Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Geo
> Metro
View Full Version :
Metro
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
where does my oil go?
Need some help.
1993 Geo Metro 3 cyl - Wont Start
window regulators
crappy gas mileage
'97 drivers side mirror question
Timing On A 95 Geo Metro?
Headliner replacement
Speedo Problems
91 metro cranking problem- Need Help!
cruise control
timming
spindle nuts - change every time?
metro wheels
window regulator
Metro wont start
Applying something learned on this Forum....
Clacking noise. Front center of the car.
oil additive needed
performance upgrades for cheap
Can I Overfill The Radiator?
Best Light Bulb
Changing Water Pump
93 geo metro pcikup coil bad again
pcv valve clicking at idle
95 metro squeeling alternator.
1992 Geo Metro replacing the Fuel Pump
Cylinder Head/Rocker Arm Wear
question?
metro compared to suzuki
some questions....
Changing 92 Metro Clutch
? on crank position sensor
MPG...what happened??
1996-97 Metro colors - which available?
Metro Success Stories
Peeling paint - how to fix?
Speedometer not working
acetone in gas
mistery no start problem
miles'gallon
Oil on air filter
1995 Geo Metro O2 Sensor Wiring Colors
Wiring schematic needed
high idle and surge on 95
'91 Geo dies at stop sign
trick the ecm for more hp
What Motor Do I have??????
Auto Trans. help PLEASE
5 speed hard to shift when warm
1993 Yellow Corner Light Replacement
Installing sunroof - hard to do? bad idea?
1995 Geo with rusty suspension
key broken off in ignition
94 Geo Has Spark Flooding Cylinders
2000 4cy Air Filter
WTB - 1995 or newer Metro, for body
Newbie here w/questions on control arms!!
1.3 4cyl relisted
JDM's carburation to EFI
WANTED: Stock radio for 97 metro
1993 Eats Alternator Belt
Factory tach cluster 98 3cyl
1998 metro
Let's compile a list of automotive ACRONYMS.
Engine & transmission swap - possible?
Auto trans interchange question
VIN # question
All this JARGON - it CTHOOM !
testing and cleaning EGR
Rear brake adjustment
1996 1.0L needs engine -- Can I use 1995 JDM?
Click Click ... hard to start info
97 front end problems
97 2 door metro quarter window question
Electrical System Shorted
Code 42. Engine turns over but won't start.
engine coolant temperature sensor
Intro- 1990 Metro Convertible
'96 Front Wheel Lug Bolt CrossThreaded
For sale 13.
Low vacuum and flooding
95 Metro Timing Belt snapped
getting alternator out of engine compartment
fuel pump install success..
Coil Pack or Crank Sensor?
cam gear
cam gear
95 Metro Parts for sale
How do you get the crank pulley out?
home front-end alignment?
Ignition/Electrical Short - 92 GEO Automatic
tune up parts
how long do your tires last?
neutral at high RPM
2000 Metro poblem
EVEP Canisters
How do you replace the Clutch bearing in a 92 metro???
97 wipers won't go.
Rust Question
1.0l engine into a 1.3l '98 metro???
99 Metro engine runs Cold-Warm-Cold-warm
Manual Trans Work
Need help with this
How often do ECMs go bad?
Cutting and using new gaskets
my service engine soon light comes on one one day but goes off the next??
How to take (save) the pictures here....
1997 geo codes
I Found It!!
head gasket
Geo Metro start trouble
G10 transmission for the 3 Cylinder Where the hell do i put in the fluid.
Geo Metro Starting Probles Not the Starter
'96 1.3L metro - is this a deal?
speedometer quit working
fuel filter or battery?
Newbie 98 1.0 HB
anyone here used an exhaust pipe repair kit?
Bottom Half of Throttle Body Exposed !
97 geo 1.0 manual tranny swap to auto
Offerings
2000 Metro LSi dash fuse blowing
Has anyone ever installed a ROBERK wiper delay?
Adding a/c to a '96 metro
A very good investment indeed!!!!
Burning Oil, and Smoking
coolant in #2 cylinder
Front oil seal partially out and leaking
fuel pump replacement
should i put my broken timing belt cover back on?
