View Full Version : Metro
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16
  1. EGR valve and pinging
  2. 96 Geo metro LSI Idle Too High When Hot
  3. Metro dead??
  4. 1996 Geo Metro car headlight problem, HELP!
  5. 99 Metro 1.3 Problem
  6. electro surprises
  7. Tranny same as swift/esteem?
  8. Washer Fluid
  9. Brown Gunk under car
  10. Will these Suzuki Swift taillights fit on a Geo Metro?
  11. Back Hatch Cover/Shelf- Where Can I find one?
  12. Insulating my metro
  13. ac button removal
  14. 94 metro
  15. Odometer on the Blink
  16. Tips on Changing Fuel Filter
  17. 93 Octane VS. 87 Octane Gas
  18. Starts fine,fine when warmed up..GRRRR in between.
  19. Lets talk about ATF and motor oil.
  20. 96 geo metro radio locked out
  21. Adding a Rear Hatch Release
  22. The Theory of WARMING UP the engine upon startup.
  23. radio help
  24. leds
  25. help squealing and smoking belt!
  26. Need help
  27. Hubcaps
  28. Some issues
  29. 93 Metro Needs New Engine???
  30. 93 Geo Metro
  31. 93 Geo Metro
  32. '95 Metro 4 to 3 cylinder conversion
  33. HELP - 94 Metro losing power
  34. highly in need of transmission
  35. auto trans will not go forward
  36. Auto. Trans problem...
  37. Making a Cell Phone Charger Plug - Always On
  38. 94 Metro Code 51 EGR Problem ... AARGH!
  39. Interior lights
  40. Interior lights
  41. Where to buy Transmission Rebuild Kit?
  42. How to Post pictures onto this Forum
  43. autopartsgiant.com beware
  44. 93 Convertible Dashboard
  45. blowing ignition fuse
  46. poor speedo alignment
  47. In need of power steering setup
  48. Jumping Speedometer from Calaverous County
  49. What brand of struts should I get for my Geo?
  50. no fuel delivery
  51. Possible cause of Rusting front frame
  52. Tip for Ca. front cat.
  53. 1992-1995 and 1996-2001 gauge clusters...what's different?
  54. 13" tire size?
  55. 96' 1.0 5sp manual transmision swap
  56. Rims for my 92 Geo Metro
  57. 1994 Metro 3cyl- Rattling noise in the back
  58. Head Gasket
  59. Question re: lifters - need a quick answer
  60. Gas Shocks for Hatchback Door - Faulty?
  61. My 96 3-cyl 1.0 died-FREE any takers?
  62. Possible '98 4 Door 4 cyl Automatic for daughter?
  63. Roaring Noise When Driving - Can't figure it out???
  64. 97 metro code po113 HELP!
  65. Calling Dr. House - I need a diagnosis
  66. 91 GEO Metro
  67. Are the TBI fuel injectors the same for the 1.0 and 1.3L?
  68. No power to move 92 metro
  69. Help. I need a combination switch
  70. 1998 Metro Will Not Fire. HELP!!!
  71. Geo Metro/ Swift Mini Truck Conversion Kit
  72. 99 metro 4cyl. smokes - worth rebuilding?
  73. 95 1.3 Auto trans question
  74. more temperature problems...
  75. tempeature problem
  76. 8-valve vs 16-valve
  77. HELP!! trying to time 96 metro 1.3 l 4cyl
  78. 1999 1.3 Timing Marks
  79. ignition fuse on 92 Metro
  80. registering on teamswift.net
  81. hesitation
  82. What Should The Amps Reading Be In A Compressor?
  83. Looking for a good metro frame/body
  84. Correct Iridium Spark Plug Gap
  85. 1994 Geo Metro xfi 1.0 Fuel Filler Neck
  86. Metro convertible & Adding Factory Air
  87. How Do I Prevent Dash Fade?
  88. Looking for advice - Frame
  89. 91 Metro Splash Shield
  90. Need acondenser fan motor
  91. Question About New Exhaust for 94 Metro
  92. lights question
  93. finally insurance $
  94. Intake Passages
  95. Side Mirrors
  96. Cant get key out! help!!!
  97. setting initial timing for gas mileage on 1.0L
  98. Clutch
  99. Should I Worry about my Emissions Test?
  100. Daylight running lights not working
  101. Have any metros hit a deer?
  102. Check engine light
  103. Fixing a Tranny Leak W/Pics
  104. Shifting issues
  105. Vacuum problem - Car works great! Crazy!
  106. A/C conversion Help
  107. Alternator Belt Flies out the back of the car
  108. Electronic ISC
  109. Squeaking Belt
  110. Engine Block - Transmission opportunity
  111. Steering creaking
  112. Need: 94 Metro Transaxle Control Module (TCM)
  113. Just bought metro #3
  114. insurance $ ???
