Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Geo
> Metro
View Full Version :
Metro
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Problems With My Metro
ground effects, body kits?
97 trans HELP!
Egr and #3 here we go again
Ohio snow killed the Metro
Gave up the '96 Metro
weatherstripping for a 91 convertible?
Idle control solenoid
96 geo for sale
Windshield Wiper Fluid Engages
Empty Radiator Coolant Tank
WTB: Keyset from 92-94 Automatic
Convertible Top Frame
Metro's rule !!!!!!!!
haze on composite headlights???
Convertible Top Help!!!
check engine light on....
timing problems 1990 metro ?
Hesitation at High Speed 94 METRo PLEASE HELP
Missing VECI lable 94 Metro
1997 Metro, Service engine light
engine ping
burned out ignition fuse
95 1.0 Fuel Pressure
92 Metro Ragtop Part Needed
93 geo metro crankshaft pulley
Sign of the times!!
1990 geo metro tensioner plate
96 metro 4sale
metro wont start
86 Sprint (Metro to be) starter won't engage
93 head rebuild?
Can't get the key out.
EGR coincidence ?
Idle tip
drivers side window 94 hb
How hard is it....
Throttle stop screw
Tranny problem found (WOOHOO!!)
Water in oil
What all years will this tach fit?
Hi, I'm new to the forum and have a question.
Aaaaarrrgggghhhhh!!!!!
rotor speed ?
95 GEO wiring diagram found.
lets see some smokey burn out pics
Right Headlight Metro 96
Help with Connector on firewall!
Idle Drops Dramatically with AC
'96 1.3 liter lifter noise
geo parts cars
speaker size?
Poor idle
rough throttle - JERKY GEO
need wiring diagram
Any suggestions welcome!!!
FS: Ready Sleve for 3cyl
Puzzling Power problem *not compression*
FS: Suzuki Swift GTi Springs (stock lower springs)
Need Help with My 1.0
GM p/n for 89-94 Metro/Swift
FOR SALE 95 Metro 3cyl 5spd
Radiator Fan always running
decals?
Geo Metro Headlight Warning
1.0 heads needed...
front hub removal
Ever seen this b4 -- repairable??
1993 geo metro computer swap
Praying to the Audiophile Gods
Where do I buy new 12" tires?
Anyone interested in a GT
99 North American Metro Body (bumper)
1995 Geo Metro TPS specs ?
toneau cover
metro convertible transmission
Newbie needing parts
need wiring diagram
CV joint replacement on 96 1.0 Metro
WTB: MK2 (89-91) Light Grey Dash in MINT Condition
Testing the EGR Valve
child lock inside doesn't open from outside
How do I find GM part numbers?
95 Metro Carpet
'94 2-door Metro driver side window regulator needed
My Fuel Sensor is kinda whack...Can someone help me?
Hi Everyone Im a Proud Owner of a GEO! And I love it!
poor power on hill starts poor acceleration
1996 geo metro lsi trans seal
need cheap parts for my geo metro
Thermostat Question
Oxygen sensor on 94 Metro
need help with my 95 metro
Timing and Custom Hood Scoop
94 geo metro engine id
93 Metro Front Brakes
Throttlebody Gasket
Help With Timing!!!!!
Headlights on create drag on motor...
1996 Metro air bag light blinks then stays lit
1994 Trans. in a 1996 metro? Possible? Other problems too.
Acceleration Hesitation
some irony and a standing "o"
97 1.0L Head
Source for underdrive pulleys?
Where to buy window regulator for '96?
A few questions about the GEO Metro.....
Throttle body gasket question
Timing Info Etc.
changing the fuel pump?
Sending Unit/Scan Tool Hookup
97 Metro
1994 Oxygen Sensor
MPG Help!!
