View Full Version : Metro
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16
  1. 1.3 has no acceleration when it's cold
  2. just making sure...
  3. Hard start in cold temps.......
  4. Odometer failure
  5. The Story of My Metro
  6. map sensor not conneced 97' lsi
  7. Car Dead....driving me crazy!!!
  8. Intermittent fuel problems when wet
  9. fuel pressure prob or not
  10. Low Idle, What to Check?
  11. ARGGGG!!!! ANOTHER PROBLEM! This time it won't start
  12. Geo not shifting
  13. Tire ordering issues
  14. WANTED: 1991 or 1992 in NC area with clear title RUNNING OR NOT Parts Car.
  15. Protecting the Metro Frame
  16. Ignition Cylinder
  17. Morning Smoke: Possibly Moisture???
  18. Electrical Disaster or not...
  19. the continuing metro electrical disaster
  20. Wet Distributer
  21. disk brake drag
  22. 99 METRO 1.3 liter computer for sale
  23. Starting issue in a 96 Metro
  24. Brand new bearing set for sale
  25. E-85 Ethanol
  26. WD-40 and Unwanted Paint
  27. Anyone have an extra auto trans
  28. Belt squealing then breaking
  29. Sticky Ignition
  30. Stopping a loud creaking sound in the rear...
  31. Engine Vibration -- gonna be fatal, soon?
  32. 85 Octane Fuel
  33. Getting my Geo's windows tinted.
  34. 96 1.3L head gasket replacement
  35. Drip Stick Tube
  36. Metro 3 speed automatic transmision
  37. Adding sway bars to a 94 metro
  38. NOT AGAIN! - Heater Problem
  39. Need SOME HELP Plz. Cranks Shaft Gear Broken!?
  40. aftermarket new 92-94 door handles review
  41. I love my geo but I have an exhaust problem that sucks...
  42. Looking to Buy Another
  43. Why so Long
  44. Bucking Metro
  45. Bucking Metro
  46. Window Washer Fluid and Nozzles
  47. Suspension problem?
  48. What year tranny will fit my 96 1.3L ?
  49. Geo Metro of Death!
  50. 94 Metro Loses Fast Idle When Cold
  51. Why Is It That...?
  52. My heater fan quit working - 20 °F !!!
  53. 94 Metro EGR Solenoid
  54. 1999 Geo Metro will not reverse.
  55. ignition failure
  56. How difficult is it to replace Transmission's Bearings?
  57. 98 Chevy Metro/ Floods out when cold started
  58. side moldings
  59. 97 Metro Intermittent Starting Issue
  60. Question about the AudioVox Cruise Control
  61. Slow Crank
  62. Troubleshoot/replace starter
  63. stereo and a/c blew
  64. Stereo and A/C blew!
  65. Squeeealing - Shreiks of the damned...
  66. How do I engage the window washer on a 96 Metro Sedan, automatic
  67. 1992 Metro suspension
  68. Can a loose A/C belt cause it A/C problems
  69. Replacing center dash vents
  70. Transmission Oil Fill Plug
  71. Getting different tires
  72. Alternator bolt
  73. cow jumped over the metro
  74. sway bar link replacement part?
  75. new metrophile
  76. intermittent buzzing from dashboard
  77. Everyone have a MetroChristmas and Happy New Gear!
  78. Tire decision
  79. 94 metro floods hard to start
  80. Frothy Oil
  81. NO Charging
  82. Low Fluid is or is my Transmission finally toast?
  83. Rattle in back right rear
  84. Power vs Altitude and Cold Air
  85. I need help with a 96 metro
  86. Ignition Module Location???
  87. 1999 1.3 still no spark on 1-4.
  88. Can't beat Ebay just bought
  89. Car too cold
  90. Steering column lock
  91. What is turning in the Transmission at idle, clutch out?
  92. 1994 metro odometer not working...
  93. Cam seal, crank seal, water pump questions
  94. Draining Cooling system !
  95. Finding my Snow Tires
  96. Air Compressor Advice
  97. Dead Windshield Wiper
  98. My trip to Mexico and cars there
  99. 1.0 L twin-cam turbo w/ 101 hp Metro
  100. Freeze Plug - 96 Geo Metro
  101. Snow Tires
  102. 99 SOHC 1.3L metro...timing chain or belt?
  103. Changing the Brakes
  104. location of computer in a 93 geo metro
  105. Air Filter and Connecting Hoses
  106. PCV Hose
  107. Measuring Horsepower
  108. Metro running rough
  109. 91 1.0l tps adjustment
  110. Off Model Question
  111. The Silver Bullet lives on!!
  112. Considering buying a 95 metro.. questions
  113. how to remove the belts?
  114. Automatic transmission gear ratios
  115. Rough Idle
  116. Trying to post picture of the Dragon!
  117. Tinted Windows
  118. tires I found
  119. I have a question about TBI's
  120. 94 Metro mystery sensor?
  121. 90 Metro cold on hiway warm in town.
  122. 1998 Chevy Metro LSI 5 speed: stiff shift lever
  123. loose valve cover gasket/oil spraying?
