mad metro!!!!!
geoboy5000
01-04-2006, 06:52 PM
Ok this is the problem.The car is fine at 30 m.p.h. but after that it starts to shake.The shaking gets worse the faster I go. I don't know if its a wheel balance problem cause i felt for a bump on the tire and one is not there.when I get to 50 mph or faster I feel like the tire is wobbling 1 inch off center. the lug nuts where tight. So if anyone has an idea what the case may be i would like any help on it.Also there is a faint clicking noise coming from the passanger side.I was wondering if its the c.v joint or the engine. I have to skills on cars. All i know is how to check the fluids and drive it.anything goes wrong i get nervous.
By the way where under the car is the fuel filter and how do you change it?
unbe
01-04-2006, 07:02 PM
Fuel injected or carb?
Crvett69
01-04-2006, 07:03 PM
you can jack the tires up and spin them and look for a wobble or take it in to a tire or alignment shop. most will check it for free and tell you what the problem is. on the click if it gets louder when you turn a corner its most likely a CV joint, if noise stays the same its something else
geoboy5000
01-04-2006, 07:18 PM
it has a carb on it and the noise is more ranom than steady but its like someone is tapping the wheel well softly with a piece of metal by the way can they lift it if the passanger floor is almost rusted away?
unbe
01-04-2006, 07:41 PM
Your fuel filter is on the firewall under the brake master cyl.
Tominator2000
01-04-2006, 08:05 PM
Lift the whole front end via the bulge you see in the front crossmember.
Check those ball joints! :grinyes:
seb001
01-04-2006, 08:16 PM
Yes, check the ball joint.
My wheel fell off while driving. You don't want that...
Crvett69
01-04-2006, 08:24 PM
fuel filter should be in rear by tank
frets14
01-04-2006, 10:12 PM
Your problem is most likely the rust. I had a Metro once that acted like that. The rust had weakened the A-arm support. You may not be able to save it unless you are good at extensive sheet-metal welding. Good luck.
