96 jeep has no fire to the distributor or coil HELP
Jeepjones85
05-28-2005, 11:27 AM
I have a 96 jeep cherokee 4.0L . Here is the problem i am not
getting fire to the distributor or coil all the fu :eek2: ses are good {may be
a relay problem?} also key igntion has been replaced and that did
help.
If there is any thing else it could be please send message...
Thanks Jeepjones85
Jones85@gmail.com
help.
Thanks Jeepjones85
Jones85@gmail.com
aubs42
05-31-2005, 08:51 AM
What does the car do when you try to start it? I was having a problem like this that is very hard to track down.
oio
05-31-2005, 11:52 PM
I had the same problem and found it to be the (crankshaft position sensor). It is located on the bell housing where the engine and trans bolt together. Mine was at the top at about ten o clock looking forward.
It is a cheap part and if it is bad you will get no spark. Good luck Kevin….
blacky horse
06-05-2005, 04:20 AM
check the coil blug or the relay coz i have the same problem and it was from the coil plug .