  124. Unwanted Paint
  125. Cold Mornings
  126. New Headlights
  127. MPG Computer for pre '96 Metros?
  128. Port and Polishing
  129. 99 metro 4cyl no fuel injector pulse
  130. Car Stereo/Radio
  131. More Horsepower
  132. CV Joint, Bearing, or ???
  133. Thanksgiving
  134. Tire size calculator
  135. 92 Metro automatic won't shift
  136. Timing Belt R&R job cost?
  137. car wants to die when I shift
  138. Thank You Everyone- Metro Dead!
  139. Need transmission mount
  140. Help-geo timing whos right?
  141. 1990 metro timing marks
  142. Need advice on problem-no start
  143. Fuel Saver Chip
  144. Geo Metro Mini Truck Conversion
  145. 1990 3cyl fuel pressure specs
  146. HELP!!!! Heater not blowing very hot!!!
  147. ohm values 90 metro 1.0
  148. Lihtan geo service manual
  149. Ideas Anyone?
  150. Is an Oscilloscope useful for Automotive repairing?
  151. No Fuel Through Injector--No Start
  152. Push button Ignition
  153. Car stalled - is there a problem on the way?
  154. 98 metro floods
  155. 12" tires are making me MAD!!
  156. Is the Metro 4 cyl engine same as Suzuki Esteem's ?
  157. Clearing up the Tach issues
  158. 96 Metro LSI VSS Location And Picture If Possible
  159. A/C belt - do I NEED it?
  160. Metro Transmission
  161. 93 Geo Metro Center Taillight
  162. Po780 Code
  163. Oil Pan Drips
  164. A Few Screws Short
  165. Motor Mounts
  166. new engine
  167. My Shift Lever Rattles...
  168. PCV Valve plugged
  169. Timing Marks
  170. Service Manual vs. Haynes Manual
  171. 98 metro engine swap
  172. Driver side window
  173. I Checked the "code" from the Check Engine Light - OK, now what?
  174. headliner
  175. Replacing thermostat?
  176. 97 geo wont start
  177. Geo Metro Exterior Door Handle
  178. Winter Storage ?
  179. Door Handle Repair
  180. HELP 99 Metro 4cy Keeps Fuel Fouling Plugs
  181. Ring Replacement.. Doc you SOB!!!!
  182. ??? Gas Filter???
  183. Tightening up the 5 speed shifter
  184. Help! Car up and died
  185. Water Pump Going Bad???
  186. We're back!
  187. oil pan/catalytic converter
  188. Hate to ask.. Oil Capacity 1.0l
  189. exhaust manifold studs
  190. Valve Seals
  191. How to clear up composite headlights
  192. '92 Metro 1.0 Exhaust Question -- pipe diameter
  193. 93 Metro Idle Problem
  194. Why do my miles/gallon fall off in Winter?
  195. Torque Steer
  196. Will parts fit?
  197. August 1993 Geo Metro, Starting problems
  198. leaking brake
  199. 93 metro cooling fan
  200. '97 Metro (1.3L) Intermittent stall/sputter
  201. problem with 95 Geo Metro
  202. HELP 99 Metro 1.3 No Spark
  203. Outer CV joint removal
  204. 95 Metro: back-up lights out
  205. HELP - AGAIN - Very SLIGHT hesitation while driving - itermitent check engine light
  206. 1996 Geo Metro Schematic Needed
  207. PCV filter location?
  208. 94 Metro engine problems
  209. HELP NEEDED IN A HURRY! Metro 3 cyl DIED this morning, won't restart
  210. XFI question
  211. Interesting Automotive Situations...
  212. rear brake locked up
  213. Replaced broken timing belt, now head gasket is blown? Why?
  214. Who Knows the Most Efficient Intake Air Temperature?
  215. Weird problem when filling the tank
  216. Metro wants to DIE when A/C is turned on. Please help me!
  217. 2000 Metro 1.3 Tick at idle
  218. Fuel Tank Capacity
  219. Humming noise after highway drive from rear
  220. The error in determining Miles/Gallon....
  221. Window washer setup/hoses
  222. timing for 1990 geo metro
  223. Burnt valve?
  224. Air Conditioning
  225. 95 1.3Lsi Metro Fuel Problem?
  226. Squeeky engine
  227. a/c clutch???
  228. How do you know where to set the timing?
  229. 94 Metro burning anti-freeze
  230. Metro : 1.0 vs 1.3
  231. Roof Rack
  232. Help high idle after I rebuilt engine??
  233. post-metro suggestions?
  234. Engine revs up when started, surges when warm
  235. Is there a "Trick" to adjusting the Window Regulator?
  236. Valve Burning - any way to know before disaster strikes?
  237. Head bolt tightening sequence and torque
  238. Any POWER CURVE (rpm vs torque) published for the 3 cylinder Suzuki engine?
  239. Going in reverse
  240. Wheel size
  241. Clutch Adjustment
  242. Can't clear code
  243. Gas mileage issues
  244. Idle Speed
  245. Dash Lights
  246. Manual Window Track
  247. how to remove shifter, 97 metro
  248. Replacing struts on my 92 Geo Metro
  249. 90 geo metro fan thermostat location
  250. How to put in a used engine