  115. Now I have a Tachometer in The Phoenix...!
  116. no speed reading
  117. 97' Geo Metro Crank Gear worn out
  118. Throttle Position Sensor
  119. Air Conditioning problem (AC Relay)
  120. Fixing the clutch yourself? Parts source?
  121. 1992 Geo Metro Automoatic
  122. Buying New Catalytic Converter?
  123. Spark Plug Gap 94 Metro..
  124. Ive got a 96 metro 1.0 liter ignition problem
  125. Airconditioning help
  126. OBD Connectors
  127. 95 geo metro Emissions
  128. Conversion - lsi convertible into xfi convertible
  129. geo engine vibration
  130. Condenser fan
  131. Control arm info
  132. Help, two wires, and no place to put them
  133. Headlights on a 95 Metro
  134. 2000 1.3L auto transaxle swap
  135. GEO Metro XFI?
  136. Idle Speed
  137. Low idle problems
  138. Computer Code Problem
  139. New clutch but now grinding near fifth gear
  140. Distributor ??
  141. Balancing the Flywheel on 93 Geo Metro
  142. Metro Lifespan?
  143. head light/tail light swap out of a swift gti to a '91 metro
  144. shift linkage-exploded view
  145. no spark
  146. Engine compatibility per year
  147. problems
  148. codes 46 and 51
  149. Trani popped-can I get it unpopped?
  150. local guy builds electric geo metro!!
  151. Dipstick tube gone AWOL
  152. 1990 geo metro ECM
  153. 1994 idle speed
  154. 95 Metro flooding
  155. 4 door front seats in two door car
  156. VSS on 5 speed
  157. Driveshaft Question
  158. I tend to exceed the speed limit....
  159. 96 metro shift malfunction
  160. Um how much would it cost?
  161. Removing bolt with stripped thread
  162. ECM Scan Tools '95 and earler
  163. 90' Metro high idle
  164. If it's not the starter, then what could it be?
  165. Want to buy
  166. Is it the Starter
  167. 95 Metro Test SW Affect On Timing
  168. Help!!!!
  169. The Wal-Mart tire controversy (?)
  170. How are the wheels aligned?
  171. Strange sound
  172. Need some advice and opinions about my 91 metro
  173. Strings for cargo cover, where do they anchor to?
  174. Radiator Support
  175. swift conversion
  176. 96 Geo Timing belt TDC Question
  177. 96 geo Timing belt a no go
  178. A/C-Heater
  179. L4 engine Interchange 1997 Geo Metro - 1995 Swift
  180. cooling fan never comes on?
  181. 91 metro 12"tires?
  182. water pump longevity, jackstand points
  183. Suzuki Swift taillights work on a 92 Metro?
  184. info on suzukird 1.0 3 cyl header?
  185. few quick questions
  186. Is this a deal?
  187. 94 Metro Terrible Acceleration - FIXED
  188. Frt. control arm change..
  189. Check Valve In Head
  190. Check engine light flashes on acceleration
  191. 93 Geo Metro Problem
  192. '93 Metro Weak Takeoff/Not the Clutch
  193. 1990 Geo Metro using oil
  194. where to get a rebuilt short-block
  195. Cargo cover...can you find them?
  196. Under the Reinforced Bumper
  197. smoking engine
  198. 97 Metro 1.3 Downstream O2 sensor
  199. My new LeBra installed on my 92 Geo!
  200. What is the miles per gallon difference 3 cyl to 4 cyl ?
  201. Bolt pattern help
  202. want to buy geos
  203. 96' or 97' motor into a 95'
  204. Stupid question, but will this work?
  205. '95 Geo For Sale
  206. shift problems
  207. Hella Optilux 2020 driving/fog lights!
  208. Want to buy these parts?
  209. '93 Metro 4 Sale
  210. 92 metro engine in a 96 metro electrical problem
  211. OBD II diagnostics
  212. won't shut off
  213. How to destroy a metro
  214. which cam mark?
  215. AC Not Working Need Help
  216. '93 Metro Broken Door Handle Lever
  217. timing or electrical at fault, or...?
  218. 10mmx1.25 acorn lugs work on 13x5.5 rim?
  219. Here's a GOOD reason to keep your clutch adjusted correctly!
  220. 94 metro 1.0 terrible acceleration
  221. Which 02 sensor (1.3L)
  222. 96 Metro/Firefly chassis rust can someone give an opinion if salvageable?
  223. before dashboard re-assembly
  224. Wisconsin to Florida
  225. Headlights
  226. Wanted 93 Metro Convertible For Parts
  227. Need help ID'ing 3 things
  228. Headlights and Dash Lights go out when turned fully on
  229. New Owner ....Lots of Questions
  230. Massager on the gas pedal
  231. White spark plugs
  232. Error Codes 41, 46, 51
  233. Different Headlight problem
  234. EGR Valve Mystery
  235. Problem finding 13" tires
  236. 1.3 Automatic Transmission
  237. Passenger side engine splash shield?
  238. Anyone have these hard to find parts?
  239. Seeking Metro parts
  240. How are Metros for repair?
  241. Any Theories?
  242. An insight on my engine purchase experience I had
  243. Does having more compression create more vacuum?
  244. This is what happens when you get to liking a car...
  245. Strange Noise 2k LSI Automatic
  246. Resonator - Is it important?
  247. Was this feature an "Option" on Geo Metros?
  248. 91 Metro LSi Conv. - Squealing Noise.
  249. Couple Issues
  250. Metro NOOB