Cargo/ Hatch cover on ebay
valve cover ventilation and pcv
Taking the Throttle Body Apart - Lower half.
Fuel Line Pressure - Best test point(s)?
'91 Metro Convertable Top replacement help
Coolant Leak near CKP (Crank Pos Sens)
Oil leak prob
body mods for 91 geo metro
will a CRX engine fit in my 91 metro?
melting head light wire with no short to ground!!!!!!
2000 Metro Tie Rod Ends?
fender
feulpump prob.
Can't shift down from 3rd to 2nd ?
1991 metro cranks but won't start - Mystery
Important Update!!
Bent Strut
pcv valve
Hard Shifting....
5 Speed Manual Replacement
headlight swap question
Safe to rinse TBI head with Gasoline?
1995 and 1999 the same?
EFI on 'roids?
XFI without vacuum advance on distributor?
Took TB off - Checked Sensors - Partial Results
Front Wheel Bearing Going Bad?
diagnostic connector on '96 metro
Driving Geo Metros "aggressively" - EPA
E3 sparkplugs... anyone using them?
driveline vibration
Vacuum Gauge - which hose to tap into?
1997 geo metro throttle body injecter
will 98 headlghts fit on a 97?
Whats my engine? / Other probs...
96 metro ECM temp. sensor location
Removing & checking the TPS - easy?
Incomplete Shifting Through Gears
Is Ugly now "In" ?
93 Geo Metro with no spark of pwr to FI
Shift Solenoid and O2 Sensor '97 Metro
A new Thread on ECM's
timing belt replacement
mad metro!!!!!
blown head gasket?
strange rattling in 96 LSi
Very, very wierd idle...help!
93 GEO Metro Auto, Problems
'96 Metro Trans Problem
Message to the Moderator(s) - Suggestion.
1.0L and #3 cylinder
Rear wheel bearing discrepencies
Those nasty alternator blues
Timing 92' Geo Metro 1L
Identifying Sensors - 1993 Geo Metro 3 cyl TBI 5 speed
2000 metro cold start prob.
alternator tips
died while driving
TPS adjust
Where would I install a Vacuum Gauge?
Please help identify these goodies....
XFI ECM interchangability
? on Fuel Regulators
FYI - For those who haven't seen an ECM
something weird
cracked side mirror
Problems97 Geo Metro Stereo and Service Engine Light
Metro roof rack?
locked out need help
97 metro parking cable broken?
my built up 1.3 DOHC engine for sale..
power and mpg loss
Testing Fuel Pump Pressure - HOW? WHERE?
1990 Firefly convert tire pressure?
how to clean crud off of composite beams?
year of motor
93 1.0L MAP sensor code?
Need a good factory tape deck
96 timing belt and alt
97 geo manual swap to automatic?! problem?!
poor gas milage
97 GEO loses power intermittently
New Exhaust system in New England area
hydraulic valve lifters
Check For Vacuum Leaks - Carb Cleaner - Explain ??
Holy Moly!! This is unreal!
97 geo
Head lights doing weird things HELP
AT controller
How can you test continuity with an ECM and O2 Sensor?
99 Metro Blower Motor
97 metro engine stumbling
Simple Question on Side view Mirrors
Information about ECM \ PCM of Metro's ?
Wheel came off
EGR failure
96 LSI....cargo cover? Also, what is this?
Replaced alternator and battery....NEED HELP!
Is removing the one TB Fuel Injector difficult?
where is the coolant teperature sensor?
93 Metro Electrical???
Clicking noise at idle
7 °F - '93 Metro running bad of a sudden!
cylinder head bolts
hard to start 97 metro
96 geo headlight problems
Which is Best Manual Transmission Fluid ?
96 LSI fuel capacity?
instrument cluster swap
New Question
Changed Front Brake Pads - tic tic tic....
95 5 speed transmission interchange question
Awesome Product Alert, Buy NOW!!!
$300 metro
Is there a 'Wheel Interchangability' list available?
95 metro
2000 Metro CV driveshaft question....
Hatchback lock cylinder
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
