105. service engine soon lamp lit
  106. '93 Metro - Adjusting Idle for Winter ????
  107. Valve specs dims
  108. loose caliper
  109. help identify engine part
  110. PCV valve clogging
  111. motor swap wiring problem
  112. Thinking of buying a Metro and have some questions
  113. peculiar driveability problem
  114. Changing Alt Belt '96 Metro 1.3
  115. Original Motor and DTCs
  116. Parts/Accessories Recommendations/help
  117. Highway Reliability?
  118. 91 Geo Metro - No EGR!!!
  119. metro inner tie rods
  120. oil leak at distributor
  121. brake lights not working
  122. heater core
  123. Conversion
  124. Metro body kits and accessories...where???
  125. Interior Light
  126. 91 metro starter
  127. Sticking fuel sender?
  128. 1997 Geo Metro stalling
  129. Where is ID plate located?
  130. New Owner Question
  131. Fuel Pump Behavior
  132. Howdy Folks
  133. heater core, which hose is in, which is out.
  134. Please Comment Soonest...Thanks!
  135. Removing Alternator
  136. suzuki swift vs geo metro?
  137. Geo Questions & Search
  138. Hello
  139. Overheating
  140. Car deck install in 88 Firefly (CDN Metro)
  141. Alternator Bearing Replacement
  142. Winter Tires
  143. 93Metro 145K,runs good. @idle, speeds up for 1 sec, and cuts gas for 1 sec. PLS help
  144. Water Pump Replacement
  145. 95 metro no power
  146. Compression Numbers
  147. 97 metro tranny problem
  148. Dirty Oil
  149. Overheathing
  150. Attention all gas mileage enthusiasts!
  151. Gas Mileage Increasing Devices: Poll.
  152. O2 sensor mystery
  153. Help with Engine Noise Diagnosis
  154. Hood release
  155. Will '98 Metro seats mount in a '94
  156. 1994 metro looks like spark plug melted
  157. how many miles on....
  158. boggs down after warm up
  159. Metro needs Tracker Window buttons to hold them close.
  160. Gas coming out of my throttle body
  161. Geo drives me nuts help needed
  162. Keeping a stady speed, Please Help
  163. geo metro underdrive pulleys????
  164. Computer (ECU) Question
  165. Softer ride
  166. Metro engines
  167. Tachometer hookup
  168. car idles rough
  169. Amount of Esther Oil in Compressor?
  170. What is going on?! on death row!
  171. Some pictures of our two Geo's
  172. Hard to get to Intake manifold nut
  173. General Questions
  174. Metro Door Hinges
  175. timing belt tensioner
  176. Geo Metro 95 Clutch
  177. geo metro tranny
  178. help with conversion
  179. How clogged can an EGR valve be?
  180. that damn driver door window
  181. throttle body
  182. Air conditioning fuse 15 or 30 amp?
  183. Muscle car metro...
  184. Need Help locating tranny Parts
  185. Dogde Stratus 97 - Coolant Temperature Sensor
  186. Code 15 Coolant sensor circuit
  187. Help I accidently cleared the engine codes
  188. Geo Metro FHi 94 turns over, but won't start.
  189. Coolant disappearing
  190. 91 geo trans issue?
  191. trouble putting throttle body back on
  192. 1994 Metro Check Engine light on
  193. Is it a bad idea to drive too fast?
  194. windshield seal
  195. geo metro
  196. I need a couple of interior trim parts
  197. rip off or not
  198. 93 1.0L won´t start????
  199. Major Oil Leak 3 cyl.
  200. Auto tranny does not shift up or down
  201. engine cuts out under load
  202. broke college girl in need of help!!!!
  203. GM Screws You on Parts Costs !!
  204. 93 geo auto trans no sec gear when warm
  205. Swift parts on a Metro
  206. '96 front crankshaft oil sleeve
  207. Intake manifold water gaskett leak?
  208. Please Help!!!
  209. tork specification for the lug nuts
  210. did i pay too much
  211. engine tranny
  212. Horrible gas mileage
  213. 1990 3 cyl,Has fuel diluting the eng oil.
  214. Metro prices / availibility
  215. '98 to 2001 Geo 1.3L torque curve
  216. 96 geo tranny making noise
  217. 96 Metro 1.3 timing belt off 2 degrees
  218. We want the Metro back!!!
  219. 1992 geo metro trans problem help
  220. distributor cap position
  221. Check out this Metro!
  222. '91 Metro just won't start
  223. Suspension upgrade
  224. temp guage acts like vacum gauge
  225. help a rookie
  226. Tire recommendations
  227. 1995 Metro 1.0 leter won't pass emmissions.
  228. XFi
  229. setting the timming belt
  230. 1994 geo metro where is my fuel filter
  231. 94 Metro Auto trans stays in Drive gear?
  232. OE stereo
  233. what are you getting for MPG
  234. Need this running by tuesday...
  235. Wiring diagrams
  236. A arms & lower ball joints shot. Difficult to replace?
  237. *shifty eyes* GEOZUKI AWAY!
  238. XFi 89-94 ecms, oem part numbers ?
  239. Need Help W/ Engine Code...Got Code, Don't know where or how to fix it
  240. where to get the largest selection of used parts ?
  241. blower
  242. How can I make the Horn Pad stay put ?
  243. Easy way to lub the gas pedal thrust cable?
  244. Is there a code reader for a 91 3cyl?
  245. v8
  246. MAJOR problems with 1989 metro
  247. I need a Geo Metro but I don't need the engine
  248. What i've been up to.
  249. 95 Metro, Need I say more!!!
  250. battery backwards