Kill Story> Team Metro 1<> Team Coyote0
Where Is The Gas Filter Located 05 3cyl Metro
I give up! How do you get the gear shift knob off?
loss of power after warm start
97 geo metro problems
Good Deal?
fuse pannel
Audio Systems
backfires thru throttle body
Wanted: Geo Metro XFI
loss of power
Suspension swaps
Engine Missing or Surging at Higher Speeds
94 Metro problems (codes 13 and 51)
Taking the Muffler out in CA of a 94 3banger
My friend can't get his 3 cylinder to run right no matter what he does.
Transmission interchange...what years are interchangable?
need diagram in hurry....
help
'92 Metro with 14 inch wheels...read if you are considering this..
Headlight upgrades??
Rack and pinion problems
92 Metro Conv. Code 23
timeing
F/S: Metro w/GT swap(not mine)
Headlights wont shut off
motor knocks - rebuild or new?
Fogging
suzuki swift GTI
metro keeps squealing
A good one about head swap
What mpg are you actually getting?
standard or upgraded emissions
'94 Metro code 15: coolant temp
How much is a 2000 Geo Metro worth???
Help with Trouble Codes!!!
crashed the metro
the need for speed
Free parts. Come and get them.
96 geo metro
93 metro poor gas milage
94 metro
What Type of Mtl
Radiator starting to leak - '93
Need REPAIR MANUAL for Geo Metro LSI
92 GEO Metro-1 99 Mustang Gt-0
Radiator from a stanard & use in a automatic?
NEED Owner's manual for 96 Geo Metro LSI
Headlights quit working (Fuse Blows Always)
Metro Ragtop
95 metro head bolts
Rca Jacks
94 Metro Lug Pattern
headlights??
Custom Headers request info
Tachometer Question
Surging and loss of acceleration on '92 Metro
high HCs on emmissions test
starters
I want suzuki swift G13b engine
engine wont ignite?
faulty interior fan speed control
wing nut for airfilter casing
'91 Geo Metro wont' start if engine is hot?
metro engine install and surge fix
Has anyone used one of them Turbonators???
suggestions for seat replacement
Instrument Panel Cover
Check Engine flashes once, then twice??
93 engine swap
I need a Top. '92 LSI
92 Metro engine missing?
95 1.3 no power
dash still not working...
Alternator 94 metro replaced 3 times
drive belt questions
I am thinking of selling my 95 Metro
'94 Metro Still Overheating!!!!
No ignition buzz when key is turned, wont start
manual trans dip stick on 96 1.0???
For sale:91 metro
runs,losespower at3/4 pedal down idle is all over the place
steering
Metro Motor Lifespan
cannister
Codes
Pimped my ride
Auto Transmission help please!
97 Tranny in a 95 Geo Plz HELP!!
'00 1.3 burning oil.
crank / gear problem
WTB radio for 95 metro
Spash Shield
leaking and i dont know where....
checked the fuses....
'94 Timing Belt
2001 Metro DUAL-COIL, NO-SPARK
okay got the code....
Probably a Fuel issue...
Steering Wheel Adaptor Kits??
Which is faster?
Urgent! Dirty Metro Transmissions (literally)
Air Filter
Headlights
Cruise control for 96 Metro Manual
VERY Interesting...Please read
Water Pump
My metro beat up a Honda Odyssey!
few more ?s afte r motor change
95 metro code 31
90 Metro Air/idle up valve Question
I just have to do this !
EGR trouble...still
Trade my Mazda Turbo for your 4dr.
engine swap from 89 suzuki swift to metro
how do i find check engine codes?
Struts
OK what's the trick to yanking off the transaxle case?
Fuel Gauge/Hesitation
looking for a eng for my geo
Code 23, On 1990 Lsi Metro 1.0 Ltr
350 in a metro?????
engine swaps on a automatic geo metro hb??
my metro is weak on power
poor mileage
94 Geo Metro Valve Timing
91 metro engine replace?
Engine Whine
clutch pedal help
noob Metro owner with a few questions
Installaton of alternator belt - Help Please
stilll wont run right(92 metro) 1.0 motor
car wont start after using carburetor cleaner...plz help!!!
cruise control 95 metro
I Need To Know What Size Bolts Go In My Motor Mount.
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
